AF Fix Using Free Software
Started May 27, 2012 | User reviews
dnguyen
New MemberPosts: 4
May 27, 2012
Barry Fitzgerald's review is spot on. Currently own the K2000 and the K-r is a vast improvement.
Problems:
From the factory, the K-r front focusing was really bad (tested 3 lens: 18-55mm f3.5-5.6, 28-90mm f3.5-5.6, and 35mm f2.4). I had to AF Fine Adjust to -10. I then found a nifty app called PK_Tether, which allows you to put Pentax cameras (K-x, K7, K5, K-r, K20D, K10D, K200) into debug mode. That enables you to get to the Debug menu and do AF calibration. I am not sure what the max is but I went as high as -19. You would want to reset the AF Fine Adjustment to 0 before using the calibration. That way you can do fine adjustment from the calibrated setting.
Other than the front focusing issue, the K-r could use the individual AF fine adjustment setting for up to 20 lens feature available on the K7 and K5.
dnguyen's score
4.5
Average community score
3.7
Pentax K10D Pentax K20D Pentax K-5 Pentax K-7 Pentax K-m (K2000) Pentax K-r
