Is Waterproof Dustproof too?
Started Mar 16, 2013 | Questions
MickeyWickey New Member • Posts: 3
I am not a professional photographer. I work in a dusty environment. We need to take lots of pictures every day with several different cameras. Most of the waterproof point and shoots look like they have dinky little lenses. A year or so ago I remember seeing a Canon camera at a club store that had "dustproof" as a feature but I'm having little luck finding it again.
Are the waterproof cameras generally considered to be dustproof as well? Are there any "prosumer" level cameras with the dustproof feature that you know of?
Thanks for any assistance.
-Mickey
 MickeyWickey's gear list:MickeyWickey's gear list
Sony Cyber-shot DSC-F717
Robert Anderson Senior Member • Posts: 2,261
Re: Is Waterproof Dustproof too?
The waterproof P&S models are also considered dust proof. None of them have very good image quality compared to prosumer models. All have small sensors and folded optical systems. Most have over aggressive noise reduction. A prosumer model in an underwater housing would do a better job.
MickeyWickey OP New Member • Posts: 3
Thank you. That's actually a good idea, and I can test it right away with my Canon G9 and the underwater housing that I really never used.
I also saw this one in doing more searching around:
http://www.dpreview.com/news/2012/02/08/Olympus_OM-D_E-M5_announced
which touts weather sealing. Wonder if it's enough for the fine dust I'm trying to avoid. I don't expect we'll be changing lenses often, and if we do, it would be in the showroom area, not in the dusty production area.
glasswave Veteran Member • Posts: 8,658
Re:Waterproof vs. water resistant vs dustproof...
Don't forget splash proof or weather sealed.
These marketing claims are not regulated by standards. What one company markets as water proof may only qualify as water resistant by another.
As far as industry marketing goes it would basically go:
1. Waterproof
2. Water Resistant/ weather sealed
3. Splash proof
4. Dust proof
Waterproof is only a fuction of pressure. Water can cut through 1" plate steel given adequate pressure. Most quality "waterproof" will be advertised to a certain depth, indicating how much pressure they can take.
Water resistant should mean that the product could be briefly submerged. It should have rubber seals on most buttons and doors.
Splash Proof should mean that the product could be handled and used in rainy weather for an extended period.
Most manufacturers don't allow warranty claim for water damage unless the product is marketed as water proof.
Dust is different than water in that it is abrasive. This is a whole nother ball of wax. Waterproof/waether sealed cameras will be must more dust resistant than their non sealed counter parts.
For a camera that is always in a dusty enviroment, I would recommend to keep up on your maintenance. Blow it off with air after each use. Use cleaning brushes often and use camera detailing methods frequently.
Use lens air/cloths/paper/solutions to clean your glass clean. The Canon 60d & 7d are SLR's in the prosumer range w/weather proofing as are most others to some degree.
There is simply too much beauty in the world to photograph it all, but I'm trying.
Fave Photog Senior Member • Posts: 1,241
Reason on the matter for a moment:  Which is larger, a dust particle or a molecule of water?  Correct, so if a camera/lens can seal out water, then it has to be able to seal out larger dust particles.
The Five 'Ps' of Photography:
*Proper Planning Prevents Poor Performance!*
edu T Senior Member • Posts: 1,174
But think (or drink or bath in) water in the usual sense, not as vapor or air humidity: it doesn't come in loosely scattered individual molecules.
So reason on the matter just another moment: which is larger, a speck of dust or a water droplet?
 edu T's gear list:edu T's gear list
Fujifilm FinePix F550 EXR
The last time I checked, water exists in three forms:  Solid (ice); liquid; gas (vapor).
Then you should have no worries about setting your unsealed camera and lens out on the back porch the next time it rains, since according to your 'reasoning' there is no way that an object the size of a raindrop could fit through any of the many miniscule cracks or openings in a camera/lens.
Taking your 'reasoning' one step further, a bucket of water is much larger in size than a mere drop of water.  And, since, according to you, a drop of water is too large to enter the tiny cracks and crevices of a camera or lens, then certainly there is ​no​ way that the even larger body of water found in the bucket could do so, you should happily and confidently drop your camera/lens into said bucket.
No?  Oh, OK.
happypoppeye
happypoppeye Veteran Member • Posts: 3,874
Yes ...waterproof is dustproof also ...just be careful opening a really dusty camera because everytime you do open the door dust gets in ...maybe just wash the camera off before opening up the door when really dusty.
 happypoppeye's gear list:happypoppeye's gear list
Panasonic Lumix DMC-TS30 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS
Yeah, I hadn't thought about all the various water designations.
We are careful to only operate the camera where it's dusty and move out to the office and showroom areas where it's clean (even a different air system) to change SD cards, bateries, etc.
I tried my underwater housing with my G9, and found it was too awkward to operate. Two different people dropped it!
I'm currently going to try the Olympus Stylus TG-2. Though the optics aren't as nice, the lens is faster than any other rugged cameras I could find and they chat up the dustproofiness. I'll have a real good test of that attribute shortly!
Thanks for the insight, it's appreciated.
Mickey
