Red River Metallic Paper is Amazing
Started Mar 25, 2013 | Discussions
John Crawley
John Crawley Senior Member • Posts: 1,136
Just ran a series of shots from my Nikon D600 and my Lumix FZ200 off onto some Red River Metallic paper and I am blown away. So crisp. So sharp. So 3D...you feel you could almost fall into the pictures. And in black and white it is phenomenal.
My work was printed on a Cannon pro9000. I have never had prints come out as clear and as deep in detail. I did have to lighten everything by about one f stop in PP (Both Photoshop and Aperture) to match on paper what I was seeing on screen, that is because the metallic papers really like to soak up (or suck up) the ink.  But the end product is worth the fuss.  My 8x10's and 11x14's look like film.
I am using the 66lb Polar Pearl Metallic. Quite impressive.
John Crawley
“Let there be light.” It all began right there.
http://www.flickr.com/photos/wordsandsuch/show/
There are three kinds of people: those that are good at math and those that are not.
 John Crawley's gear list:John Crawley's gear list
Sony Cyber-shot DSC-RX10 Fujifilm X100T
Nikon D600
wcrosman Contributing Member • Posts: 833
Re: Red River Metallic Paper is Amazing
kenwj Contributing Member • Posts: 573
John, are you using dye ink or pigment ink?  I was wondering if pigment ink that does not seep into the paper gives you the 3D effect also.
 kenwj's gear list:kenwj's gear list
Nikon D800
jtoolman
jtoolman Veteran Member • Posts: 5,594
He stated he printed on a Canon Pro 9000 so it is dye.
I have a couple of sheets of RR metallic as well as Inkpress Metallic and will have to test them out.
Wonder how the Pro 9500 MKII or K3 ink based Epson Printers would do with it's pigment inks?
Petruska Veteran Member • Posts: 7,548
So-so with pigment
You need the translucent dye to work the metallic magic.
Bob P.
jtoolman
Re: So-so with pigment
Bob P.
That's what I figured though RR says that it is compatible with K3 Ultrachrome as well.
So it's either CONE Dye K3, or Epson 1400 or Canon 9000 MKII.
Joe
It's K3 compatible...
Bob P.
Joe
but with a dye/pigment eval print side by side, you will pick the dye.
Bob P.
TonyGamble Senior Member • Posts: 2,562
Re: It's K3 compatible...
This thread has prompted me to get a sample of Breathing Color Vibrance Metallic and it is supposed to work in an OEM ink 3880.
http://breathingcoloruk.com/bc/catalog/product_info.php/vibrance-metallic-p-84
I'll let you know how it performs. Should arrive tomorrow.
Red River is not available in the UK - and if the Breathing Color works it makes importing the RR a non starter.
Tony
Tom-C Senior Member • Posts: 1,160
On sale
Red River has a 20% off sale, good until the 27th or so.
I've never tried their metallic paper. But got the sale notice from them because I'm a customer.
Tom
 Tom-C's gear list:Tom-C's gear list
Canon EOS 5D Mark III
John Crawley
John Crawley OP Senior Member • Posts: 1,136
Re: On sale
Red River rep was in the camera store the other day and suggested that dye inks work better with their metallic than pigments right now. They are working on one that will work well with pigments. Should be out soon. some other brands may already have them, I just do not know about them.
John Crawley
Hugowolf Forum Pro • Posts: 12,545
Works with, is different to works well with. Sure you can print on it with no problems, but it isn't 'spectacular' with pigment ink. It most often comes across as yet another odd ultra high gloss paper.
I have a sample of an early Mitsubishi metallic paper (no longer available) that was much more pearlescent than the two main varients available now. It wasn't a paper for general use like the newer ones, but when it worked, it really worked with pigments.
Brian A
chooflaki Regular Member • Posts: 397
I use MOAB Slickrock metalic paper with custom profiles for my Epson R2000. Could not be any happier.
 chooflaki's gear list:chooflaki's gear list
Fujifilm FinePix X100 Sigma DP2 Merrill Fujifilm FinePix S2 Pro Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro +2 more
Given their characteristics, they are probably both a rebranding of the same paper.
Brian A
Brian,
"with pigment ink. It most often comes across as yet another odd ultra high gloss paper."
Agreed from this afternoon's tests.
Looks no different to the Breathing Color Vibrance Gloss at jolly nearly half the price.
What I found odd is that their three Vibrance papers (Metallic, Gloss, Lustre) are all far from white. Seemed odd to me to make a paper like Metallic and not give it a white base. I can add warmth in printing but can't remove it.
Tony
soloryb Senior Member • Posts: 2,148
Tony
I have BC Vibrance Metallic on order and have tried the RR , InkPress, and Proline metallics. So far I've downloaded and installed the 3880 profile (from BC) and just did a quick comparison in LR between the BC profile and the RR Polar Pearl Metallic 3880 profile. I could see no difference in the soft-proof, at least. I then called BC and spoke to a tech who told me that the two papers are very similar. He claimed - of course - that I will like the BC Vibrance Metallic better. Once the stuff comes in, I'll do a side-by-side and post my impressions.
 soloryb's gear list:soloryb's gear list
Fujifilm FinePix X100 Nikon D800E Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Fisheye-Nikkor 16mm f/2.8D +9 more
TonyGamble wrote:
Brian,
Tony
Proline's Luster Chrome (metallic) is warm in comparison to RR Polar Pearl Metallic - on the 3880. After talking with BC, it may be that the lower the amount of OBA the paper substrate contains, the warmer the whites appear.
Re: On sale
John Crawley
Thanks for that info re RR Metallic.
I was going to order a 100' roll of it after getting some fantastic results with several large test prints from a 3880. Your post prompted me to call RR tech and ask. They told me their metallic paper prints worked well on both pigment and dye printers and wouldn't say which produced the best results. They also denied that they are working on an improved variety designed specifically for pigment inks. At this point, I'm going to wait and see a little longer before committing to a roll of the stuff, since the RR rep that you spoke of may have it right.
Re: On sale
Red River doesn't sell rolls of the metallic paper. Just sheets.
Tom
Re: On sale
RR does sell rolls of metallic paper. They're just temporarily out of it.
http://www.redrivercatalog.com/browse/66lb-polar-pearl-metallic-inkjet-photo-paper-rolls.html
Tom
Re: On sale
Thanks. Due to Red River's strange web site I had missed it.
Looking under Metallic paper at 66lb or 80lb shows no roll paper.
Looking under roll paper I had missed the metallic listing.
At one time the only way to find roll paper was to go to the roll paper option rather than look under the individual paper type, such as Polar Matte. They eventually fixed that but apparently the metallic paper didn't get the fix.
Tom
Tom
