What is the maximum ISO you're comfortable shooting (and what camera)?
Started Mar 5, 2013 | Questions
Sammy Yousef
Veteran MemberPosts: 4,570Gear list
Mar 5, 2013
I typically shoot my D90 at base ISO (200), but was wondering what most people actually shoot at regularly with the newer bodies. I will typically set auto ISO up to 800 but no more for action photography.
Sammy.
My forum postings reflect my own opinions and not those of my employer. I'm not employed in the photo business.
Nikon D90
Nexu1
Senior MemberPosts: 2,523
Re: What is the maximum ISO you're comfortable shooting (and what camera)?
In reply to Sammy Yousef, Mar 5, 2013
3200 with Sony rx100. Kinda new to the d5100 but I assume it'll match that.
JCB123
Senior MemberPosts: 1,248Gear list
Sammy.
D90 pretty much the same as you. I'll sometimes stretch to ISO 1600 if I really need to but prefer to limit to ISO 800 and prefer to keep to ISO 200 wherever possible.
For the D7000 you can add a stop to all the high ISO and I am happy to shoot at ISO 100 to 400 anytime. If I don't need to get the maximum out of the sensor (won't need to print large) then ISO 3200 is acceptable, but the problem here is that I tend not to want to commit to output usage restrictions (or even think about that) while I am shooting - I prefer to keep all options open if possible. Nevertheless if you are shooting in low natural light conditions, need to freeze subject motion and cannot or prefer not to use flash. ISO 3200 can sometimes get you a shot that would otherwise not be possible.
RX100 as for D90 but usage is different and I am not expecting to print an ISO 800 image very large.
E-PL2 Close to D7000 for ISO vs IQ, but not quite. It is a less capable camera in other respects so usage as yet is not really the same, although the purpose of owning the E-PL5 is to provide a more portable alternative to the D7000.
Regards
John
 JCB123's gear list:JCB123's gear list
Sony RX100 Nikon D90 Nikon D7000 Olympus PEN E-PL5 Nikon D7100
GeorgeE
New MemberPosts: 1
3200 with D7000 if i have to, but usually at 1600
TOR8472
Senior MemberPosts: 1,589Gear list
Re: 800/1600/3200
D80 - 800
D300 - 1600
D7000 - 3200
Of course I prefer base ISO, and prefer to shoot at less than half my "comfortable" level if possible.
 TOR8472's gear list:TOR8472's gear list
Panasonic Lumix DMC-FZ1000 Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +3 more
fotolopithecus
Senior MemberPosts: 1,699Gear list
Re: 800/1600/3200
In reply to TOR8472, Mar 5, 2013
My philosophy is to always shoot at 100 iso unless you can't. On my D7000 I get very good results at 400 iso as well, so when there's a good reason I have no problem shooting higher.
 fotolopithecus's gear list:fotolopithecus's gear list
Nikon D610 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-S Nikkor 50mm f/1.8G
Mako2011
Mako2011 MOD
Forum ProPosts: 19,212
Combo
D7000 and Topaz DeNoise combination.... ISO6400 easy.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
Aaron01
Regular MemberPosts: 171
D7000 ISO 1600, but I have gone 3200 in a pinch but IQ degrades even in RAW.
D600 ISO 6400
JakeB
Contributing MemberPosts: 797Gear list
Re: Combo
In reply to Mako2011, Mar 5, 2013
Topaz DeNoise is pretty incredible -- I've gone to ISO3200 on my D7000 with DeNoise and it has almost completely cleared up the noise with very little detail reduction.
I'll give 6400 a try.
 JakeB's gear list:JakeB's gear list
Nikon D7000 Fujifilm X-E2 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +3 more
Mako2011
Mako2011 MOD
ISO6400
In reply to JakeB, Mar 5, 2013
ISO 6400 takes a little more work and suited better for some scenes over others. Using Topaz DeNoise in layers or selectively you can nearly get the same results as having done it with 3200. Scene dependent of course.
Alex Yantifovich
Regular MemberPosts: 437
I mostly shoot in Auto ISO in S or A priority modes saved to my U1 and U2. I am comfortable with ISO 3200, although it rarely jumps that high.
