Just picked up an Oly XZ-2
Started Mar 12, 2013 | Discussions
Ivo Verhaar
Ivo Verhaar Regular Member • Posts: 346
Re: focus issues
not narrow dear, fleebay standard, i have the same searching on ebay.nl it will not show us,uk,nl all the time...
And i am pretty sure i will have lots of fun with the XZ-2, Hmmm now saving for a UW housing for snorkling fun, or stick with my old model tgh..
Olympus: E-3, 12-60SWD, EX25,EC20, FL50R, 50-200SWD, XZ-2.
Thinktank: Rotation 360, Change Up, some modules
http://www.flickr.com/photos/iverhaar
 Ivo Verhaar's gear list:Ivo Verhaar's gear list
Konica Minolta DiMAGE A2 Olympus Stylus 720 SW Olympus XZ-2 iHS Olympus E-3 Olympus E-M1 +6 more
Ivo Verhaar
Re: focus issues
The new toy is in the house..
first glance a bit more beefy as expected, but still pocketable.
Wow love the screen wish my E-3 had such a great screen, ok will wait untill E-M7/E-7...
Does it misfocus from time to time indoors yes it does, but so does my E-3.
charging in camera is new, will search if my mju charger will work, gives me some options.
Need to getting used to the menu structure, so far deleting is a bit of a pita..
So far i do not think it has any real issues. Will give a lot of joy
judith1600 OP Contributing Member • Posts: 651
Re: focus issues
I hope you enjoy it, Ivo.  Yes, there is no "mass delete" that I could find so I have had to mark my deletions in CS4 and do it there.  It does miss focus the odd time but is surprisingly accurate most of the rest.  It does quite well with my non-stop wriggling infant grandson, though
Will look forward to your test shots.
Judith
 judith1600's gear list:judith1600's gear list
Leica D-LUX 4 Olympus XZ-2 iHS Pentax K-5 Pentax K-5 IIs Olympus E-M1 +16 more
Ivo Verhaar
Multi delete..
ROFL will give the dog a try for its fast focus. interior shots are just mucking around...
but i have found a multiple delete function...
press play, toggle wide (this will give you an overview), mark photos with REC, next photo can be done by using the navigation wheel on the back. mark next etc etc, press ok, select delete and they are gone..
Note: in one of the menus you can find the option for a 4x4, 9x9 or bigger matrix under wide.
only thing i had i marked a photo to be not deletable (lock) and the only way to remove that was formatting, i was unable to remove the lock?
And i understood you could do in camera effects on raw files, not that important, but was not able to do it...
Someone wrote that focussing under 30cm, super macro? disabled the flash completely, afaik it keeps on firing up to 1cm, however! it will not be of much use without a bounce card reflecting it back to the front of the lens. Same issue as my slr, but probably have to solve it the same way (transparant matte reflector on 45 degree angle between subject and flash) Or use a wireless flash
Oh and i have version 1.0 inside...
Still a great piece of pleasure
Ok now back to my acupuncture study....
Re: Multi delete..
Card Setup in Menu allows for mass delete.  You can format or delete using that function.
pablolie Contributing Member • Posts: 635
Re: focus issues
I did experience major focus issues initially, but I am not sure if it's adjustments I made in my shooting or in the camera configuration that turned my experience into yours: a few situations where I (and the camera, we are a team) struggle to get focus. In that case, the fantastic manual focus lever is my friend.
I also very much like the fact you don't discount other users' experiences - given my initial experience, nor do I.
I do believe the focus issues stem from Oly eliminating the regular macro mode, and having the AF range cover the entire range (except super macro, which I have used only once or twice).
 pablolie's gear list:pablolie's gear list
Olympus XZ-2 iHS Olympus PEN E-P2 Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +5 more
Ivo Verhaar
Re: focus issues
Well, for me it is a new cam and almost all do worse in low light low contrast situations, so defnitely not going to judge it now. IMHO it is more than fine, maybe not stellar.
