Sx50 "Reset all" not available?
Started Mar 19, 2013 | Questions
mantabay
New MemberPosts: 3
Mar 19, 2013
Hi can anyone help please, I am trying to restore the default settings on my SX50 and have done so before so I am familiar with the menu and procedure.
Unfortunately the menu item "Reset all"  though present is  unlit and can not be selected in any mode.
Any ideas much appreciated.
coody
Senior MemberPosts: 1,509
Re: Sx50 "Reset all" not available?
In reply to mantabay, Mar 19, 2013
Did you select the Tool with the wrench and hammer icon after press the menu button?
j2l3m7
Senior MemberPosts: 4,044Gear list
Page 157 in downloadable *.pdf
To clear information you have saved to <C1> or <C2> and restore default values, turn the mode dial to <C1> or <C2> and choose [Reset ALL]
Also see page 211.
Access the [Reset All] screen.
Choose [Reset All], and then press the Func Set button.
Default settings are now restored.
I hope this helps you.
Thanks for posting, have a great day.
John
 j2l3m7's gear list:j2l3m7's gear list
Canon EOS 70D Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot SX60 HS Canon EF 85mm f/1.8 USM +10 more
mantabay
New MemberPosts: 3
In reply to j2l3m7, Mar 20, 2013
That is not the Problem I have on many occasions  Reset the camera to the default and am very familiar with the the menus, and how it is done.
The problem is that the "Reset All" option  in the tools menu is unlit or to put it another way not highlighted and therefore unselectable. No matter what mode is selected c1,m,p or anything else.
It's a bit of a tricky one ie: why is "Reset All" visable but not selectable?  It may well have been locked out by another settings change but by what?
Many Thanks for all Replies and suggestions,
Tony B.
kd6vm
Regular MemberPosts: 303
In reply to mantabay, Mar 20, 2013
I remember on my SX-40 the "Reset All" was also greyed out when using the EVF, but was not when using the LCD screen.
c.hammett
Forum ProPosts: 11,821Gear list
Re: Agree with kd6vm - check EVF or LCD view ...
In reply to kd6vm, Mar 22, 2013
I just checked my SX40, and same here. Reset All is grayed out if EVF is in use, but is available when using LCD. So switch from EVF view to LCD and see if that fixes it.
carolyn
Ranger a.k.a chammett
http://www.pbase.com/chammett
'elegance is simplicity'
 c.hammett's gear list:c.hammett's gear list
Canon EOS Rebel SL1 Canon EF-S 18-135mm f/3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM
VisionLight
Senior MemberPosts: 3,599Gear list
Confirmed with SX50
In reply to c.hammett, Mar 22, 2013
Just confirmed the same with the SX50. "Reset All " is ONLY available on the LCD and is greyed out when using the EVF.
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
j2l3m7
In reply to mantabay, Mar 22, 2013
For information in TV mode.
Taken with the Canon SX40 HS, photo of Canon SX50 HS Menu.
John
CSPoole
Regular MemberPosts: 419Gear list
In reply to j2l3m7, Mar 22, 2013
John
You want to have some fun? Go up one level and change your language once. Then try to do a "Reset All" .
Thanks, CSPoole
 CSPoole's gear list:CSPoole's gear list
Canon PowerShot SX50 HS Canon EOS 550D Canon EOS 600D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM +5 more
j2l3m7
In reply to CSPoole, Mar 22, 2013
No thank you.
John
CSPoole
April Fools ! A little early !
Thanks, CSPoole
mantabay
New MemberPosts: 3
Re: Sx50 "Reset all" not available? Thanks kd6vm!
In reply to kd6vm, Mar 23, 2013
Awesome thank you very much!
As I wear glasses for reading and shoot surf photos out in the bright sun I rarely use the lcd screen spending most of my time squinting through the evf!
Many thanks to all who replied.
stevedg
New MemberPosts: 3
In reply to mantabay, May 20, 2014
Anyone know what gets reset when you do a reset?
I notcie the date and language remains the default. Is it just certain menu and function fields?
