Will I be happy with the x20?
Started Mar 20, 2013 | Discussions
Adiel Shmit Contributing Member • Posts: 506
after selling my 5D nd some good L and 2.8 zooms because  I didn't want to lug them around,
especially now with a 6 month old son, and his baby gear...:)
I am travelling to NY friday, and one of the missions is to buy a FUJI.
my logic:
X100  focus and high iso not on par with what I need (clean 3200)
x100s- price and limitatinon of a fixed lens
x-e1 , great, but with 35mm  (love shallow DOF)   what about the wide angle? price tag...:(
x-e1+18-55mm ( shallow dof gone?) and $1300 price tag..
suddenly i thought to myself: what about the x20?  yes, its a smaller sensor compared to x-e1 and x100, and surely the eos 5D,  but it has a bright zoom. but I cannot find anywhere online about its high iso capabilities, and shallow DOF...
HELP?  need to make a decision soon...
thanks.
music and photos.. capturing the beauty of life.
Canon EOS 5D Fujifilm FinePix X100 Fujifilm X100S Fujifilm X20 Fujifilm X-E1
itairom Regular Member • Posts: 431
Re: Will I be happy with the x20?
If you like shallow depth of field and you're used to the image quality of a 5D, it's hard to imagine that going X20 only will satisfy you. Don't get me wrong, I think it'll be a great family camera and I probably will get one myself for that purpose. But I also have other gear to complement it.
pcb_dpr Contributing Member • Posts: 835
Both X100 and X100S both have fixed lens, X100S should be a bit better at ISO 3200 but not hugely better. The X100 is already pretty darn clean.
Haven't seen much X20 output yet, but I have a hard time imagining its smaller sensor will be better than X100 at 3200. Plus the lens is slower, so you'll need to shoot at higher ISO than X100/S. Smaller sensory with slower, wider lens in general means more depth of field. You'll have to check the dof charts, does a 28/2.8 have more or less dof than a 23/2.0 (X20 vxs X100)? Definitely 35/1.4 will be shallower, and the 23/1.4 when it ships.
XE1 is pricier, but you have faster lenses available, clean high-ISO.
Obviously you'll have to try these out to see what works best, but I can't imaging the X20 being the best replacement out of the Fuji family for a 5D w/2.8-L glass, at least when you two most important features are clean 3200 ISO and minimal dof...
my logic:
thanks.
Adiel Shmit OP Contributing Member • Posts: 506
makes sense.
if I go with the X-E1 , would the zoom lens be enough?
I cannot justify bothe 18-55mm and 35mm.
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 6,416
makes sense.
I would recommend 14 and 35mm. If just one lens get the zoom, the 35mm is not wide enough for most things.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Sony Alpha 7R Fujifilm X-T1 Sony a6000 +13 more
Bjrn SWE
Bjrn SWE Regular Member • Posts: 405
I think the X20 will make a great second camera. Image quality will not be anything like the 5D, but the cam seems to be a gem and I am very tempted myself! But if you want to own just one camera, I'd say there are other alternatives.
 Bjrn SWE's gear list:Bjrn SWE's gear list
Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 35mm F2 R WR
David Mintzer Forum Member • Posts: 75
Remember, many of the good photo stores are run by Jews, and they close early on Fridays.  Also, I believe Passover starts soon and they will be closed for a couple of days.
mixersoft New Member • Posts: 14
Curious - what is the prevailing sentiment for the one camera "alternative" if your price point is $600?
Part of the decision is focal length needs, part is probably financial. Fuji has rebates through 3/30 in the US, some lens choices may be cheaper than others.
The 18-55mm is roughly equivalent to a 28-85mm on your 5D, max aperture 2.8-4.0. That gives you focal length versatility, but puts you at the higher ISO range indoors and gives more dof than a faster prime.
The 35/1.4 has an efl of 50mm on a 5D, two stops+ faster than the zoom so shallower dof, lower ISO. But pretty tight focal length. The 18/2.0 efl is 28mm, on stop faster than zoom, slightly shallower dof, wider view.
If you had to start with only one lens on your 5D, would you want a 28/2.0, 50/1.4 or 28-85/2.8-4.0?
makes sense.
Don't know if there's such a thing as "prevailing sentiment" for best $600 camera. You'll find different answers at different forums I'd reckon.