But as you say, the gorgeous display with the very functional manual focus makes it a breeze anyhow.
so simply going to update it to the latest version and we will see.
by the way i did not see an option to select super macro, to me it looks like it selects it itselve in manual focus under 30cm... but could be somewhere in the iauto stuff... so used pasm
i can only hope that the new E-7 Em7 whatsoever will be as informative as this puppy... Gee if it had a high grade 400 tele inside and it was weatherproofed, i might be very tempted to leave the big gunn at home on holiday.
so do i like it yessssssssss. Now some time use it more extensive lol
Re: focus issues
Ivo: If you use the super control panel, tap S-AF then use the front control ring to scroll to the next mode which is super macro.
Judith
BMWBig6 Forum Member • Posts: 74
Re: focus issues
Judith
How does one get the Super control panel to appear?  I read about it in the manual, but can never get it to show up no matter what mode I use.  I can cycle through the other "regular" screens but not the Super control panel.  I must be doing something wrong.
Ben
 BMWBig6's gear list:BMWBig6's gear list
Olympus XZ-2 iHS
djrocks66
djrocks66 Senior Member • Posts: 1,214
Re: Just picked up an Oly XZ-2
Love the camera but I do have the focus problem. I am very experienced so it is definitely a camera problem. At certain focal lengths in low light it never locks focus. Red square. I have to manually focus which is not a big deal as I enjoy doing that anyway. It is mostly an annoyance but I did not get this to shoot low light stuff. I did almost throw it against a wall though when I was trying to focus on my daughters face after a play performance. I resisted and focused manually  I never had the focus lock problem on the XZ-1.
 djrocks66's gear list:djrocks66's gear list
Fujifilm X-Pro1 Canon EOS 6D Fujifilm X-T1 Canon EOS 7D Mark II Fujifilm X-T10 +16 more
photo perzon
photo perzon Veteran Member • Posts: 4,208
That is serious.  I wonder is Olympus is gonna try to fix this major problem.  " I did almost throw it against a wall"
 photo perzon's gear list:photo perzon's gear list
Sony Cyber-shot DSC-RX100 III Olympus PEN E-PL5 Fujifilm X-A1 Panasonic Lumix DMC-GM1
Re: Super screen
I'll try to recreate it for you tomorrow.  It is buried 5 or 6 deep in the Menu in Display, I think.  You need to turn off "Live" and then toggle on Super Screen."  To access the super screen after it's up and running, use the OK button.  Give it a try tonight.
Judith
OpticsEngineer Senior Member • Posts: 4,486
focus problem question
Could you post what settings you were using with your XZ2 when you had the focus problems?  I would like to try to re-create the problem on mine.  I have had occassional problems but nothing I can seem to reproduce reliably in the kinds of situations others seem to be having difficulty with.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Sony Alpha NEX-7 +21 more
Ivo Verhaar
Re: focus problem question
Well mine is at least doggieproofed
http://www.flickr.com/photos/iverhaar/sets/72157633055689915/
ohoh new camera in town...
strike a pose...
Gary Leland Regular Member • Posts: 237
I have had no focus issues.  Some slightly out of focus.  But my camera is always locked in on something.
Ivo - Nice puppy pics.  Your friend seems to be quite photogenic.
Gary Leland
 Gary Leland's gear list:Gary Leland's gear list
Olympus XZ-2 iHS Olympus OM-D E-M5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R
Very nice shots, Ivo.  Loads of personality there!
Ivo Verhaar
Well she is no pup, already 3 but my parents little puck behaves like one a big part of the time, and definitely a great personality inside of her. But she is even to fast for my E-3 from time to time... hmm do mis that focus tracking which was on my old canon eos 5e slr from time to time.
Novicia Junior Member • Posts: 34
The XZ-2 has focus tracking in its autofocus modes (C-AF+TR). Haven't tried it; seems like it might be tough to use if one's doggie is jumping around, since you have to keep the shutter halfway depressed while tracking.
Shhhh don't tell anybody, but sometimes I'm lazy and shoot a short video clip. Then I can grab a frame that turned out well and pretend I just had perfect timing O.o!
Ivo Verhaar
lol will give it a go, she tends to sprint straight towards me yeessssss bosssie back.... sooo will be challenging to say the least
