Wide angle , fast lens for Sony alpha. Any suggestion ?
Started Mar 8, 2013 | Questions
peter42y Senior Member • Posts: 2,181
Hi everyone :
Does anyone in this forum has any suggestion  for a wide  24 or 28 mm  fast ( f2 ) ,  lens for alpha DSLR ?
Months ago I bought the  dt 50 mm f1.8 ..., but I do not enjoy much the lens.
It is not wide enough. In order to get a shot I must be relatively far away from the subject.  Besides.., forget wide angle indoor pictures .  The lens cant do it !!!!
Thanks in advance for your input.
PS: The sony nex has the newly released f1.8 , 24 mm lens . People say it is quite good.
http://forums.dpreview.com/forums/thread/3392785#forum-post-50966152
 peter42y's gear list:peter42y's gear list
Ricoh Caplio R8 Canon IXUS 310 HS Nikon 1 V1 Canon EOS M
Ed at Ridersite Forum Pro • Posts: 17,251
Re: Wide angle , fast lens for Sony alpha. Any suggestion ?
http://www.dyxum.com/lenses/Carl-Zeiss-Distagon-T*-24mm-F2-ZA-SSM_lens587.html
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
 Ed at Ridersite's gear list:Ed at Ridersite's gear list
Sony RX100 II Sony SLT-A77 Sony DT 16-50mm F2.8 SSM Sony 70-400mm F4-5.6 G SSM II
Marco Cinnirella
Marco Cinnirella Veteran Member • Posts: 5,146
You would get more focused responses if you mentioned whether you were using full frame or APS-C and what your budget is.
The Carl Zeiss lenses in the Sony range and the G ones are generally the very best, but there are some very good budget ones as well such as the Sony 35mm 1.8 DT  SAM. And then there is all that legacy glass from Minolta, not to mention glass from Tokina, Sigma and Tamron.
"When words become unclear, I shall focus with photographs. When images become inadequate, I shall be content with silence." Ansell Adams.
 Marco Cinnirella's gear list:Marco Cinnirella's gear list
Fujifilm FinePix X100 Sony SLT-A77 Olympus OM-D E-M5 Sony SLT-A99 Fujifilm X-T1 +4 more
Rashkae Senior Member • Posts: 1,167
peter42y wrote:
Hi everyone :
Look here and start reading:
http://www.dyxum.com/lenses/index.asp
EinsteinsGhost
peter42y wrote:
Hi everyone :
Sony 35mm f/1.8 is a better general purpose lens than 50mm f/1.8 due to it having a wider FoV whereas the latter is more suited for portraits and open spaces, or if you need more reach. They are two of the excellent trio (the last being 85mm f/2.8, which I believe is based on Zeiss Sonnar design and is a full frame lens).
If you don't mind spending more (which you have to, for the FoV coupled with large aperture), Sony-Zeiss 24mm f/2 is your option.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
William Porter Senior Member • Posts: 1,676
Peter,
From what you said, I'm guessing you're using an APS-C camera like the A55, A57, A65, A77, etc. (or maybe A580, 550, 500, 100, etc.).
On an APS-C sensor camera, 50mm is not a wide-angle lens, it's not even a "normal" field of view: it's a "near telephoto".
If you're looking for a lens with a normal (little bit wide, but not TOO wide) field of view for an APS-C camera, you will to get something like a 28, 30 or 35mm. There are inexpensive but remarkably good, fast lenses for the 30mm and 35mm focal lengths.
30mm lens at Sony store
35mm lens at Sony store
They're great bargains. I've owned 'em both.
On your camera (if I'm guessing right about what you have) 28mm will be "wide-ish" rather than "wide". The old Sony 28 f/2.8 is available used from KEH and elsewhere; at least that's where I got mine.
Will
 William Porter's gear list:William Porter's gear list
Panasonic Lumix DMC-LX7 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +7 more
rio911
rio911 Contributing Member • Posts: 973
How about the Sigma 24mm f1.8?  I've used it for a long time and it is very sharp, with great IQ.
Here you will find some images I have taken with it: http://forums.dpreview.com/forums/thread/3392456
rio
 rio911's gear list:rio911's gear list
Sony RX100 Sony SLT-A77 Sony 50mm F1.4 Sony 70-300mm F4.5-5.6 G SSM Sony DT 16-50mm F2.8 SSM
peter42y OP Senior Member • Posts: 2,181
Thanks a lot for your helpful answers. I will check all of them.
I have 2 aps-c Sony cameras, both with the same sensor ( Sony A500 and sony a550).
The 550 is brand new. I bought it last december and I have not used it much.
The DT 50 mm , 1.8 is a almost telephoto lens, indeed.
I got it since I saw it recommended in camera labs website but I have found it very frustrating for indoors shooting.
http://www.cameralabs.com/lenses/lens_buyers_guide/Sony_Alpha_lenses/Which_portrait_lens/Which_Sony_Alpha_portrait_wedding_low-light_lens.shtml
Thank You
MediaArchivist
MediaArchivist Senior Member • Posts: 2,709
Zeiss 24/2
I have the CZ 24/2, and I can't say enough good things about it (except i wish is was not so expensive). I use it on my crop sensor a77-- but I can't wait to get the a99 (or a101 or whatever the 50Mp square sensor successor will be called).
Sigma has some inexpensive wide f/1.8 lenses, I don't own one but I have read mixed reviews on them. If "fast" allows for f/2.8, the Tokina 11-16 F2.8 is supposed to be pretty good (another lens I do not own). For crop sensors, the Sony 16-50/2.8 is pretty wide, a good build, and fast AF.
 MediaArchivist's gear list:MediaArchivist's gear list
Sony SLT-A99 Sigma 50mm F1.4 EX DG HSM Sony 135mm F2.8 (T4.5) STF Sony 24mm F2 SSM Carl Zeiss Distagon T* Sigma 35mm F1.4 DG HSM Art +16 more
