Laptop for serious amateur photographer
Started Mar 24, 2013 | Discussions
lnguyenh
Contributing MemberPosts: 685
Mar 24, 2013
Hello,
I am on the hunt to upgrade my current laptop (Dell inspiron 1520, 4G RAM, Core 2 duo, Seagate Momentum 750GB). I use my laptop for all my photo work, with Lightroom and Photoshop. I also have an old Eizo screen 19" that I use when I want more screen surface. I use the Xrite eyeone display 2 to calibrate my screens.
The ideal setup might be a desktop computer, but it just doesnt fit my current lifestyle.
I have been looking at the Asus rog g55 and g75.
I would like a good setup performance wise (Right now my files are 12 MP, but they might get bigger in the near future). My budget is around 1200 euros. I would prefer a touchpad with "separated mouse buttons". I am not after ultimate portability. I am more for a solid build, with little noise and good cooling (which are big selling points for the Asus G55 and G75). The screen should be decent, but doesnt have to be pro grade (within my budget it is probably out of reach anyways).
Do you have an opinion about 15 vs 17 inch for laptops? Do you agree with the G55/G75 suitability for photo related work? Other laptops I should look at?
Canon PowerShot G7 Panasonic Lumix DMC-G5
JulesJ
Forum ProPosts: 38,421Gear list
Re: Laptop for serious amateur photographer
In reply to lnguyenh, Mar 24, 2013
lnguyenh wrote:
Hello,
Solve all your problems and get a Mac laptop. Don't muck about with a Windows based one.
KENTGA
Veteran MemberPosts: 4,107Gear list
In reply to JulesJ, Mar 24, 2013
Look at this thread I started a couple of weeks ago. I ordered an HP from HP and just got it so I don't know much about it. I replaced a 6 year-old Dell that was very slow.
http://forums.dpreview.com/forums/thread/3392743
Kent
 KENTGA's gear list:KENTGA's gear list
Panasonic Lumix DMC-FZ150 Canon EOS 5D Canon EOS 40D Canon EOS 7D Canon EOS 6D +14 more
NewsyL
Veteran MemberPosts: 5,634
The weak point with laptops has always been the screen in terms of matrix type, gamut coverage, and bit depth.
A screen with an IPS panel, full gamut coverage (either standard sRGB or wide gamut sRGB + AdobeRGB), and at least a true 8bit color depth is preferred.
Many, like the two you have focused on, have the guts to process images and video reasonably quickly and enough drive storage to get you through a good period of time until you have to archive images to external drives.  Almost all Windows laptops, and until the Retina displays - Mac laptops, have had screens that were not ideal for image editing. (There was a period about 6 years ago when a few laptops had better quality screens but they vanished recently.)
They usually use a TN LCD panel matrix which has poor viewing angles such that what you see on the top and bottom of the panel is shifted in gamma & color from the middle - users will fiddle with the angle of the screen to try to get it right.  Ditto left to right but usually not as noticeable in laptop screens as on large desktop monitors that use TN panels.
Then their backlight's usually did not offer even a full gamut coverage.  For about 18 months now we've seen an influx of laptops with IPS LCD matrices.  These offer much better viewing angles but still quite a few of them offer poor gamut coverage - 67% of sRGB is not uncommon.  So an IPS panel is not guarantee of full gamut coverage.
Another point with laptops is that often the screens were not offering a true 8bit color depth (16.7 million colors).  They were actually 6bit (262,144 colors)  and used a basic form of Frame Rate Control (FRC; often referred to as a dithering technique) to simulate an 8bit color depth.  Recent budget priced IPS desktop monitors also do this but they typically use an Advanced FRC.  Both have potential to produce banding in gradients and artifacts in dark areas though the curent AFRC is actually quite good.  The older FRC could be quite bad in some laptops.
So.... if you're really serious and you want accurate color on the laptop screen with full sRGB coverage and maybe even wide gamut coverage (sRGB + AdobeRGB), you're going to have to put out about $2000 USD to get what is sometimes known as a mobile workstation.
If you can live with a substandard screen while mobile and can use the (calibrated?) external back at home base then the ASUS models will suffice.
Here's a web site that I use for reference because they check the gamut coverage of the screens:
http://www.notebookcheck.net/
________________________
Newsy http://newsy.smugmug.com
DonA2
Senior MemberPosts: 2,527Gear list
In reply to NewsyL, Mar 24, 2013
Have a look at the Luminous Landscape site.  www.luminous-landscape.com
Don V. Armitage
 DonA2's gear list:DonA2's gear list
Canon PowerShot S2 IS Canon PowerShot SX10 IS Canon PowerShot S100 Canon PowerShot SX40 HS Canon PowerShot SX50 HS +1 more
gblatchford
Regular MemberPosts: 275
In reply to JulesJ, Mar 25, 2013
I would argue don't bother with a Mac as you'll end up paying twice as much for the same as a PC thinking it's twice as good to justify the madness.
