Reviews, hands-on, samples of HS50 Part V
Started Mar 15, 2013 | Discussions
alexisgreat Veteran Member • Posts: 6,459
Re: For Michi and others who have the HS50
Could you kindly test L size DR 400 vs M size DR 400 with the HS50, now with the HS20 I have been getting consistently better highlight retention with L size DR 400 rather than the latter, more commonly acclaimed M size DR 400. Also, as far as higher ISO differences between the two resolutions, I know people say M size is better, but when I resize both M and L size to 1600 x 1200 I cant see a difference, even at ISO 3200- they look almost exactly alike, it's just that L size seems to retain highlights better than M size for some reason (at DR 400). NR should be set to Low and Sharpening to Soft.
Basically I did L size DR 400 ISO 3200 vs M size DR 400 ISO 3200 NR Low Sharpening Soft and found that L size DR 400 held highlights better and there was virtually no noise difference when both were resized to 1600 x 1200 (which matches the dot pitch of 7.5 x 10 prints.)
http://Alex_the_GREAT.photoshop.com
 alexisgreat's gear list:alexisgreat's gear list
Olympus C-7070 Wide Zoom Fujifilm FinePix HS20 EXR Fujifilm FinePix HS50 EXR Olympus E-520 Olympus PEN E-PL6 +3 more
jcmarfilph OP Veteran Member • Posts: 7,592
There you go Alex. One reason why I don't consider myself EXR lunatic lol.
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
