Custom Brackets Mini-RC?
Started Mar 24, 2013 | Discussions
bravozulu Contributing Member • Posts: 897
I got one of these last month and love it. This is the paparazzi-style affair with a bend in it, allowing your right hand clearance between flash and camera so you can easily hit the shutter button when shooting vertical (portrait) ?
Someone asked me if that offset and separation from the lens axis eliminates redeye. And I couldn't tell him. The flash sits slightly forward and about 5 inches to the right of the camera. Does that shift prevent redeye?
 bravozulu's gear list:bravozulu's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
fotowbert
fotowbert Senior Member • Posts: 2,044
Red eye and flash position
Any shift offsetting the flash tube (when shooting direct flash) from the lens axis does reduce the tendency for red eye.  With longer focal lengths 5 inches may not be enough.
Placing the flash above the lens axis works works best when you must use direct flash.  This results in the harsh direct flash shadow being cast behind the subject where it is less noticeable.
When shooting film a flip style flash bracket was almost essential for direct flash as it allowed this for both landscape and portrait orientation.  With digital and enough MP I now tend to shoot everything landscape (flash in hot shoe) and reformat in post.
  • John
 fotowbert's gear list:fotowbert's gear list
Canon PowerShot A20 Canon PowerShot SD870 IS Fujifilm FinePix F31fd Panasonic Lumix DMC-LZ8 Canon PowerShot S95 +15 more
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,724
Re: Red eye and flash position
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
bravozulu OP Contributing Member • Posts: 897
Wow. Bouncy, bouncy. I never thought of that using two speedlites.
exdeejjjaaaa
I wish two side arms for 2 + 1 flashes...
I also put arca clamp on it
What do you mean about 'Arca clamp'? An Arca quick release mount like on a tripod head?
exdeejjjaaaa
yes
