HS50 settings
Started Mar 23, 2013 | Discussions
jcmarfilph
jcmarfilph Veteran Member • Posts: 7,592
HS50 settings
6
So I recently acquired my HS50 and have been playing around with its settings (I missed the quickie buttons) and I am somehow adjusting to Q button and menus of this cam.
With my first outing with the cam (see Red alert... red alert!) I did use the same settings I have for my HS30. Note that there maybe some slight changes as I progress with this cam.
I normally shoot wildlife so here I am using C-Mode with these settings:
Static/Semi Static critters
C-Mode set to Aperture-Priority (Go to Aperture Priority mode then save to C-Settings)
ISO = Auto 400 (shoot first on this then if the critter stays shoot on lower-ISO)
DR = Auto
EV = -0.33 now at 0.
Aperture = F/2.8 (it will become f/5.6 on the long end automatically and vice-versa)
Image Size = L 4:3 RAW
Image Quality = Fine
Film Simulation = Velvia/Vivid
Color=Mid
Sharpness=Standard
Tone=Standard
File format = RAW+JPEG
Noise Reduction = Low
Intelligent Sharpness = Off
Face Detection = Off
Face Recognition = Off
Image Stabilization Mode = Continuous IS
AF Illuminator = On
EVF/LCD Mode = 50 60 fps now.
Quick Start Mode Power Saving - High Performance Mode = On
Continuous Shot Mode at 5 frames/s
Photometry(Metering) = Spot
White Balance = Auto
AF-Mode = Center
Focusing = AF-Single
LCD on Best Framing (RO3 guide)
For Bird-in-flight or other flying critter
Shutter-Priority Mode
Shutter speed = 1/1000s
Focusing = Continuous
For Macro
Aperture or Program Mode
Flash ON for insects and other critters under shade
To achieve Maximum magnification/Shallow DOF set the focal length to 150-160mm TBD (EFL) and lens at 3-5 TBD inches away
For Low-light
EXR-SN or PAS mode
ISO=Auto ISO1600
Image Size = M 4:3
DR = DR100
Film Simulation = Standard
Noise Reduction=Low
Sharpness=Standard
For General purpose type of shooting like events
Program Mode
ISO=Auto ISO400
Image Size = M 4:3
DR = DR400
Noise Reduction=Low
Sharpness=Standard
Notes:
  • If you want extra resolution shoot in L-Size and set DR to Auto, File-type to RAW and PP it. After careful post-processing, resize it down to 50-75% (depending on the quality of the shot).
  • I am using Silkypix to PP my RAW files but sometimes especially on macro mode, JPEG is more than enough.
Here is screenie of my default SilkyPix settings
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
tom1234567
tom1234567 Senior Member • Posts: 1,033
Re: HS50 settings
DR = Auto
Color=Mid
Sharpness=Standard
Tone=Standard
AF Illuminator = On
AF-Mode = Center
For Macro
For Low-light
EXR-SN or PAS mode
ISO=Auto ISO1600
Image Size = M 4:3
DR = DR100
Noise Reduction=Low
Sharpness=Standard
Program Mode
ISO=Auto ISO400
Image Size = M 4:3
DR = DR400
Noise Reduction=Low
Sharpness=Standard
Notes:
-=[ Joms ]=-
Just want to say Thank You jcmarfilph  for posting the settings will try these
Cheers Tom G
I'm a 30yr old trapped in a 62yr old body
 tom1234567's gear list:tom1234567's gear list
Nikon D7200 Tamron SP 70-300mm F/4-5.6 Di VC USD Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Nikon AF-S Nikkor 50mm f/1.8G
MitchyK7
MitchyK7 Regular Member • Posts: 131
Re: HS50 settings
Thanks for these settings joms, i will try them out. Will help me with these little flitters;
tom1234567
Re: HS50 settings
MitchyK7
Nice Photo
Tom G
jcmarfilph
jcmarfilph OP Veteran Member • Posts: 7,592
Re: HS50 settings
No problem!
Such a lovely photo. I will definitely run this thru some micro-constrasting and NR and resize it down to 12MP with USM.
-=[ Joms ]=-
Tim39
Tim39 Senior Member • Posts: 2,884
Re: HS50 settings
If only all HS cams had come with a guide like this...
Tim
jcmarfilph
Re: HS50 settings
Tim
Fuji cam should come with predefined preset like this.
-=[ Joms ]=-
470LTZ
470LTZ New Member • Posts: 2
Re: HS50 settings
Thanks Joms…you are making it harder for me not to order one of these and learn how to shoot Fuji!!! Thanks for the torture…lol...
