Manfrotto to Arca Swiss - 732 CY with A3RC1
Started Mar 23, 2013 | Questions
jamesbm
Regular MemberPosts: 181
Mar 23, 2013
Hi
I have a Manfrotto 732 CY tripod with a A3RC1 ball head.
What is the best way to convert this to make it compatible with an Arca Swiss L-plate?
Many thanks,
newtoy
Regular MemberPosts: 391Gear list
Re: Manfrotto to Arca Swiss - 732 CY with A3RC1
In reply to jamesbm, Mar 23, 2013
Do you realized that the L-Plate and clamp alone may cost more then your whole tripod setup?
 newtoy's gear list:newtoy's gear list
Nikon D70 Nikon 1 V2 Fujifilm X-T1 Nikon D810 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +23 more
Kuppenbender
Senior MemberPosts: 1,958Gear list
With great difficulty
Those smaller Manfrottos are unfortunately a bit of a dead end street. I think I'm right in thinking that neither the head nor the QR clamp are removeable. In which case there are three ways of doing it.
1. Get a cheap Arca-Swiss clamp from eBay and attach the clamp to your manfrotto QR plate.
Although cheap, I wouldn't recommend this. It would probably require some sort of butchering of your Manfrotto plate and the additional connection between camera and tripod would probably undo any benefit in stability of the L bracket.
2. Although the head is not removable, the centre column is. You could replace the centre column with some metal tubing and use some epoxy resin to attach a threaded bolt. See this site for more detailed instructions. You will then need to buy an Arca-Swiss compatible head.
3. Sell your tripod and buy a new, Arca-Swiss compatible tripod/head, but spend a little more next time.
 Kuppenbender's gear list:Kuppenbender's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +3 more