Nikon D7000
Nikon 18-70mm f/3.5-4.5G AF-S DX
Nikon 70-300mm f/4.5-5.6G AF-S VR
Nikon 50mm f/1.8 AF
Tamron SP 90mm f/2.8 Di Macro
Sigma 10-20mm f/4-5.6 EX DC HSM
Nikon SB-600
Manfrotto 190XDB / 486RC2 Ballhead
scokill
Senior MemberPosts: 2,208Gear list
I'm comfortable shooting to 3200 on d7000.  High ISO only comes into play during dance recitals/competition, etc. and indoor sports.  My preference is lens stopped down 1 stop from max up to 3200 and then go from there either wide open, reduce shutter speed, or up to 6400 or any combination thereof.   I'm concerned about people, so if the subject is lit and the scene is dark, i'll meter person.  When you get to 6400 with any crop skin turns to mush or plastic with noise reduction, but can be acceptable.  I took some test shots at 12,800 this weekend for kicks and it's very, very rough.  If it gets to that I just put the camera up.
 scokill's gear list:scokill's gear list
Nikon D610 Nikon Df Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +1 more
Lightpath48
Senior MemberPosts: 3,324Gear list
D5100, ISO 1600, 3200 in a low light pinch. Not 6400. Rule of thumb: highest usable ISO is half the maximum (without going into extended range). With my D5100 (or D7000) that would be 3200, half of 6400.
 Lightpath48's gear list:Lightpath48's gear list
Sony Cyber-shot DSC-RX10
nfpotter
Veteran MemberPosts: 4,080
Re: 800/1600/3200
In reply to fotolopithecus, Mar 5, 2013
Lol.  Duh.
nfpotter
6400, D7000.  Better a noisy shot than a blurry one.
rpacoma
New MemberPosts: 11
Currently using a D90 and I have no qualms about taking it to 1600; sometimes to 3200 if I really want the shot.  Using Topaz Denoise really helps out though with removing the noise at the higher ISOs and basically repressed my urges to get the new D7100 (for now....).
brucet
Senior MemberPosts: 2,107Gear list
In reply to rpacoma, Mar 5, 2013
D7000 1600iso.
I'm a new convert to DeNoise and love it. But 1600iso is still my go to max.
 brucet's gear list:brucet's gear list
Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Tokina AT-X Pro 12-24mm f/4 DX II Nikon AF-S Nikkor 50mm f/1.8G
Ed_arizona
Senior MemberPosts: 1,541Gear list
Re: Combo
HOw you like the Topaz Denoise compared to detail mode in LR 4.0... I have Topaz bundle loaded, but not tried denoise yet, is it really better?
“ You’ve got to push yourself harder. You’ve got to start looking for pictures nobody else could take. You’ve got to take the tools you have and probe deeper." – William Albert Allard
 Ed_arizona's gear list:Ed_arizona's gear list
Panasonic Lumix DMC-LX5 Fujifilm X-E2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
pixd90
Senior MemberPosts: 1,354Gear list
I start my D90 at base ISO of 200 and shoot 99% in manual . My brain is now wired that I could not see ever getting away from front & rear wheel adjustments. I increase my ISO based on need, type of picture or type of effect that I want. If I just want to get the shot I would increase ISO to where it takes me to get the shot than try to fix in PP, photoshop,lightroom, topaz, etc. Last resort I try B&W than X for delete.
I know that our D90's are limited and upgrading will get to lower ISO, but will hold off till May.
 pixd90's gear list:pixd90's gear list
Nikon D90 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G
baloo_buc
Veteran MemberPosts: 7,780Gear list
Nikon D90: max ISO3200
Nikon D5100: max ISO6400
The noise doesn't bother me as much a blurry photos or having to use tripod for every shot.
I use ISO Auto in combination with M mode in order to reduce as much as possible the ISO Speed.
Nikon D5100, ISO 4500
Nikon D90, ISO 2500
I go to the max only if necessary.
 baloo_buc's gear list:baloo_buc's gear list
Nikon D5100 Olympus PEN E-PL5 Nikon D7200 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Tokina AT-X Pro 12-24mm f/4 DX II +13 more
