sb-700 coloured filters
Started Mar 14, 2013 | Discussions
hwg
hwg Contributing Member • Posts: 535
If I ever find anywhere to buy the sz-3 filter holder - Nikon don't have any! They have given me some dealers to try.
I will experiment with it.
The sb-700 user manual states if I put a coloured filter on it I can then tell the flash what colour filter I am using.
WHY???
why does it need to know I have put a yellow filter on it?
I want it to flash yellow (or whatever)
I don't want it trying to neutralise the colour by doing some fancy stuff to the white balance of other settings so what is the purpose of telling the flash it has a yellow filter on it?
Patco
Patco Forum Pro • Posts: 12,060
Re: sb-700 coloured filters
WHY???
Perhaps in non-TTL mode the flash needs to know how much boost to apply to compensate for the loss of light, which will vary according to colour?
Patco
A photograph is more than a bunch of pixels
hwg
hwg OP Contributing Member • Posts: 535
but doesn't the TTL computer work this out as it is measuring the light that is actually hitting the sesnsor?
Patco
Yes, but I said it might need to know this info for "non-TTL" mode.  For example, if you were to set the flash for 1/64 output, it will not reach that level with a colour filter attached, and might compensate according to which filter is mounted.  Just speculation, though, as I don't have this flash.
Patco
hwg
I see...
i am going to experiment with my
new kit this weekend so i will see what differences the various settings do.
sshoihet
sshoihet Senior Member • Posts: 2,538
WHY???
As you noted, the purpose is to set the white balance to the temp of the filter because you generally want the temp to match the subject that you're lighting with the flash.
 sshoihet's gear list:sshoihet's gear list
Canon PowerShot S95 Nikon D7000 Canon EOS M Nikon D600 Nikon D7100 +14 more
Patco
WHY???
Actually, the purpose of the SJ-4 Color Filter Set seems to be to "Create interesting effects by changing the color of the light emitted by the flash" (SB-700 manual, page E-17), so I'm not sure neutralizing the effect one is trying to create would produce the desired result. The incandescent & fluorescent filters are entirely another matter.
Perhaps by telling the flash it has an "effect" filter (yellow, blue, etc.), the camera's auto WB will alter or cancel its correction for that specific color? Like I said in another post, this is just speculation, as I don't have this flash
Patco
