Transparencies
Started Mar 25, 2013 | Discussions
Hudsonriver Contributing Member • Posts: 695
Transparencies
I was wondering if there are any printers that can print on a transparent medium and also is there a medium and ink available. The purpose is to project an image on to a canvas and draw the image..Thanks ..Jeff
Serhat Abaci Regular Member • Posts: 265
Re: Transparencies
I guess its only medium based... I can print with my epson 1400 and epson 4000 pro on transparent material, but it has to be "special" inkjet stuff..
I printed out various movie posters for a "horror film mashup festivall" mirrored on A2 Sheets, then they where put into lightboxes with backlight, wonderfull!
 Serhat Abaci's gear list:Serhat Abaci's gear list
Canon EOS M Canon EOS Rebel SL1 Canon EF 40mm f/2.8 STM Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +3 more
RS_RS Senior Member • Posts: 1,733
Re: Transparencies
Why not use a digital projector?
Hudsonriver OP Contributing Member • Posts: 695
Re: Transparencies
Thanks Serhat for the printer information and also RS-RS for the advice but I already have the projector...Jeff
FRGorga Regular Member • Posts: 305
Re: Transparencies
Jeff,
The solution to your "problem" is Pictorico OHP Transparency Film, see:
http://diamond-jet.com/premiumohptransparencyfilm.aspx
http://diamond-jet.com/ultrapremiumohptransparencyfilm.aspx
I use the "Premium" version to make negatives for alternative processes (mainly cyanotypes). I am currently using an Epson 3880 (pigment-based) for this purpose. In the past, I used a Canon i9900 (dye-based) for the same purpose. OEM links in both cases.
Re: Transparencies
Thanks FRGorga thats great information..Jeff
