Has anybody seen the starr comet in the northern hemisfere
Started Mar 12, 2013 | Discussions
fotosplaneta New Member • Posts: 19
Do you know which are the best camera settings that are necessary to picture this comet which it appears very low in the horizon and in the glow of the sunset. Furthermore, in the case in question it is necessary to take into account the glow of city lights. That is, which are the ideal aperture, iso, and shutter speed to get a good photo.  Besides of the best focal length required to get a decent size of the comet´s tail.
Regards
http://www.flickr.com/photos/fotosplaneta
Mark Scott Abeln Veteran Member • Posts: 7,800
No
I didn’t see it, since weather here has been overcast the past several days. Perhaps tonight might be good.
Anything longer than a 15 second exposure time for a normal lens will produce visible trails from the rotation of the earth. For longer lenses, shorter exposures will be needed for this, and so you might have to boost your ISO.
Since I assume you are using a digital camera, then you should not worry too much about exposure, since you can immediately check your histograms and image afterwards.
If you underexpose the image a bit, you will retain the color of the stars, which are usually overexposed in many astronomical photos.
However, the comet will only be visible right after sunset, and so there will be extensive sky light. In this case, automatic exposure might give you good results.
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF Nikkor 50mm f/1.8D +1 more
Wildbegonia
Wildbegonia Regular Member • Posts: 472
Re: Has anybody seen the starr comet in the northern hemisfere
Regards
Nope! We do not pay enough taxes up here in the northeast coast of North America to get that kind of celestial show!
"There is a crack in everything, that's how the light gets in" Leonard Cohen
dsjtecserv Veteran Member • Posts: 3,113
Here's one posted from the LA area from last night:
http://www.fredmiranda.com/forum/topic/1196612
Dave
 dsjtecserv's gear list:dsjtecserv's gear list
Canon EOS 5DS R Canon EF 17-40mm f/4.0L USM Canon EF 100mm f/2.8L Macro IS USM Canon TS-E 24mm f/3.5L II Canon EF 24-105mm f/4L IS USM +4 more
johnznyc Regular Member • Posts: 127
I tried to get a shot Sunday night from the Top of the Rock.  Unfortunately, certain tourists did not  the time change and sunset became overly crowded and I missed the window.
I will try again Thursday at sunset...
OpticsEngineer Senior Member • Posts: 4,548
comet visible in NA
It was visible naked eye in New Mexico this evening.  Here a couple of handheld shots from my Sony A65  18-135 mm lens.  I was out taking pictures of my dogs and kids at twilight at the park when one of the other dog walkers reminded us about comet.  So  a few of us waited until if finally appeared, dimly, but clearly visible if someone could point out to you where to look.
sony a65, comet is small smudge in center of image
sony a65
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Sony Alpha NEX-7 +21 more
Placation101 Regular Member • Posts: 455
Regards
Really depends how high in the sky you are able to locate it and how much haze. while it should get brighter as it gets darker it is so low that as it moves down in the sky eventually haze may obscure it. My best recommendation is a nice set of binoculars to find it immediately when it comes into view. look roughly above where the sun set. I set my focus on very distant clouds while the sun was still setting to avoid refocusing. I had to go all the way up to the local mountains here to get a clean Shot.
Iso, when it first came out I was shooting 100, 800 by the time it was all the way down.
If you followed the Fred Miranda link above you will see that the head of the comet is conical. The real shape is spherical. To best capture the true comet shape I observed keep the exposure under two seconds. At first I was able to keep it well under two seconds by the end in the haze it was much longer and the shape began looking worse in my opinion, more conical. Better to get a conical comet than none at all.
Dont need to worry really about city lights I don't think? Avoid them if possible.
shoot raw for noise removal.
i used a 300mm f/4 +1.4tc. f stop f/5.6-f/8 mostly 5.6. still pretty small in frame.
if you locate the comet early you should have plenty of time to adjust settings. Nobody will be able to give you the exact settings because conditions will vary and then vary again from sun setting. This is your chance to prove you can Quickly adjust. As long as you get one frame containing the comet you will be able to adjust exposure accordingly.
tomorrow is supposed to be a nice moon and comet photo op. however its not gonna really be easy to expose the moon and comet both properly so...
answering the OPs question
That was a better post than mine in terms of answering the OPs question.
The post below showed a good result on a Sony A99.   For a good picture, lower ISO and longer exposure time and a tripod is certainly better than my handheld shot.
http://forums.dpreview.com/forums/thread/3400196
And of course a fast long focal length lens would be a big help.  But it is still worth taking a picture even with something like a standard 55-300 zoom lens even if it is as slow as f/6.3 fully zoomed out.
From the time the sky became dark enough to see the comet,  knowing where to look, to when it disappeared into the dust in the sky toward the horizon, was about 15 minutes for us tonight.  So you do need to have a good idea of what settings you want to try.  Also, for my 1/20th second shots, the comet was not visible in the camera display.  I knew where to point the camera based on seeing where it was with my naked eye relative to the moon.  I just took a few shots and hoped the comet would be visible when I downloaded the image onto the computer, which it was.
I should say that all of the shots I took that came out to my satisfaction were reasonably close to properly exposed.  try and shoot for a sky that looks approximately like every picture you see online.
fotosplaneta OP New Member • Posts: 19
Thanks everyone for all the answers.  Unfortunately it has been unusually cloudy during the past few days in a way that not even the moon was visible.  It is very strange the overcast conditions in this time of the year (rainy season is in the summer). However, it seems that the comet could still be photographed in the next few days using enough exposure time (hoping the clouds allow such implementation).
Cheers
http://www.flickr.com/photos/fotosplaneta/
CuriousMark Forum Member • Posts: 55
Re: Has anybody seen the starr comet in the northern hemisphere
You may want to check out several threads on Pan STARRS over in the Astrophotography forum area here.  Lots of discussions on what settings were used for the various shots taken and posted there from different countries and different parts of the US.
 CuriousMark's gear list:CuriousMark's gear list
Nikon D5000 Nikon AF-S DX Nikkor 35mm f/1.8G Tamron 18-270mm F/3.5-6.3 Di II VC PZD Nikon AF-S Nikkor 50mm f/1.8G Adobe Photoshop Lightroom 3 +4 more
