Canon 6D and Tamron 24-70
Started Mar 12, 2013 | Discussions
Coolhandchuck
Coolhandchuck New Member • Posts: 3
Not only am I having a ridiculous battery drain, but I am also having a metadata issue. When I go in to check my metadata, the camera has recorded the wrong info into the image file. I used a Tamron 24-70mm f/2.8 VC USD for the shots, but it says that I used a a Sigma 24-70mm f/2.8 IF EX HSM. I called Canon and they had no clue other than it must have been a communication error between the lens and the camera. No, really....? I know that people have been having battery issues, but has anyone had a metadata problem?
 Coolhandchuck's gear list:Coolhandchuck's gear list
Canon EOS 500D Canon EOS 6D Canon EF 50mm f/1.8 II Tamron SP 24-70mm F2.8 Di VC USD Tamron SP 70-200mm F/2.8 Di VC USD +4 more
Canon EOS 6D
bakewell Forum Member • Posts: 89
Re: Canon 6D and Tamron 24-70
The camera reports 24-70 on it's menu. In LR under lens corrections/make click the drop-down and pick Tamron. The correct lens will be inserted.
 bakewell's gear list:bakewell's gear list
Canon EOS 80D Tamron SP 70-200mm F/2.8 Di VC USD Canon EF 35mm f/2 IS USM Canon EF 24-70mm f/4L IS USM Canon EF 16-35mm f/4L IS USM
William DIllard Senior Member • Posts: 2,481
Are you keeping yor VC turned on. I heard that will affect the battery.
 William DIllard's gear list:William DIllard's gear list
Tokina AF-X Pro 16-50mm f/2.8 DX
ASR45
ASR45 Forum Pro • Posts: 34,976
Thats what its there for, should have no deppramental effect me thinks.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
MisterBG Veteran Member • Posts: 5,823
Based on other discussions on these forums, I believe there is a fix for this problem.
You need to return the lens to Tamron for a firmware update.
>The only way of discovering the limits of the possible is to venture a little way past them into the impossible.
dave_bass5
dave_bass5 Veteran Member • Posts: 6,208
Yes, there seem to be a battery drain issue with this lens and the 6D. It seems like its just early batches and Tamron are aware of it.
As for the Exif, I too found that LR reports it as a Sigma. Once you change the Lens correction over to Tamron set this as the lens default and you wont need to do it again.
 dave_bass5's gear list:dave_bass5's gear list
Canon EOS 5D Mark III Sony a6000 Canon EF 135mm f/2.0L USM Canon EF 24-70mm f/2.8L II USM Canon EF 35mm f/2 IS USM +10 more
