Fujifilm FinePix S1600 / Fujifilm FinePix S1770 review
Started Jun 19, 2010 | User reviews
demarren 123 Veteran Member • Posts: 3,616
Exelent longzoom camera,but need alot of light.
Image qalitie is good,however alot of noise reduction is aplied to the pictures even at ISO 64
for close shots,people,objects it is not an problem,but for landscape thads another story.
The camera focus is to slow to take sport pictures.By the time you get an focus lock,the object is gone.
The FZ35 is alot faster,however cost double.
The S-1600 is capable of exelent pictures as long you stay at ISO 64-100 abouve thad detail is alraidy gone.
But you get smoot pictures in low iso,and the colors are great.
Also the camera is sharper then the panasonic output.
but the pictures detail is alot more then on the panasonic.
Ok there is some noise in FZ-35 even at lowes iso but detail is mush better.
This Fuji perform verry wel in good light.
but everything is sayed,not good in lower light.
The lcd and viewfinder is exelent for sutch an low cost camera,and batterie live seem to last forever.
The lens is exelent,but at 27 Mm the right side get blurie however CA is verry low,almost not existend,but at 27 mm there is some corner softness visible ,somtimes in bad wether visible at normal view on your monitor,things get better in good light.
Abouve ISO 200 the camera pictures are of low qalitie,noise reduction is so high,thad detail is lost,and there is no raw on the camera,nor anny noise settings.
Video is also not the strong point of this camera,it is good in good light,and thads it,however you can zoom while recording.
Iff you stay at ISO 64 as long as possible the pictures are good,somtimes even exelent,and for $ 150 you wil not find anny camera thad to better.
the biggest problem is thad the camera is slow,when you try to capture for example birds,it is simple not possible to get an bird in focus,exept if the bird sit still.
The camera is limit to statics pictures,then it perform verry wel.
Wat I found.
1.Exelent qalitie pictures of static objects,at lowest ISO
2.good LCD and viewfinder.
3.long batterie live.
4.verry portable.
5.easy in use.
6.good flash pictures
7.F button is welcome.
Problems:
Not so good.
1.wierd structure of menus.
2.when viewing an picture you have to press the shutter button.
3.High ISO is an joke.
4.To slow for moving objects.
5.Wierd power button,slide to start up,Slide to stop
6.control dials having wierd options.
7.No viewfinder diopter.
8.movie mode not great.
 demarren 123's gear list:demarren 123's gear list
Olympus E-10 Sony Cyber-shot DSC-HX100V Fujifilm X10 Nikon Coolpix P7700 Panasonic Lumix DMC-LX100 +10 more
FujiFilm FinePix S1600 (FinePix S1770)
12 megapixels • 3 screen • 28 – 420 mm (15×)
Announced: Feb 2, 2010
demarren 123's score
4.5
Average community score
3.8