How about a link to HS50 Manual anyone have or can drop box one?
Ralph McKenzie
Ralph McKenzie Senior Member • Posts: 1,818
Re: HS50 settings
Joms :
You are using an EXR camera in standard mode and while some of the EXR functionality is still available - DR400% for example, you and others still seem to insist on doing this.
The EXR sensor is designed to be used with the EXR processing on-board.  I have yet to see anyone produce a photo with the EXR cameras that is better shot in standard modes as opposed to a properly shot EXR mode. Also I have yet to see it proved that shooting RAW with these cameras gives you a significant improvement in image quality compared to the Jpeg.
Raw shot with the F series is definitely better, but I've never seen anyone shoot Raw with an HS camera that has proved to be worth all the extra PP work needed, especially in light of the lack of RAW processing in mainstream software, which Silky definitely isn't.
Forget about the massive zoom, use the lens atlow/mid range zoom and a RAW only & Jpeg only and lets see how they look SOOC and no processing. Shoot one  series using the standard ( your current settings) and one using the EXR settings at the same image size and a series in EXR DR mode. Lets see what the camera can really do, because what I'm seeing from everyone here so far and yes I know you are all new to the camera ( but not new to EXR cameras) is very little if any improvement in image quality and if we are to believe Fuji in their claim the IQ is improved then we aren't seeing it to date.
It will be interesting to compare Dave Lloyds images once he has a bit more of a handle on the camera.
Love dat Fuji
http://akiwiretrospective.wordpress.com/
Fuji HS20EXR
Fuji HS10,
Pentax K1000, Pentax sf7, Pentax zx-50
 Ralph McKenzie's gear list:Ralph McKenzie's gear list
Fujifilm FinePix HS20 EXR Fujifilm X-A2 Fujifilm XF 27mm F2.8 Fujifilm 50-230mm Fujifilm 16-50mm F3.5-5.6 II
Tim39
Re: HS50 settings
Any torture that Joms doesn't intend is purely gratis and just a happy collateral benefit of communication.
If he can incite you into ordering one, and your experience can persuade you into keeping it, that'll be game, set and match for me.
Tim
Tim39
Re: HS50 settings
Ralph McKenzie wrote:
Joms :
Seriously good points, Ralph.  They have to be dealt with before there can be any kind of reasonable consensus on this camera.  I think there are substantive improvements with the 50, but my eye, at least,  doesn't see them influencing the images shown.
Haven't heard or seen Dave in what seems like eons.  Really miss that guy.  Presuming he's well and prospering (photographically speaking).
Love dat Fuji
Fuji HS20EXR
Fuji HS10,
Tim
painterdude
painterdude Senior Member • Posts: 2,836
Re: HS50 settings
have to generally agree with what you write ..After all my fooling around with settings ..in general ..shooting a EXR cam in its  duh EXR modes wound up being the fail safe fall back setting for me (though I still like messing with L and varied settings ) .
Most of the shots on my site listed below were shot with fuji EXR cams in EXR mode..DR EXR being a fav. I never shot RAW though Dave L did ..and was able at times to get better stuff from some shots via RAW pping  hence he generally shot RAW+jpeg . He has a HS50 now. If there is a person I listen to on EXR cams ..its Dave so keep tuned. He may post here I dunno ..
His  HS series shots  blow away anyone elses I have seen re quality (artistic & tech merit)  IMHO. While some were washing the HS10 down the drain as a Fuji debacle (as I heard it claimed here) , he was slamming killer shot after killer shot from the same cam. He just worked the settings and found the capabilities of the cam.
anywhoo..
all the best
g
 painterdude's gear list:painterdude's gear list
Fujifilm FinePix F770EXR Nikon D90 Nikon D800E Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 16-35mm F4G ED VR +2 more
tom1234567
Re: HS50 settings
Tim
Hi there try this link for Manual when page opens scroll to bottom and click on HS50
http://www.fujifilm.com/support/digital_cameras/manuals/#s
Tom G
Bassy
Bassy Veteran Member • Posts: 6,802
Re: HS50 settings
hi joms  i enjoy reading your findings what ever they may be,   you bring life into the threads
i just wish i had zoomed in a bit more  with my canon sx50
i know you like birds flying  so have a look if you wish
http://forums.dpreview.com/forums/1010
and the gracefull swans with my g1x
click on original and then click again
http://forums.dpreview.com/forums/post/51145068
 Bassy's gear list:Bassy's gear list
Sony Alpha a6300
jcmarfilph
Re: HS50 settings
Joms :
EXR is for DR only (which is very achievable using RAW) and don't force yourself to cripple your cam into a half-resolution camera.
