Samsung NX20 (APS-C) High ISO Noise "Issue"
Started Mar 2, 2013 | Discussions
johnznyc Regular Member • Posts: 127
I did a few quick tests with interesting results.  Currently, I only have two lenses (18X55mm Zoom and 20mm Pancake) but there is clearly a noise difference between the two when shooting ISO 3200.
More important, I quickly concluded that Samsung's jpeg engine at high ISO is horrible -- so bad somebody at Samsung needs to be fired for allowing such poor quality software to be publicly released.
In need to go back and re-shoot with a tripod and manual focus, but from my first two shots, it is quite obvious that Samsung's jpeg engine does not remove much color noise.  In addition, luminance  noise is over-processed and there appears to be no sharpening.  Even modest correction in Lightroom produces much better results.  To be completely fair, I will also create jpegs using Samsung's RAW converter.
Usee
Usee Senior Member • Posts: 2,223
Re: Samsung NX20 (APS-C) High ISO Noise "Issue"
A hint with a possible explanation:
http://www.dxomark.com/index.php/Publications/DxOMark-Insights/F-stop-blues
I would guess that some of the things You describe could be due to (in camera) lens correction - in this case maybe vignetting, beside loss of light correction due to (many) lens elements.
...well, forget JPG - better try ACDSee Pro, Capture One, Lightroom, or something in conjunction with Your Samsung...
...have a look, how ISO3200 @ 16MP can look like (NX1000 downsized):
ISO3200, NX1000 @ 16 MP for comparison
...not bad in comparison to other cameras if compared at the same true ISO instead of the manufacturer claimed ISO and at the same size.
Envy is the highest form of recognition.
Stop to run, start to think.
Think twice - that doubles the fun!
Your world is as big, as Your mind.
Avoid to have only one point of view!
Uli
 Usee's gear list:Usee's gear list
Samsung NX1 Samsung NX 12-24mm F4-5.6 ED Samsung NX 45mm F1.8 2D/3D Samsung 16-50mm F3.5-5.6 power zoom Samsung 50-150mm F2.8 S
johnznyc OP Regular Member • Posts: 127
Uli
I agree -- I shoot in raw only then correct.  But I keep seeing these "Samsung high ISO noise" comments and they are simply incorrect, at least regarding the sensor.
At high ISO, raw images are of the same quality to that of an Sony NEX-7, and low ISO a bit better.
Laurie899 Regular Member • Posts: 149
Usee
The DxO article is very interesting. Have I udersood correctly that the impact of light loss for a given large appeture is greater on higher pixel count sensors? It seems that for large appetures that noise is the price paid however still retaining the advantage of shallow depth of field (not mentioned by DxO)
The resized image (16mp) seems impresively low on noise for 3200. I have wondered, is down sizing a practical method to reduce noise generaly on images. I seem to have read contradictory articles on this
Laurie
 Laurie899's gear list:Laurie899's gear list
Samsung NX20 Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS Samsung NX 12-24mm F4-5.6 ED Fujifilm XC 16-50mm F3.5-5.6 OIS
viking79
viking79 Forum Pro • Posts: 14,136
Exactly, at high ISO the JPEG engine is no good at default settings, especially for people. My wife's face had gray spots all over it from where it went excessive with chroma noise reduction, but as you say, it isn't good at chroma reduction. Basically 800 or 1600 is probably my limit for JPEG. As for sharpening, you can adjust that in "picture wizard", press up on directional controller when you have one highlighted and you can change sharpness, contrast, saturation, and color hue. Not a lot of adjustments, but something that might help. As you say, I just shoot RAW Low ISO the JPEG engine is very good though.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Usee
Laurie899 wrote:
Usee
Laurie,
as You can see, it depends mainly on the pixel size (sensor size and pixel count),
but also on other things, like pixel and microlens design - beside the used lens and it's construction...
...but in tendency You understood it right.
Yes, somehow, but it is more that the (light) advantage of larger apertures is partly eaten by the disadvantage of a higher light loss (in conjunction) with smaller pixel size (and geometry).
As You pointed at, the advantage of shallow depth of field remains.
Laurie
I would be surprised, if You read contradictory articels on this somewhere - maybe You can hint to some?
Ulrich
Uli
Ulrich,
Thanks for your response, I can't quote the contradictory article as I did the search months ago and have lost the track and don't remember the logic of the  argument. In practice it is however easy to validate for a specific case.
Laurie
