Landscape with SX50 HS
Started Mar 10, 2013 | Discussions
Wulfhere New Member • Posts: 4
As you can see from this image, the background is kind of washed out. Maybe this what makes me focus on the subject (which is nice and clear). What settings should I have had so that the background is... less so out of focus, enough for definition but not so much for distraction? DOF, landscape...a mode missing from the SX50 HS. I own both the SX40 HS and the SX50 HS. I keep the SX40 HS because, basically.. love the camera. I bought the SX50 HS for the zoom. What and where do I make the settings so that this photo has background definition? PS. Love both cameras, still a novice.
Canon PowerShot SX40 HS Canon PowerShot SX50 HS
Digital Shutterbug Senior Member • Posts: 2,081
Re: Landscape with SX50 HS
DOF is controlled by the aperture. You need to close the aperture down (a larger number) to increase the DOF. In this example, I'm not sure I would want to do that. You really want your eye drawn to the main subject.
Steve
 Digital Shutterbug's gear list:Digital Shutterbug's gear list
Sony Cyber-shot DSC-RX10 III
Wulfhere OP New Member • Posts: 4
Thanks . I love this picture, but had I wanted to... You are right. So bringing the AV to f/8 would have done it (all on it's own?)? Thanks again
I'm not going to say that f/8 would have made a huge difference, but it's in the right direction.
Steve
Sue K
Sue K Regular Member • Posts: 153
Love it just the way it is!
Sue K
 Sue K's gear list:Sue K's gear list
Canon PowerShot SX200 IS Canon PowerShot SX50 HS
VisionLight
VisionLight Senior Member • Posts: 3,685
What you have in this image is a very narrow depth of field. Depth of field is the distance between the nearest point and farthest point in an image that will be in reasonable focus. Different focal lengths have different depths of field. The wider the focal length, the more depth of field. The longer the focal length, the lesser the depth of field. Different sensor sizes will have different depths of field for the same focal length. Smaller sensors will have more depth at a given focal length than a larger sensor. This image is taken with a VERY LONG focal length, 215mm on the small SX50 sensor or 1200mm full frame equivalent. Since the size of the bird indicates that it was only about 40 to 50 feet away, depth of field would only be within the area of the subject and CAN NOT also include any background. Using a long telephoto, you CAN NOT correct this. In order to get more of your image in focus, you would have to zoom back down to a shorter focal length where the depth of field is greater, then move in to within 5 to ten feet from the bird. Now focusing on the bird will also include focus on the background in the short focal length's wide depth of field.
Vision
Edit: Note that aperture can also increase depth of field by closing it down. But once again, the effect is limited as the focal length increases. And on the SX50, the smallest aperture is only f8, so the effect is even more limited. So once again, on P&S cameras with small sensors, the best way to increase depth is to use a lower focal length and get closer to your subject.
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Augustin Man
Augustin Man Veteran Member • Posts: 6,517
I think your shot is very good as it is, the bokeh is outstanding !
For landscapes the apperture should be smaller  (f8), but here it would only loose the focus on the bird
Thank you for sharing,
Augustin
 Augustin Man's gear list:Augustin Man's gear list
Canon PowerShot SX50 HS Nikon Coolpix P900
Patricia S. Jones Senior Member • Posts: 1,017
How would you feel...
...about the soft-focus background if there were not so much of it?  I like the sharper bird/hazy surroundings but would like to see a crop in which the bird dominates the space more. In any event, that's a beautiful bird.
Regards... Patsy Stored Memories: http://www.pbase.com/patsysj
filibuster
filibuster Veteran Member • Posts: 3,212
Re: How would you feel...
Patricia makes the point about negative space, and I totally agree. Sheer bad luck that you did not take the shot in portrait orientation with all the bird in the frame.
Quote hhgttg: Life is wasted on the living.
filibuster (Bromsgrove, Worcestershire, UK)
http://picasaweb.google.com/scenic.filibuster
Stephen Ingraham Senior Member • Posts: 1,331
I have taken the liberty to do a bit of post work in Lightroom...just to demonstrate the possibilities. Part of the problem here is the underexposure of the background. Lightroom work was done with Shadows and Clarity only, applied to the whole image...no local adjustments. Took me 30 seconds.
 Stephen Ingraham's gear list:Stephen Ingraham's gear list
Nikon Coolpix P900 Canon PowerShot SX50 HS Sony Cyber-shot DSC-HX400V Sony Cyber-shot DSC-HX90V Sony Alpha NEX-3N +4 more
vipictureman Forum Member • Posts: 77
Here is another option that was suggested. To see more of the bird, and in a vertical format.
Despite the small sensor on the SX50HS it has held up well to the heavy cropping I made on this image, indicating you executed a sharp and fine exposure of the main subject.
 vipictureman's gear list:vipictureman's gear list
Canon PowerShot S70 Fujifilm FinePix F31fd Panasonic Lumix DMC-TZ5 Panasonic Lumix DMC-LX5 Canon PowerShot SX50 HS +13 more
DonA2
DonA2 Senior Member • Posts: 2,640
Vipictureman, you hit it right on.  Crop and rotate.  100% improvement.
Don V. Armitage
 DonA2's gear list:DonA2's gear list
Canon PowerShot S2 IS Canon PowerShot SX10 IS Canon PowerShot S100 Canon PowerShot SX40 HS Canon PowerShot SX50 HS +1 more
