Anyone try new NIKKOR 18-35mm f/3.5-4.5G on D800
Started Mar 14, 2013 | Discussions
HankK
Regular MemberPosts: 389
Mar 14, 2013
As anyone tried the new NIKKOR 18-35mm f/3.5-4.5G on the D800.  I am looking for lighter weight wide zoom for shooting building exteriors and interiors.   I usually shoot at f8-f11.  I was hoping that this lens might be sharp enough to the edges, at least at these f stops.
Hank K
Nikon D800E, Fuji XE-1, Samsung NX20 (former 5DM2, RX100, GH2 Kit, and Fujifilm X100 shooter)
Nikon D800
Todd Jones
Contributing MemberPosts: 645Gear list
Re: Anyone try new NIKKOR 18-35mm f/3.5-4.5G on D800
In reply to HankK, Mar 14, 2013
I'd be interested as well. There just isn't to much info on this lens yet, but I would be using it at wider apertures on a D700.
 Todd Jones's gear list:Todd Jones's gear list
Nikon D810 Tokina AT-X Pro 100mm f/2.8 Macro Carl Zeiss Distagon T* 2/35 Nikon AF-S Nikkor 70-200mm f/4G ED VR Nikon AF-S Nikkor 20mm f/1.8G ED
BackPacker1532
Regular MemberPosts: 108Gear list
I would suggest that on that specific camera, you will be wasting the camera's ability.  For that camera you need GOOD glass to make use of the 35mp not wehat is more like a kit lens
 BackPacker1532's gear list:BackPacker1532's gear list
Nikon D3 Leica S2
Mike Wilcox
Forum MemberPosts: 85Gear list
Mine just shipped.  I will post a review of it as soon as I have a chance to check it out.  This lens was what I was looking for in terms of weight, angle of view and size.  I fully expect it will be optically good but won't know that until I use it.  Most of my photography is on a tripod at optimal apertures so I get good performance out of most lenses.  Coming from Pentax, the 12-24 was my most used lens so this on the D600 should be virtually identical.  I considered the 16-35 Nikkor and the 16-28 Tokina but was put off by size and weight and in the case of Nikkor, size, weight, filter size and cost. I try not to get hung up on other people's opinion of what is "good glass".  My most used kit is 20mm f/2.8 Nikkor, 50 f/1.8 Nikkor and 100 f/2.8 Tokina Macro.  I also have and am very pleased with the 24-85 "kit" lens.
www.openshadowsphotography.com
footlong
Regular MemberPosts: 195
In reply to BackPacker1532, Mar 14, 2013
That's a myth
shaunly
Contributing MemberPosts: 526
Too much forum reading.... not enough real life experience.
jfk
jfk
Senior MemberPosts: 2,966
M35G35
Regular MemberPosts: 222Gear list
In reply to HankK, Mar 15, 2013
 M35G35's gear list:M35G35's gear list
Nikon D800E Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR +14 more
GlobalGuyUSA
Senior MemberPosts: 1,683Gear list
In reply to BackPacker1532, Mar 15, 2013
This is not true as many D800 owners are attesting for even older lenses and non-primes, non-gold teles. And doubly not true the way that consumers actually use the D800, by compressing images into much smaller jpegs.
Megapixels are not that interesting to me. High ISO is (or effective ISO when compressed). I would be much more concerned about this being a dark, variable aperture lens than its resolution ability on a D800 (although that is the cost of a light, low-cost lens, which are pluses in their own right).
Far more important is "how does it handle low-light and shake" than the MPs.
Sincerely, GlobalGuyUSA
 GlobalGuyUSA's gear list:GlobalGuyUSA's gear list
Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Nikkor 20mm f/2.8D Nikon AF Nikkor 50mm f/1.8D Nikon AF Nikkor 135mm f/2D DC +4 more
Ernie Misner
Senior MemberPosts: 2,303Gear list
In reply to GlobalGuyUSA, Mar 15, 2013
There's already  the 16-35 and the older 17-35.    So just curious, if not an optical improvement what would be benefit of this new lens be?    Just cost and weight?    Thanks!
Mike Wilcox
In reply to HankK, Mar 20, 2013
Just got my lens.  Took it out in the back and shot the fence at most apertures and focal lengths.
Physical - Incredibly light and reasonably compact.  Very similar to the 24-85 but slightly lighter. 77mm filter size which is nice.
Optically:
Sharpness: Excellent at all focal lengths from f/3.5 (f/4.5 at 35) to f/11 with f/5.6 seeming to be the best on my sample.
Distortion: Very little noticed but haven't really checked this out yet.  Definitely the least barrel distortion of any super-wide I have ever owned. No correction for distortion or CA on these samples.
CA: slight at edge of frame but easily corrected.
Below is a link to 4 full size jpegs with just normal sharpening and curves adjustment out of LR. Shot with D600.  I only provided 18mm and 35mm at wide open and f/5.6 as everything else upt f/11 is pretty much the same.  F/16 and smaller is good but starts to fall off a bit due to refraction.
Best Nikkor I have shot with.  All shots with D600 at iso 100 on tripod. This is the lens that will stay on the camera.
http://www.openshadowsphotography.com/Other/Nikon-18-35G/28514510_h2qvGd#!i=2416561209&k=ttVXpfX&lb=1&s=A
Lasse Eisele
Senior MemberPosts: 1,680
Thanks!
In reply to Mike Wilcox, Mar 20, 2013
Optically:
Very encouraging report! This lens would be perfect for my needs if edge performance is good enough at f/8-11.
reginalddwight
Senior MemberPosts: 2,003Gear list
Outperforms 14-24/2.8G?
Thank you for sharing your preliminary impressions.
Outperforms the venerable reference standard, 14-24mm/2.8G?
jfk
jfk
Re: Outperforms 14-24/2.8G?
In reply to reginalddwight, Mar 20, 2013
Haven't had much time to use it, but so far 'very sharp' with maybe just a slight bit of softening in the corners wide open that pretty much disappears by f8.  Tiny bit of CA along some edges that clears up easily.  Much better than the original 18-35 afd!
Very impressed so far.
jfk
reginalddwight
In reply to jfk, Mar 20, 2013
Congratulations on your new lens. I may need to rent this lens and put it through its paces myself. The 14-24 is a brilliant lens but sometimes more than what I want to carry around. I had the 16-35/4 but wasn't too impressed. I am looking for something lighter. This new lens may fit the bill.
ageha
Contributing MemberPosts: 651Gear list
check these out.
http://www.nikoncafe.com/vforums/showthread.php?t=355678
jfk
You need an account for it to work.
 ageha's gear list:ageha's gear list
Sony Cyber-shot DSC-TX10 Sony Alpha DSLR-A390 Panasonic Lumix DMC-GH2 Nikon 1 V1 Nikon D600 +17 more
ageha
Optically:
Looking good.
moony16
Regular MemberPosts: 434
Optically:
Who looks outside,
dreams; who looks
inside, awakens
Carl Jung (1875-1961)
tabila117
Forum MemberPosts: 54Gear list
In reply to moony16, Mar 20, 2013
Very interested to get more information on this lens. My Nikkor 17-35mm f/2.8 is not so good on my D800. Would be very interested to get something lighter with some more sharpness on the sides and corners.
My blog (in french):
http://www.photogeek.fr/
 tabila117's gear list:tabila117's gear list
Fujifilm X-T1
Mike Wilcox
Don't know. I have never shot with that lens. Probaby not at 14mm and f/2.8
