D800: how many pushes for a 1:1 view?
Started Mar 3, 2013 | Questions
nandadevieast Regular Member • Posts: 400
Hi,
How many pushes of the magnify button does it take for a 100% view in playback mode? And what do these 4x/8x/12x mean? 4x of what?
Thanks in advance.
anurag
Nikon D800
iJoost
iJoost Regular Member • Posts: 105
Re: D800: how many pushes for a 1:1 view?
Two down from maximum. Which is called Medium magnification in the f2 setting.
rovingtim Veteran Member • Posts: 8,591
I can't answer how many for a 1:1 view, but I can say that no magnification is the entire picture on your LCD and 2 x is zoomed in so the entire image is twice the size of your LCD, etc.
But your question is very interesting. Why don't manufacturers put on a 1:1 zoom option on the LCD as that has got to be, by far, the most popular view for jobbing photographers.
CraigBennett
CraigBennett Contributing Member • Posts: 699
Nine presses = 100%  Or as iJosst wrote, just go to max and bump down by 2.
 CraigBennett's gear list:CraigBennett's gear list
Nikon D90 Nikon D800E Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR +5 more
Roger Eritja Forum Member • Posts: 59
5
You can configure the central button of the multiselector to zoom at 100% on your reproduced image. That's function F2, choosing zoom as the custom function for the central button, and then "medium enlargement" which turns to be 100%. I always found that trick very valuable to check for basic sharpness, although one must bear in mind that we are looking at a simple JPG.
Roger
Roger Eritja www.eritja.com
sebastian huvenaars Forum Member • Posts: 52
Got mine set up the same way, i use it almost all the time
Turning the front control wheel scrolls trough (potential) faces.
nandadevieast OP Regular Member • Posts: 400
thanks guys
