best sd cards , what are you using
Started Mar 6, 2013 | Discussions
cream Contributing Member • Posts: 625
hi
I have nx1000  with sandisk 32gb class10  and transcend 16gb class 10
seems ok so far  but haven't tried many  fast action shots as yet.
whats everyone else using
thanks
mark
Samsung NX1000
timedrun Contributing Member • Posts: 683
Re: best sd cards , what are you using
Eric (viking) has recently ran a testmand posted the results on this forum,  it seems that there may be an upper limit beyond which returns dimimish exponentially.
A little green rosetta......a tiny green rosetta........
 timedrun's gear list:timedrun's gear list
Samsung NX20 Samsung NX 16mm F2.4 Pancake Samsung NX 30mm F2 Pancake Samsung NX 45mm F1.8 Samsung NX 50-200mm F4-5.6 OIS
Knallberto Veteran Member • Posts: 5,478
is there a SD-virus for the 999th time ?
go into next shop, buy a class10 + be happy!
Re: is there a SD-virus for the 999th time ?
Even class 6 seem ok on my NX11, so im more than happy with a class 10.
Peadingle
Peadingle Regular Member • Posts: 491
 Peadingle's gear list:Peadingle's gear list
Samsung TL500 Canon PowerShot G1 X
83cat New Member • Posts: 15
cream wrote:
hi
thanks
mark
Very similar, I have nx1000 with sandisk 16gb class10 and transcend 32gb class 10.
felix
 83cat's gear list:83cat's gear list
Samsung NX 50-200mm F4-5.6 OIS Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 30mm F2 Pancake Samsung NX 45mm F1.8 Samsung NX 16mm F2.4 Pancake
barfoo New Member • Posts: 16
I recently switched from a PNY Class 10 card to a Sony UHS-1 card (rated for 45 MB/s writes) in my NX100, and a noticed a difference right away. With the PNY card, there was often a long buffer lag after a shot, during which some of the control menus became inaccessible: the display was on, but I couldn't change ISO, WB, etc. After a series of shots, the delay could become quite long and noticeable. But with the UHS-1 card the delay is much shorter, which makes the camera more usable (it's easier to try the same shot again with different settings). I always shoot RAW, which of course means the writes take longer.
 barfoo's gear list:barfoo's gear list
Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS
Draek
Draek Senior Member • Posts: 2,028
El-cheapo Kingston 8 GB Class 4 SD cards. My beard grows a whole centimeter while I wait for my EX1 to finish writing a RAW+JPEG frame, but what can I say? I shot for so long with manual film cameras I'm pretty used to this whole "seconds per frame" thing. And they're cheap. Did I mention cheap? yeah.
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Canon PowerShot A1200 Samsung TL500 Sony Alpha DSLR-A390
trac63 Contributing Member • Posts: 615
I have a Panasonic Gold Class 10 SDHC.
viking79
viking79 Forum Pro • Posts: 14,136
Peadingle wrote:
Another test of SD cards.
Interesting. Transcend looks best overall, but worst with 32 MB files (the size of the RAW files).  The Sandisk and Lexar look noticeably better there.
Looks like I might need to get a different benchmarking program, might explain some of the discrepancies I saw between benchmark speed and camera performance if I care to do more of tests, which I don't really care to do
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
ac146 Regular Member • Posts: 322
Hi!
We use a Sandisk Ultra 32gb class 10 and a Lexar 32gb class 10 SD cards in our WB750 and EX1.
Santa being sympathetic of slow write times.
The class 10s seems faster than what we had before (class 6 cards). How much faster I couldn't tell you.
Nova Scotia, Canada
 ac146's gear list:ac146's gear list
Olympus XZ-2 iHS
Ariston Senior Member • Posts: 2,401
I would advise to use a 16GB instead of 32gb. for some reason, the 16gb have much faster write times. also, the Ultras are quite mediocre compared to the Pro series and UHS-1.
hootsmon
hootsmon Contributing Member • Posts: 887
SanDisk "Ultra" 16Gb, Class 10, SDHCI.
Claims 30MB/s
Presently using this card in an NX-11, however I'm guessing its probably wasted (ie. overkill).
 hootsmon's gear list:hootsmon's gear list
Samsung NX11 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samyang 12mm 1:2.0 NCS CS
nx200USER1 Senior Member • Posts: 1,097
I have tried several different types of cards at varying speed ratings. For my nx200 I think from past experience timing tests and talking with others on this forum its would seem my Patriot 32GB class 10 suffice its maximum capabilities to write to the card. I tried a sony or samsung UHS-1 but the card didnt play well with my camera. Took it back and got a patriot 32GB class 10. I tried a sandisk extreme 16GB, no change in write times to the card. Took it back and got a patriot 32GB class 10 (I have like 7 of them now!)
Updating to the latest firmware was prolly the biggest benefit in write times ( I was a stick in the mud keeping fw v1.02)
The only benefit of my camera working well with a faster (write) card would be the files will offload from my card reader to computer much quicker. ah well...as the late Doris Day would say que sera, sera.
