Olympus OM-D E-M5 really cheap grip.
Started Mar 7, 2013 | Discussions
juansalva New Member • Posts: 8
Hello everyone! I am new to posting in forums. Like many of you, I too have been searching for an inexpensive grip to compensate the lack of it on the OM-D. Recently I came across with what I think is a really cheap, non-bulk-and-light solution, and I want to share it with the community.
I find outrageous the price that Olympus charges for the HLD-6 grip, and let's not go into the matter selling the hoods separately from their lenses while having to pay rape prices for the hoods. Oh well, that is the subject for another forum.
Disclaimer: I have no commercial or otherwise relationship with the company which makes the product that I am writing about. I purchased the product myself for around $13 including shipping. I am not recommending it, I am simply sharing my findings.
Check out the different grips made by a company called Flipbac (www.flipbac.com), among them there is one that was recently released called G3 - Flipbac Camera Grip 3 - Narrow 2nd Edition, the way to tell between versions is that the newer Narrow 2nd Edition doesn't have the model number molded onto the grip itself. Its dimensions are 38mm in height by 19mm in width and around 7mm in thickness..
I have been using the camera with the grip for few days, and handling the camera is way better.
The only time it feels a bit cramped between the lens and the fingers is in those rare occasions when I am hand holding the Panasonic 100-400 with a tripod clamp attached. Other than that, the grip is comfortable with other lenses I use.
Please keep in mind that depending on the size of the fingers, this solution may not work for all of you OM-D owners. As with anything, let me add, not everyone will like it for one reason or another. Again, everyone is entitled to their opinions. I have no doubt that the approach to a grip presented by Mr. John Milich is much better, I'll soon probably purchase one. For now while on a tight budget, this works and doesn't add a lot of weight or size to the camera.
Cheers!
I placed the grip 8mm from the edge of the top of the camera's grip
VIEW FROM BOTTOM OF CAMERA
Side view
Two fingers rest easily on the grip
Olympus OM-D E-M5
dcassat
dcassat Senior Member • Posts: 1,192
Fastened by?
It does look like a viable solution for many people depending on the way it is fastened to the body...  glue?
Thanks for sharing!
Dan
 dcassat's gear list:dcassat's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH +8 more
Alumna Gorp Senior Member • Posts: 1,531
Re: Fastened by?
Hey, that`s pretty cool never thought of glue
 Alumna Gorp's gear list:Alumna Gorp's gear list
Fujifilm X10 Olympus OM-D E-M5 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-G2 Panasonic Lumix G 14mm F2.5 ASPH +4 more
juansalva OP New Member • Posts: 8
Re: Fastened by?
From the manufacturer's web site:
The no-mess 3M adhesive has a strong, secure hold but also allows the grip to be removed without leaving residue or damaging the camera body. After removing the grip, cover the adhesive with the original backing material for storage so that you can reattach the grip.
http://www.flipbac.com/camera-grip-about.htm
Aleo Veuliah
Aleo Veuliah MOD Forum Pro • Posts: 14,628
Re: Olympus OM-D E-M5 really cheap grip.
For a cheap solution, it looks good.
Simplicity is the ultimate sophistication.
Pure logic is the ruin of the spirit.
If plan A doesn't work, the alphabet has 25 more letters, keep calm.
Imagination is more important than knowledge.
God is the tangential point between zero and infinity.
Aleo Photo Site
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GH4 +4 more
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 17,410
Wow - these are pure Richard Franiac imitations....
Richard Franiac has been making this style grip for countless cameras and he's often featured on various forums (to which he makes camera grips for).  This company featured here is certainly taking his idea and running with it (I wonder if Richard has a patent on his designs, or....if, in fact, this is Richard's company under a different heading).
Have a great one....
Bernd (Ben) W. Herrmann
North Carolina, USA
link
 Ben Herrmann's gear list:Ben Herrmann's gear list
Olympus XZ-1 Canon PowerShot G12 Canon PowerShot SX50 HS Nikon Coolpix P330 Fujifilm X20 +38 more
baxters Veteran Member • Posts: 5,016
Holding the OMD EM5 isn't a problem for me, but I thought I would try a stick-on grip for my EPM1 and another bar-of-soap camera I own. We'll see,
These don't look like Franiac knock-offs to me. Just molded rubber/silicon in a different shape, with adhesive.
 baxters's gear list:baxters's gear list
Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6
DonParrot Veteran Member • Posts: 3,600
Re: Wow - these are pure Richard Franiac imitations....
They have been producing these grips for years and I purchased a three item-set for my E-PL3 to years ago to test which one would suit me best. Buit i never would have come to the idea to use them for the E-M5 too as I hadn't believed they would stick on its material. Interesting indeed.
And these grips are made of rubber while Richard's are metal.
I wish I was an OLYgarch
 DonParrot's gear list:DonParrot's gear list
Panasonic Lumix DMC-FZ1000 Olympus E-30 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GH4 +12 more
SayCheesePlease New Member • Posts: 1
Are you Richards best buddy?
Richard copied OEM grips that were on previous cameras. Richard makes fine custom machined aluminum grips for US$40 plus shipping. Flipbac makes high density silicon grips for $10.  This is the same silicon material that Nikon and Canon use on their cameras.
The flipbac grips work "as well " with $30 still in my pocket.
Bobby Handal
Bobby Handal Veteran Member • Posts: 5,452
Re: Olympus OM-D E-M5 really cheap grip from China?.
I am baffled with this grip situation. China comes out with cheap grips for every nikon and canon available, even came out with some Olympus clones. And now, one of the better sellers of M4/3 systems out there and no grips ??
Hard to believe. Bummer.
Whoever comes out with a true clone grip from China, I believe will make a bundle of money. It would be great to have a vertical button, built in remote control, etc.
www.photoexpedition.net
www.fotoclubhonduras.com
http://img.photobucket.com/albums/v206/bobhandal/BANNERXPEDITION1.jpg
 Bobby Handal's gear list:Bobby Handal's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-TS3 Sony Cyber-shot DSC-HX400V Nikon Coolpix P900 Ricoh WG-M1 +55 more
PAUL TILL
PAUL TILL Veteran Member • Posts: 9,285
Looks like you need to be double jointed to use that contraption. Who holds a camera like that?
The 10% Rule:
You Must Be 10% Smarter Than The Equipment You're Operating
Sergey Borachev Senior Member • Posts: 3,303
The 10% Rule:
Those fingers are two close to the lens barrel.
I think the JB Design grip is much much better as a cheap grip.  If you can afford the E-M5, you should be able to afford this $46 grip.  Much more comfortable.  The edges are slightly sharp, but 15 minutes of work using a very fine file or sandpaper will fix them.
Soon, there should be some cheaper version similar to the JB one, but much cheaper, made in China.
ARB1
ARB1 Veteran Member • Posts: 3,082
It looks tacky to me.  I just purchased the actual grip and now my OMD feels amazing.
I see Olympus had $50 off through April 20th.  Forget the stick-on and get the real thing.
https://www.getolympus.com/us/en/featured_weekly_deals/?utm_source=web&utm_medium=redirect&utm_campaign=redirect_offers
Allen
___________
"It's easier to build strong children than to repair broken men."
-- Frederick Douglass
 ARB1's gear list:ARB1's gear list
Olympus OM-D E-M5 Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 24-120mm f/4G ED VR Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +6 more