For twice the price you'll get a PC that poops on a Mac at the same, I did, Dell Presision M6600.
I don't really find that it limits my work/sales as a working professional, but the others here who swear a beauty parade is what sells you images, are obviously correct.
My tu'penny'worth.
GB
JulesJ
In reply to gblatchford, Mar 25, 2013
Plus twice the ease of use and twice less hassle and a thought out user friendly interface unlike MS's
My tu'penny'worth.
GB
alvie
Regular MemberPosts: 253
In reply to lnguyenh, Mar 25, 2013
I'm in the boat that you're in.  I was going to buy a Mac but then you have to pay $200.00 for photoshop upgrade in order to use mac platform CS6.  You'll have to pay a minium of $1600.00 for the mac retina pro 13 inch, you may also have to pay for any other software you have in your windows that you'll need. See where I'm going.  Mo Money...stay with the windows base laptop.   In the long run its no better no worse that the mac.
Tom_N
Veteran MemberPosts: 9,997
In reply to alvie, Mar 25, 2013
That's Adobe's doing.  A Mac user of an old copy of Photoshop who was going to buy a Windows PC and move Photoshop to it would face the same "upgrade to cross-grade" fee.  (To make things more fun, I think Adobe now only allows upgrading from the immediately-previous version.)
There are no laptops like the Retina MacBook Pros (whether 13-inch or 15-inch) anywhere in the Windows world.  But as a rule, if you go high-spec in the Windows world, you'll also have to pay for it.  (Take a look at the price on an HP EliteBook with DreamColor 2 IPS screen lately?)
turbsy
Contributing MemberPosts: 788Gear list
In reply to JulesJ, Mar 27, 2013
JulesJ wrote:
lnguyenh wrote:
Hello,
And why diodes buying a Mac solve the problem?  Can you even get a MBP for 1200 euros?
 turbsy's gear list:turbsy's gear list
Olympus XZ-1 Nikon D50 Nikon D300 Nikon D800 Nikon AF-S Nikkor 300mm f/4D ED-IF +11 more
Birk Binnard
Senior MemberPosts: 1,815
Here's what I did
In reply to lnguyenh, Mar 27, 2013
I use a laptop when travelling for photo & video backup & editing.  So I wanted a machine that was easy to pack but still had enough power to run Photoshop Elements, Autopano Giga, and Sony Vegas.
I know from experience I needed at least an i5 CPU, and after converting my desktop's boot device to an SSD I knew the laptop had to have the same feature.
I opted for an ASUS ZenBook - because I only use it when travelling I got the small one with the i5 CPU, but they make a big screen one as well, and you can get an i7 if yu want to pay the extra $.
ZenBooks have IPS screens and therefore display a really great looking image.
My ZenBook has a 128GB SSD drive, period.  This is not a lot of space - with Win8 & my software I have about 60% free.  But I travel with a 2TB USB3 pocket drive which is where I put system backups and all my image & video files.  (On a typical trip I usually end up with about 50GB of photo & video files.)
Win8 is another story itself of course.  Most people either love it or hate it.  I'm a hater, but I installed a $5 utility called Start8 that makes the system look & run just like Win7.
Birk Binnard
www.birkbinnard.com/photography;
JulesJ
In reply to turbsy, Mar 27, 2013
turbsy wrote:
JulesJ wrote:
lnguyenh wrote:
Hello,
Pas with most things, you get what you pay for.
turbsy
JulesJ wrote:
turbsy wrote:
JulesJ wrote:
lnguyenh wrote:
Hello,
let me correct that for you.  You get what you over pay for.  MBP are nice well built machines. I have owned two. With the new non upgradable MBPs i cannot recommend them even with the retina screen.
Tom_N
Yes, you can.  But according to the prices posted on the French Apple Store site, that would be for a 13" MacBook Pro (base model).  15" models with quad-core CPUs (which better match the specs the OP seems to want) start at 600 euros more than that, and go from there.
Curiously enough, the numbers for the base 13" and 15" models are the same on the U.S. and the French sites, even though the units (dollars, euros) differ, and the euro is worth more.  I think the French prices may include VAT, whereas the US prices are the prices before sales tax.
