***Weekly Wildlife Thread - Mar 24 - Mar 30***
Started Mar 24, 2013 | Discussions
burtcat
burtcat Regular Member • Posts: 295
Re: Florida Spring Birding Life
Nice stuff you make me want to venture down south away from the Rockies.
burtcat
Re: Color Version
Both are very cool; where is the location that they were taken?
burtcat
Re: Mine from the week - 9 images
Looks like a great week with lots of choices; nice series.
miles green
miles green Veteran Member • Posts: 4,990
Eurasian curlew
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +9 more
Atgard
Atgard Regular Member • Posts: 432
Re: ***Weekly Wildlife Thread - Mar 24 - Mar 30***
zackiedawg wrote:
Indeed that late in the day the light gets nice and warm, but can also be a little hard when the birds come low under where the golden sun hits them to get enough light. Not bad - you need to work mostly at controlling the exposures, as some of them are a little 'hot' or overexposed. Most likely because you were tracking them as they went against trees or water or near their nest tree, where there was a lot of dark background which told the camera to meter up, only to then hit the open bit of sky and not be able to adjust in time.
I'd recommend trying out spot focus more than the other modes...unless you're dealing with flying birds against big, blank skies, the spot meter will allow you to more precisely tell the camera where you want the focus, and avoid that issue of the background sometimes being in focus rather than the bird - as long as you learn to keep the spot focus on the subject. For any still birds, spot will be your friend - and for large, slower birds like the herons, it's not too hard with a little practice to keep the spot on them.
You're doing well - keep it up. I missed you probably by 30 minutes or so - I had just left as you were just arriving. Maybe next time!! I may be there this Friday since it's a holiday, and almost certainly on Saturday which is my normal day out there. I almost always start at Green Cay - bigger park and selection...spend 3-4 hours there, before moving over to Wakodahatchee later in the day.
Thanks for the tips … I've mostly been using center point focus -- definitely when stationary, and I've been experimenting both ways with smaller BIFs.
Yeah, late in the day is when lots of birds start flying in for the night, but the light can get challenging for BIFs (although really beautiful for stationary subjects).
 Atgard's gear list:Atgard's gear list
Sony SLT-A37 Sony a77 II Sony 70-400mm F4-5.6 G SSM
Atgard
Gene Tenold wrote:
Very nice set, I also am working on my BIF shots, I work on the slower bigger birds, and now I am trying to get the smaller and faster birds.
Gene
Thanks! The faster ones are definitely tougher to track, especially if they're close enough to nearly fill the frame! Sometimes it helps to get them gliding in for a landing.
I don't even really bother with the really small & quick birds yet either -- I'm not fast enough for them yet!
Atgard
Re: Some BIF's with the Nikon D600 (8)
Gene Tenold wrote:
Taken with Nikon D600 & Sigma 80-400 (OS)
Gene
Nice shots, I especially like these two with the reflections.
Peter Heckert2
Peter Heckert2 Contributing Member • Posts: 520
Some from spring last year.
All taken with Panasonic G3 and Walimex 500mm f/5.6 manual focus lens.
This lens is rather light and not really sharp fully open, so the images are processed a lot.
Rat.
Rotkehlchen (german name)
This is a heavy crop, the distance was 20m or more. If I go closer, the bird will see me and stop singing, so, what to do?
Wild female duck
Young yellow hammer
Yellow hammer.
have fun,
Peter
Gene Tenold
Gene Tenold Veteran Member • Posts: 3,275
Very nice set, here in San Diego a lot of the lakes have the Canadian Geese, and they are pretty much up to let you get close-ups of them as long as it is not too close
Gene
 Gene Tenold's gear list:Gene Tenold's gear list
Sony Alpha DSLR-A700 Sony SLT-A77 Nikon D600 Sony DT 16-105mm F3.5-5.6 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) +12 more
Gene Tenold
Nice captures, I like the last one best with the different color.
Gene
Gene Tenold
Re: ***Weekly Wildlife Thread - Mar 24 - Mar 30*** A couple of shots
Very beautiful detailed shots, how do you like the D800? I have the D600 and love it very much, even though it does have some of the dust spots on the sensor.
Gene
Gene Tenold
Very nice low angle shot, have not seen one posted here in a while.
Gene
Gene Tenold
Re: Sam's Weekly Wildlife
Nice portraits, we have those Geese here as well and they let you get pretty close for nice shots. I also like the Coots because you can always see them in a squabble of some sort.
Gene
Ed at Ridersite
Ed at Ridersite Forum Pro • Posts: 17,063
You win the most birds award this week Gene!  My favorites though are the two with the reflections - real nice!
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
Gene Tenold
The Usual Suspects (14 images)
The shots with the a77 are the Sigma 150-500 (non-OS), and the Nikon D600 are with the Sigma 80-400 DG (OS)
The Nikon shots
The a77 shots
Gene
jameswyatt
jameswyatt Regular Member • Posts: 169
Bald Eagle through the snow.
Bald Eagle shot through the snow from about 120 yards.
 jameswyatt's gear list:jameswyatt's gear list
Sony Cyber-shot DSC-RX10 Panasonic Lumix DMC-FZ1000 Sony a77 II Sony DT 18-250mm F3.5-6.3 Sony 70-300mm F4.5-5.6 G SSM +1 more
steelhead3
steelhead3 Veteran Member • Posts: 6,126
burrowing owl
Only the 3rd recorded burrowing owl in our area (Central Oregon) in the last 20 years.  I backed off to not disturb the owl, so this is a jpeg 500 f4+1.4 TC and in camera 2x crop.  My attempt at maual adjustment left me with a little front focus.
 steelhead3's gear list:steelhead3's gear list
Sony a77 II
zackiedawg
zackiedawg OP Forum Pro • Posts: 25,495
Re: A few from the weekend in St.John's Newfoundland Canada
Very nice Gene - I love the birds up that way because most are quite different from what I see down here.  I saw my first chickadee when I was up in northern Quebec - lovely little birds and not too shy.
Nice selection and surprisingly warm light - doesn't look as wintery!
Justin
galleries: www.pbase.com/zackiedawg
 zackiedawg's gear list:zackiedawg's gear list
Sony Alpha DSLR-A580 Sony a6000 Sony Alpha a6300 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +22 more
zackiedawg
Re: All from this morning :-) . Really.
You've got some diversity for such un-birding conditions!  I'd love it myself, being bound to warm places virtually my whole life - snow is wonderful to me, and I thoroughly enjoy it the few times I get to visit it.  While the global weirdness brings you long strange winters, it brings those of us way down south a complete lack of winter - handful of days in the 50s, and the whole rest of the year at or above 90.  Going on 3 years now since we had a proper, weeks-long cold spell, though this year wasn't quite as bad as last year's 'the winter that never was'.
You're right on the red-bellied woodpecker...except for the lightest brush of pinkish red hue as they get older, they don't really have much in the way of red on their bellies.  Problem is, the name 'red-headed woodpecker' was already taken, and indeed they have a VERY red head...so they had to call that one something else!
Justin
zackiedawg
Nice waterbirds!  I like the flock shots - always looks like abstract art to see so many birds in the air in a shot.  I really like #6 and the last one, both very nice detail on the birds with great water reflections beneath them.
Justin
