Nikon 20mm not D version noise while Autofocusing
Started Mar 7, 2013 | Discussions
johnparas11zenfoliodotcom
Senior MemberPosts: 2,214Gear list
Mar 7, 2013
I just got this lens, it focuses on my D300s, quite fast and responsive actually, but is the somewhat grinding noise normal? Not like gears grinding noise but it is just noisy.. Anyone have any experience with this oens? Thanks!
The noise is when it goes from infinity to minimum focsuing distance when the barrel travels the whole distance..
Nikon D300S
Re: Nikon 20mm not D version noise while Autofocusing
In reply to johnparas11zenfoliodotcom, Mar 7, 2013
i  just did a comparison test with my Nikon 50mm f/1.8 non d... and yes the 20mm is noisier hhmm..
jhinkey
Senior MemberPosts: 2,758Gear list
Mine is about 15 years old and it too makes a lot of noise while focusing.  I suspect is needs some lubrication or the gearing inside is worn out.  Still works so I keep on using it.
John
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-LX7 Nikon D800 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GH3 +20 more
