Wide-angle options for NEX-6
Started Mar 23, 2013 | Discussions
mgn2
Regular MemberPosts: 138Gear list
Mar 23, 2013
Coming from Nikon (have a D5100) and about to get the 14-24 Nikon or 12-24 Tokina for lanscapes (both are $500, Nikon used, Tokina new). Is there a NEX-6 + lens combo that will work just as well if not better in terms of IQ and lens optics? If so which lens is this? The smaller the lens the better, and I really don't mind primes. What gets used by far the most on my Nikon bodies (D5100 and D40) is the Nikkor 35mm 1.8, for which there is definitely a great alternative in the NEX universe.
Nikon D40 Nikon D5100 Sony Alpha NEX-6
blue_skies
Veteran MemberPosts: 9,413Gear list
Re: Wide-angle options for NEX-6
In reply to mgn2, Mar 23, 2013
The Nex-6 works well with almost all WA lens solutions. Most compact are the RF lenses, unless you want a zoom. The E1018 is likely to be the most compact zoom. Zeiss has announced a 12mm/f2.8 lens that may be above your budget, but pricing is not known yet.
Aforementioned lenses all produce very sharp images. In your budget, WA RF Voigtlanders would be a first choice, but they do have softer edges than e.g. the Zeiss lenses.
Of-course, if 19mm suffices, the Sigma 19 is a very easy choice.
The E1018 also softens at the edges, so it may be a wash.
Most lenses are f/4. If you use f/4 and up (f/5.6), the cheapest way to go is the E16+ECU1 adapter. This will give you a 12mm effective FL with reasonable sharpness. Edges are not perfect, but quite acceptable.
The same ECU1 is rumored to work with the upcoming E20 pancake lens. This would give you a 15mm effective FL, with higher IQ than the E16, but again, edges may not be tack sharp.
OTOH, edges were never really sharp with legacy (SLR) lenses either. It is that we can now pixel-peep at 100% and see the details more clearly. With some lenses it is not lens IQ, but field curvature. You can e.g. focus on the edge (have soft center) and take a second pic with focus on the center (soft edge) and then layer the two images in PhotoShop or so to combine them into one sharp image.
Most of the time, the edges don't bother me. When viewing the picture in full size, the edges appear either sharp or don't matter, due to the composition.
(If a Nex-7, then the WA RF lenses are pretty much a no-go).
Pricing guestimates:
  • $100 - Sigma 19 (gen-1) (19mm/f2.8)
  • $200 - Sigma 19 (gen-2) (19mm/f2.8)
  • $250 - E16+ECU1 (12mm/f2.8, but use > f/4)
  • $350 - E20+ECU1 (15mm/f2.8)
  • $500 - Voigtlander (21mm/f4 skopar)
  • $600 - Voigtlander (15mm/f4.5 super wide heliar)
  • $800 - Voigtlander (12mm/f5.6 heliar)
  • $800 - E1018 (10-18mm/f4)
  • $900 - Zeiss 12 (12mm/f2.8)
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Sony DT 18-55mm F3.5-5.6 SAM +33 more