Can you guess which is which? You'll gonna need tons of PP to justify the advantage of MSize DR400 over LSize DR100 here. L-Size has advantage in resolution and shooting in RAW will double that plus the DR advantage of M Size can be surpassed in RAW.
You have an HS20, try it.
See my samples above. Deep also posted side-by-side comparison using HS50 in my last thread
http://forums.dpreview.com/forums/post/51120281
Kim just bit his tongue and cannot explain why L-Size stomped the M size in resolution and sharpness.
Dave is a RAW shooter too so lets see.
Love dat Fuji
Fuji HS20EXR
Fuji HS10,
-=[ Joms ]=-
Wellington100
Wellington100 Veteran Member • Posts: 8,266
Re: HS50 settings
I came up with an outdoor daylight Black and White setting for EXR cameras which is:
S/N mode, ISO100, B&W, -1EV and lift the shadows in PP to bring out the tones that you want.
Try it on the HS50 in strong sunlight especially and I bet you will get both great contrast and as much tone in PP as you can handle.
I shoot this in jpeg on my F300 and even then it works very well I think.
DR = Auto
Color=Mid
Sharpness=Standard
Tone=Standard
AF Illuminator = On
AF-Mode = Center
For Macro
For Low-light
EXR-SN or PAS mode
ISO=Auto ISO1600
Image Size = M 4:3
DR = DR100
Noise Reduction=Low
Sharpness=Standard
Program Mode
ISO=Auto ISO400
Image Size = M 4:3
DR = DR400
Noise Reduction=Low
Sharpness=Standard
Notes:
-=[ Joms ]=-
Doctors are bad for your lifestyle.
jcmarfilph
Re: HS50 settings
Since you've done tremendous amount of PP in JPEG, why not do it in RAW? See my samples above, upsampled M size cannot match the LSize in resolution. DR difference is almost nil and is only visible if you will pull down the highlight and lift the shadows. Again I can do it easily with L size too and much better in RAW.
DR = Auto
Color=Mid
Sharpness=Standard
Tone=Standard
AF Illuminator = On
AF-Mode = Center
For Macro
For Low-light
EXR-SN or PAS mode
ISO=Auto ISO1600
Image Size = M 4:3
DR = DR100
Noise Reduction=Low
Sharpness=Standard
Program Mode
ISO=Auto ISO400
Image Size = M 4:3
DR = DR400
Noise Reduction=Low
Sharpness=Standard
Notes:
-=[ Joms ]=-
-=[ Joms ]=-
jcmarfilph
Re: HS50 settings
You have a lovely swan there. I would suggest to pull-down those blown highlights though. I am just sharing my knowledge and experience here so I am happy if someone will appreciate it and will benefit from it.
-=[ Joms ]=-
Wellington100
Re: HS50 settings
Well my F300 is pre RAW it has the old jpeg only firmware.
In my head I know I should be using RAW with my cameras but my jpegs are good enough for my screen needs but for quality stuff I intend to try soon, I will go FF Nikon and RAW I guess
DR = Auto
Color=Mid
Sharpness=Standard
Tone=Standard
AF Illuminator = On
AF-Mode = Center
For Macro
For Low-light
EXR-SN or PAS mode
ISO=Auto ISO1600
Image Size = M 4:3
DR = DR100
Noise Reduction=Low
Sharpness=Standard
Program Mode
ISO=Auto ISO400
Image Size = M 4:3
DR = DR400
Noise Reduction=Low
Sharpness=Standard
Notes:
-=[ Joms ]=-
-=[ Joms ]=-
NOEL 100
NOEL 100 Contributing Member • Posts: 676
Re: Have to agree.
I like others have C set up with the "recommended HS settings" and generally get good results. But I also use the auto modes on occasions when I feel the "preferred settings" are a bit restrictive. Auto modes can do a pretty good job when you haven't got the time to play around and I wouldn't discount them totally.
After a lot of playing around I've come to the conclusion that shooting RAW has little gain for me. JPEGs out of the 30 are really good enough for most of my needs and the added extra of PP RAW in one of the packages doesn't really return the value for effort factor. I'll also say that I've tweaked the odd JPEG when needed with good results but it's not an every day event.
Ralph you must just about have your finger on the buy button by now?
Must comment that I prefer Sharpness at hard it suits my personal taste, medium, just a bit soft for me especially at some of the longer shots.
Noel 100
 NOEL 100's gear list:NOEL 100's gear list
Fujifilm FinePix HS30EXR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Nikon AF-S DX Nikkor 18-300mm F3.5-5.6G ED VR