OP didn't set a $600 price point, seemed to be thinking the X20 might be a better choice than the X100/S, other things being equal, and would be significantly cheaper than an XE1.
well,  on my 5D, my favorite lenses (excluding anything above 80mm..)
where the 24-70mm (especially for the 24-35mm for scenes  and the 70mm for portraits.
and the beloved 50mm f1.8 (which gave me so much pleasure, I left it at home as a gift to my wife with her eos 500D (so she can take a bicely bokeh'd portrait once in a while) as she only has and wants to use her 18-55mm kit. (i stopped arguing with her about this as she wakes up at night to feed the baby and I sleep through:).
argyrotype Contributing Member • Posts: 597
the X20 is a really nifty little camera, arguably the best of the small (<1 inch) sensor compacts, but it has limitations.  I;d like to have one, even as a single camera for an Italy trip, and ISO 3200 is really pretty good, see this 3200 image:
http://mos.futurenet.com/techradar/art/cameras/Fujifilm/X20/sample%20images/DSCF9273.JPG
The OVF is crummy in the X10, but the X20 is supposed to have fixed its shortcomings (except for the 85% coverage).  I am coming from an X100 and consider the images I took with an X10 to be acceptable but not special.  I've seen images from the X20 that are pretty nice, but you will not mistake the X20 for a Sigma DPMerrill.
http://www.flickr.com/photos/minami/sets/72157632822934670/with/8499454651/
http://www.flickr.com/photos/absolutic/8557783009/sizes/k/in/pool-2121200@N24/
the photographer formerly known as 'Kallitype'
zoooming Senior Member • Posts: 2,746
I think the X20 will make a great second camera. Image quality will not be anything like the 5D, but the cam seems to be a gem and I am very tempted myself! But if you want to own just one camera, I'd say there are other alternativesI
Agree entirely - I'm often amazed by those seeking to replace an 'expensive' SLR body (eg 5DMKII $3k+ when new) with a compact around the $600 mark while seemingly not wanting to sacrifice image quality.
I have the 5DMKII as well as all the 1D series sports bodies and while I would never replace any of those bodies with an X20 I'm seriously considering getting one for a 'walkabout' body. The catch is it would only replace my G10 which has been great (bar the flash).
The difference in price/features in these type of exercises (1/5th of the price) is simply too great to be fair.
Zoooming
94
94 Senior Member • Posts: 1,041
Yes, very much so happy with X20!!
Quit worrying about details, save some of your money, and get over the ridiculous obsession with bokah (...feh) and resolve to buy the camera that will give you a fine collection of new family photos.
You'll miss some of your kid's best moments and a lot of great memories fretting over this nonsense. Fuji is making technological combinations in all of their cameras that are world beating great.
 94's gear list:94's gear list
Fujifilm X100T Canon EOS-1D Mark II N Canon EOS 5D Mark II Fujifilm X-Pro1 Fujifilm X-T1 +24 more
ScottD1964 Senior Member • Posts: 1,305
You're not going to have a lot of time.  Sunday to be precise.  B&H (and probably Adorama and any of the other reputable and Jewish run photo shops) close at 2PM on Friday for the Sabbath and are closed Saturday.  B&H is open 10-6 on Sunday then closed Monday 3/25- Wednesday 4/3 for Passover. Adoramam probably has hours that are much the same.
In any case I wish you luck with your camera decision and even more luck getting to B&H or Adorama to check them out and ultimately make a purchase.
Safe travels.
Scott
 ScottD1964's gear list:ScottD1964's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +3 more
PeterPrism
PeterPrism Senior Member • Posts: 1,060
I Agree 100%. +1
 PeterPrism's gear list:PeterPrism's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +1 more
dear 94. I took you up on the advice.
I want to have fun watching and recording my child and family.
I just bought an x20.
thank you for the good sense.
mr moonlight Senior Member • Posts: 1,781
Good decision. So many get hung up on details that are simply not important when they want a camera for just taking family photos. The smaller sensor on the X20 can be an advantage since you can get a wider DOF. Helps when shooting wide open to get a running child in focus.
I use a 5D and a bunch of heavy L-lenses for professional use, but when it comes to taking family photos or traveling, it's just too damn big and heavy. When it comes down to it, I have a ton of great photos and videos I've taken of my kid and family with my iPhone. Sometimes you want the razor thin DOF, perfect bokeh and mind blowing IQ, but most of the time you just need a camera that fits in your pocket that can capture all your most cherished memories.
HL48 Junior Member • Posts: 35
Will you be happy with the X20?  Wish I could answer that question for either you or me.
I used a slew of cameras in my youth. None were as much fun as the the Canonet 1.7 although many were far more expensive, and technically superior. The process of composing in a viewfinder uninterrupted while managing the mechanics of the exposure made for a delightful picture taking experience. Considering which compact camera will make for a more satisfying experience now, I am leaning toward the flexibility offered by the zoom lens of the X20 rather the image quality offered by the X100S's APS-C sized sensor.
Best of luck with your choice.
Harry
 HL48's gear list:HL48's gear list
Panasonic Lumix DMC-LX100
Nukunukoo
Nukunukoo Regular Member • Posts: 358
As a X20 owner, I'll give you both the short and long answer...
Short answer: Yes.
Long Answer: Yeeeeeeeeeeeeeeeeeeesssssssssh!
Hope that's helpful. Cheers!
Akoni
 Nukunukoo's gear list:Nukunukoo's gear list
Fujifilm X20 Nikon D300S Nikon D800E Nikon D7100 Sigma 50-150mm F2.8 EX DC APO OS HSM +4 more
