Difference between gamma range in different softwares
Started Mar 11, 2013 | Discussions
cboudier Regular Member • Posts: 413
Hello,
the first step of my retouching process is to set a gamma value between 2.2 and 2.7 in Photoshop (or Elements)
In Photoshop, Capture One, PhotoLine, Capture NX, the range goes from B=0 to W=255, middle being 1 (i.e. non linear scale)
In GraphicConverter, Pixelmator, Aperture and anything with a Quartz engine, the range goes from B=-1 (or -1.5) to W=+1 (or +1.5), middle being 0 (i.e. linear scale)
Have you any explanation for the different approaches ?
If I want to use Aperture, what gamma range should I use ?
Thanks a lot for your help.
Christophe Boudier
 cboudier's gear list:cboudier's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +1 more
cboudier OP Regular Member • Posts: 413
Re: Difference between gamma range in different softwares
oops, made a mistake : in Aperture as in Pixelmator, the range is B=0 to W=1, middle being 0.5, linear scale also.
Christophe Boudier
oops, a second mistake !
in Photoshop, the gamma range goes from 10 on the left side to 0 on the right side (and not from 0 to 255 as I wrote earlier)
But this doesn't solve my problem neither...
so to summarize :
Photoshop : [10 ; 0], middle = 1
Aperture : [0 ; 1], middle = 0.5
Christophe Boudier
benross Contributing Member • Posts: 931
I guess it's the story of that amplifier that you could crank up to 11.
