Ricoh Caplio GX8 review
Started Aug 18, 2005 | User reviews
smecrow Forum Member • Posts: 54
Good solid construction and relatively simple to use. Lens is sharp and has a wide angle equivalent of 28mm - very useful.
Image quality is very good at low ISO levels - 100 and 64. Noise is evident at 200 and above - but can be reduced using post processing to acceptable levels.
NiMH AAs are OK - but the camera performance is far better when using the optional lithium battery - available on ebay for less than £10 - but you will need a charger.
Problems:
No major problems so far.
 smecrow's gear list:smecrow's gear list
Sony SLT-A65 Sony Alpha NEX-3N Sony DT 11-18mm F4.5-5.6 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro +6 more
Ricoh Caplio GX8
8 megapixels • 1.8 screen • 28 – 85 mm (3×)
Announced: Apr 26, 2005
smecrow's score
4.3
Average community score
4.2
