Suggested improvements for SPP
Started Mar 22, 2013 | Discussions
aleatory
Contributing MemberPosts: 992
Mar 22, 2013
1. For each adjustment bar, have independent manual and auto radio buttons for each adjustment. For example, set brightness to auto while keeping shadows and fill light fixed.
2. Levels command with similar adjustments found in the Photoshop levels command.
I think these improvements will improve everyone's workflow as they may find using Photoshop only for levels adjustments.
I learn from what creates through me.
http://www.egap.me
Antone
Contributing MemberPosts: 839
Re: Suggested improvements for SPP
In reply to aleatory, Mar 22, 2013
A unified edit window so one click on the image brings it up
Use the GPU for editing and file export
Brushes (too much to ask, probably)
Presets to get you in the ball-park
Enable the magnification function at all times - it should never be grayed out
No need to save edits to a file - once you work on it, those should automatically be saved
Tony-S
itairom
Regular MemberPosts: 430
Crash less
Hornbrille
Regular MemberPosts: 305Gear list
In reply to itairom, Mar 22, 2013
Let me adjust noise reduction before preview is complete without crashing
Show before after somehow.
Provide banding reduction and label it accordingly.
Add banding and posterization warning.
Add noise and grain control for separate layers in monochrome.
Let me use the color picker in Foveon Blue color mode.
Uwe 8-)
 Hornbrille's gear list:Hornbrille's gear list
Sigma dp2 Quattro
atom14
Senior MemberPosts: 1,627
Ein sichtbarer Bildschirm!!!
OK, you might well, ask, but loosely...
"A visible/readable screen/interface!"
atom14+. (Ionized.)
Rudi
Senior MemberPosts: 1,023
Re: Ein sichtbarer Bildschirm!!!
In reply to atom14, Mar 22, 2013
At least the labeling of the menues and buttons could be a little bit brighter.
panpen
Contributing MemberPosts: 954
1. Better jpeg conversion
2. Crop and rotate tools
motionride
Regular MemberPosts: 108Gear list
In reply to panpen, Mar 22, 2013
1. Support GPU Processing
2. Customizable UI
3. Adjustment Panel to be adjusted to the side (ideal in multi monitor environments where you have space to the side but not to the bottom (if all the panels are extended you cannot see everything))
4. Better multi CPU/core support
 motionride's gear list:motionride's gear list
Sigma DP1 Sigma SD9 Sigma SD10 Sigma SD14 Sigma SD15 +14 more
James05
Regular MemberPosts: 163Gear list
Second the crop and rotate tools
Hornbrille
In reply to motionride, Mar 22, 2013
Let us fully open the custom settings dropdown menu and let us sort, group and exchange the custom settings.
Let the settings be stored in a human readable text file.
Uwe 8-)
Sigma dp2 Quattro
AdamT
Forum ProPosts: 58,216Gear list
Kelvin and Tint sliders
It`s needed them since Day one and they`ve stubbornly resisted them for over TEN years !
Canon PowerShot G1 X Nikon Coolpix P330 Panasonic Lumix DMC-GM5
sfa1966
Veteran MemberPosts: 3,299Gear list
  1. Crop
  2. Rotate
  3. Ability to darken blacks (neg fill light doesn't do it for me)
  4. Stop causing my computer to groan loudly.
sfa
 sfa1966's gear list:sfa1966's gear list
Sigma DP1 Sigma DP2 Merrill Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +9 more
Laurence Matson
Forum ProPosts: 11,493Gear list
Quick question on printing
How many people here print directly from SPP?
Laurence
laurence at appledore-farm dot com
"The fact of being reported multiplies the apparent extent of any deplorable development by five- to tenfold" (or any figure the reader would care to supply).
Barbara Tuchman, A Distant Mirror
http://www.pbase.com/lmatson
http://www.pbase.com/sigmadslr
http://www.howardmyerslaw.com
Laurence Matson
In reply to sfa1966, Mar 22, 2013
sfa1966 wrote:
  1. Crop
  2. Rotate
2. Rotate is possible at 90° steps.
3. How much darker do you want the blacks? Are you using the Shadow slider now?
Laurence
sfa1966
In reply to Laurence Matson, Mar 22, 2013
Laurence Matson wrote:
sfa1966 wrote:
  1. Crop
  2. Rotate
Thanks, but just for convenience, I would like to be able to tweak and straighten slightly tilted horizons within SPP without exporting TIFFs to Photoshop Elements.
I find that on many shots I am converting to 16-bit TIFF, taking them into Lightroom and then doing nothing other than taking the 'Blacks" slider dowm to the -20 to -30 range in the Develop module. It gives a kind of contrast boost, but leaves 90% of the pixels unchanged.
Using Shadow and negative Fill Light - in any combination - I can't find an equivalent workflow to replicate that effect in SPP (yet). I am open to suggestions, however.
sfa
SandyF
Forum ProPosts: 14,937Gear list
Re: Quick question on printing
I print directly from SPP.
FWIW, the two 'features' I wish were in SPP are straighten/trim tool and dust spot tool.
Best regards, Sandy
http://www.pbase.com/sandyfleischman (archival)
http://www.flickr.com/photos/sandyfleischmann (current)
 SandyF's gear list:SandyF's gear list
Sigma DP2 Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Canon EOS 5D Mark II +6 more
Roland D
Regular MemberPosts: 189
To speed up
Allow user defined Scratch Disk like in Photoshop.  It would then be possible to use a Ramdisk as scratch disk.
rd
Roland D
Thumbnails
A 1 step top create thumbnails pics to make it easier to select pics from Windows Explorer
or
create an add-on to Explorer to see imbedded JPG from raw (like Arcsoft raw viewer)
rd
Hornbrille
Re: Thumbnails
In reply to Roland D, Mar 24, 2013
You can have Explorer preview of x3f and many other formats with Fastpictureviewer's Codec Pack.
Uwe 8-)
Sigma dp2 Quattro
Johan Borg
Senior MemberPosts: 2,276
In reply to panpen, Mar 24, 2013
Definitely. As a side effect of saving the crop area in the X3F file, the camera could also give hints for cropping (after a firmware upgrade) - for example:
3:2, 4:3, 1:1, 16:9, Center (half size)
