Anyone else notice a major jump in centre sharpness f4 to f5.6 on the 24-105L?
Started Mar 17, 2013 | Discussions
robonrome
Senior MemberPosts: 1,836Gear list
Mar 17, 2013
Hi All, I've had the 24-105L for four years and it's my most used lens. Recently it developed the dreaded aperture circuit problem which seems to bedevil this lens once it matures - froze on apertures above F4 and had to get ribbon cable inside replaced...not cheap either.
Hadn't used it much since, but playing around today I started to notice it no longer appears as sharp in the centre wide open... sure there was always a deterioration in sharpness in the corners, but now I'm seeing a drammatic increase in sharpness moving from f4 to f5.6 and again to f8 in the centre. I've always felt in the past the lens was very sharp in the centre even at F4 at least not appreciably softer than at F5.6.
Wondering now if some lens elements may have got misaligned when the aperture problem was fixed... or maybe I'm just noticing something that was always there...since getting the 70-200 2.8 mk2 I confess to have a new standard for sharpness so maybe it's just me.
What's the prevailing view on the 24-105 ...do others notice a big difference in sharpness from F4 to F5.6 esp at the long end?
 robonrome's gear list:robonrome's gear list
Sony Cyber-shot DSC-RX100 III Olympus E-M1 Olympus E-M5 II Sony Alpha 7R II Canon EF 135mm f/2.0L USM +13 more
Panasonic Lumix DMC-F5
ASR45
Forum ProPosts: 34,346Gear list
Re: Anyone else notice a major jump in centre sharpness f4 to f5.6 on the 24-105L?
In reply to robonrome, Mar 17, 2013
Cannot say i have, but there again not used it much, but will keep an eye open for that one thanks.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +5 more
Gearóid Ó Laoi, Garry Lee
Veteran MemberPosts: 6,034Gear list
In reply to ASR45, Mar 17, 2013
I may have a very good version of the lens but I use it a lot.
This is one sample of lens at 58mm and F4. I don't hesistate to use this wide open doing the occasional wedding I do etc..
 Gearóid Ó Laoi, Garry Lee's gear list:Gearóid Ó Laoi, Garry Lee's gear list
Canon PowerShot S90 Fujifilm X10 Canon EOS-1Ds Mark III Panasonic Lumix DMC-G1 Canon EOS-1D Mark IV +25 more
rebel99
Veteran MemberPosts: 4,025
24-105mm f4 was my first "L" lens which infected me with "L" disease about 6-7 years ago i have never had any problem with it whatsoever and my lens is as sharp and well functioning as the day one and it is one of my most used lenses in my collection, although it may be surpassed in usage by my 17-40mm f4 real soon!
cheerz.
gfspencer
Contributing MemberPosts: 517Gear list
In reply to rebel99, Mar 17, 2013
rebel99 wrote:
24-105mm f4 was my first "L" lens which infected me with "L" disease about 6-7 years ago i have never had any problem with it whatsoever and my lens is as sharp and well functioning as the day one and it is one of my most used lenses in my collection.
cheerz.
Same here.
 gfspencer's gear list:gfspencer's gear list
Canon EOS 7D Canon EOS 6D Canon EF 50mm f/1.2L USM Canon EF 16-35mm f/2.8L II USM Canon EF 28-135mm f/3.5-5.6 IS USM +5 more
robonrome
Hmm this is making me think that perhaps something did get nudged when the aperture circuit was repaired.
Adza
Regular MemberPosts: 333
How much did they charge?
In reply to robonrome, Mar 18, 2013
Just curious as to how much they charged you for the repair?
sacentre
Senior MemberPosts: 1,563Gear list
Exactly the same thing happened to me. The aperture assembly failed and was repaired by Canon and ever since then, I've had the feeling that the lens doesn't seem as sharp anymore. It's hard to pin down. I'm now looking back at my before and after shots to see if I can spot any real difference.  Could be just imagining it and will know once I do some more test shots.
 sacentre's gear list:sacentre's gear list
Canon EOS 5D Mark II Canon EF 85mm f/1.2L II USM Canon EF 200mm f/2L IS USM Canon TS-E 17mm f/4L Canon EF 100mm f/2.8 Macro USM +5 more
robonrome
In reply to sacentre, Mar 18, 2013
Thanks let me know how u go. Mine still seems quite sharp at 5.6 and above, but f4 at longer focal lengths is a marked deterioration in sharpness.
robonrome
Re: How much did they charge?
In reply to Adza, Mar 19, 2013
I think it was $320au. .. about $300US
