K-30 manual mode question.
Started Mar 16, 2013 | Questions
jojo81
Regular MemberPosts: 120Gear list
Mar 16, 2013
I have the K -30 and the kit lens, I also have a couple of old manual focus lenses with built in aperture rings. (I can get exact models of it makes a difference) when I have the kit lens on I get full manual control of iso, shutter speed, and aperture.  When I use an old lens the camera will only go into A mode, even if I select T or M it still says 'A'.
So i can select the aperture and the iso but not the shutter speed. Is this normal, or am I doing something wrong, is there a setting I can change in the menus to get full control back?
Thanks, Jo Jo.
 jojo81's gear list:jojo81's gear list
Pentax K-30 Sigma 120-400mm F4.5-5.6 DG OS HSM Pentax smc DA 18-55mm F3.5-5.6 AL WR +2 more
Ian Leach
Senior MemberPosts: 1,365
Re: K-30 manual mode question.
In reply to jojo81, Mar 16, 2013
I don’t know if it is your problem but I recently had issues because I was in auto-iso. The camera will revert to AV even if it is set to Manual. So you may need to fix the iso to one value.
mike703
Veteran MemberPosts: 6,379
There is a menu option to 'enable aperture ring' which needs to be set to 'Yes'.
Once you have done that you do the following:
set focus to manual
set exposure to manual
select aperture
compose / focus your shot
press green button - this stops down the lens briefly and sets the correct shutter speed based on the aperture / ISO you have chosen
take picture.
There are more detailed descriptions of how to do this around - I'll see if I can find one.
Best wishes
mike703
In reply to mike703, Mar 16, 2013
Here's one - more or less what I thought - this one is for a K5 not a K30 but same principle.  Good luck
http://forums.dpreview.com/forums/post/51008485
jojo81
jojo81 OP
In reply to Ian Leach, Mar 17, 2013
Thanks Ian, I'll check that out.
