want to rename multiple files at one time
Started Mar 2, 2013 | Discussions
darwin36
darwin36 Junior Member • Posts: 40
Guys cant figure ot how to rename multiple Images at once. Using LR4 . And I want it the real image file .
 darwin36's gear list:darwin36's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 14mm f/2.8L II USM Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM +7 more
fuego6
fuego6 Senior Member • Posts: 1,966
Re: want to rename multiple files at one time
Wouldn't recommend doing this in LR... get yourself a tool designed for just that.  Personally, I use XYPlorer as an explorer replacement and it has a very advanced file renamer built in that I use often to batch rename.... simple, powerful, quick.
plugin Contributing Member • Posts: 805
Wouldn't recommend doing it outside of LR ... LR will not be able to load the images after renaming (you can tell LR to look for them, but I don't know if it just looks for file names, in which case that would fail. If so, and you do rename them outside of LR, you will lose all your edits and history.
johnsong Senior Member • Posts: 1,173
What do you want the multiple images to be called?
fuego6, Are you saying you personally use XYPlorer to rename multiple images within Lightroom.
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,274
In the Library Module select all the files you want to rename at one time, generally the files you want to rename in a sequence.
Go to Library/Rename Files (F2) and select the File Naming method want to use.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
