Kyocera Finecam L3V review
Started Aug 28, 2003 | User reviews
Ovinator New Member • Posts: 2
pros:
- great display (size and quality)
- 3 MP cam has better pictures than 4 MP with same resolution (because same ccd size - the 4MP has closer pixel position -> more (color) noise)
Problems:
one big pro is, that one can use it with aa-rechargables, but:
cons:
- you need a high voltage rechargeable battery-pack and a recharger with good delta-u behavior. when your akku has less then 1.4 volts the cam says: low battery. with my normal mignon-akkumulators, which have 1.35 after charging, i can only work about 5 minutes.
kyocera says, late 2003 there will come a special battery-pack with own rechargestation.
Kyocera Finecam L3V
3 megapixels • 2.5 screen • 38 – 115 mm (3×)
Announced: Mar 2, 2003
Ovinator's score
4.1
Average community score
4.2
