Advice on background
Started Mar 5, 2013 | Discussions
dka91 Senior Member • Posts: 1,059
Hi, I posted a couple shoot about 2 weeks ago and Im going over some photos from that shoot in ps to remove some backgrounds but Im unsure of a few of the shots, so I thought Id ask here if you think they look too distracting...
Thank you
 dka91's gear list:dka91's gear list
Nikon D7200 Samsung NX 85mm F1.4 ED SSA Samsung 16-50mm F2.0-2.8
RichV Veteran Member • Posts: 6,135
Re: Advice on background
I think your instincts are good - especially, the young lady always seems to have a tree growing out of her head!  They photograph well (and you did a good job of it), so I'd invest some time and effort in the possibilities.
 RichV's gear list:RichV's gear list
Sony RX100 Sony SLT-A77 Sony SLT-A99 Sony 70-200mm F2.8 G Sony 50mm F1.4 +6 more
dka91 OP Senior Member • Posts: 1,059
Awesome, thanks alot for the tip, its off to ps lol!
Sonyshine
Sonyshine Senior Member • Posts: 7,829
Yes the background is distracting. A wider aperture ( maybe on a different lens? ) would have blurred it out.
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +7 more
123Mike Senior Member • Posts: 4,643
Those two are so radiant, I'm not even noticing any background. What was in the background again, I forgot.
But you could blur it by using a longer focal length and standing back a little further.
Thanks for the advice
Yes tbh I would've liked to have used a wider aperture, but I was having a little...trouble trying to get both of them in focus, even when they were on the same plane.
Ill try it for next time though, maybe get them to pose in a more straight line so theyre exactly at the same distance.
Thanks pal
Ed at Ridersite Forum Pro • Posts: 17,230
In addition to not stopping down so far, you can also use a little longer lens - maybe 50mm @ f2.8.  If you shoot again, pay attention to the background and keep distractions relatively far from the subjects (completely out of the photo if possible).  In general, you want the distance from the camera to the subject to be small and the distance from the subject to the background to be large.  However, if you use a wide angle lens, you will have trouble with just about anything showing in the background.
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
