Overexposes
Started Nov 21, 2012 | User reviews
seekr
New MemberPosts: 17
Overexposes
Nov 21, 2012
I was impressed with the build quality, solidity and sharpness.
But, used with my Nikon D90, every image was very overexposed, whether with the built-in flash, SB-400 flash or without flash. Regardless of the many various settings I tried, images were badly overexposed. I have other Nikon brand lenses, both from my old Nikon film SLR days, (28-105mm) as well as the 18-55 and 55-200 kit lenses, and the 85mm micro. They all exposed properly, taking as close to identical comparison photos from a tripod as I could. I guess could have dialed in a negative compensation when using the lens, but then I'd have to remember to recorrect for other lenses.
Tokina's US rep suggested sending it to them for inspection, as they said they had not heard of this problem. As I recall, the EXIF data f-stop and speed set by the camera were pretty well matched to those of the other lenses, but the resulting images were not.
I just returned it to the retailer, and purchased the Nikon 40mm micro. Exposures are now spot on.
seekr's score
1.5
Average community score
3.3
Nikon D90
dfrnz
New MemberPosts: 2
Re: Overexposes
In reply to seekr, May 30, 2013
Overexposure has nothing to do with the lens. That can be fixed in-camera.
skidMark
New MemberPosts: 10
Re: Overexposes
I am using that as my main lens on a D3100 which means I have to manually focus and do so willingly...because it is that good.
Randy Benter
Veteran MemberPosts: 3,113Gear list
Re: Overexposes
In reply to dfrnz, Jun 4, 2013
That is not true. Correct exposure is dependent on proper functioning of the lens. The aperture setting is half the exposure equation. If the aperture blades are stuck in the open position, then many shots will be overexposed.
 Randy Benter's gear list:Randy Benter's gear list
Fujifilm X100T Fujifilm X-T10 Nikon D7200 Carl Zeiss Touit 1.8/32 Apple Aperture +18 more
