Purple flare: Causes and remedies
Started Mar 1, 2013 | Discussions
Anders W
Forum ProPosts: 21,460Gear list
Mar 1, 2013
There have been quite a bit of discussion here over the last half a year or so about the fact that the E-M5 (and possibly some other MFT cameras too) tend to produce purple flare in certain situations. The problem is particularly noticeable with the Panasonic 7-14 but that is, in all likelihood, merely a consequence of the fact that the 7-14, like other UWAs, is more prone to flare in general than other lenses. The tendency for the flare to go purple is there with any lens, not just the 7-14.
Ever since the first major thread on the subject about half a year ago (see here) I have been trying to figure out exactly what is going on here. Why is the flare, which is neutral white/gray with other cameras (e.g., the G1) going purple on the E-M5 (and perhaps some other MFT bodies as well)?
I have had what I consider to be reasonably promising ideas about that for a while now but I have been waiting for some key equipment that would allow me to test my ideas to a somewhat greater extent before spelling them out. That equipment finally arrived so here goes.
As a testing stage, I chose my kitchen ceiling with associated spotlights. As previously observed, strong lights just outside the frame is one of several conditions that might cause the dreaded purple flare to appear and as shown by the first of the three images posted below (with the spotlights just outside the top of the frame), I had no difficulties reproducing the problem with the 45/1.8 on the E-M5.
What we see here, by the way, is in all likelihood the same phenomenon that has received so much attention with regard to the iPhone 5. Just google the phrase "purple flare" without specification, e.g., by means of this link and you will see what I mean.
Apple's official explanation (see here) is the following:
"Most small cameras, including those in every generation of iPhone, may exhibit some form of flare at the edge of the frame when capturing an image with out-of-scene light sources. This can happen when a light source is positioned at an angle (usually just outside the field of view) so that it causes a reflection off the surfaces inside the camera module and onto the camera sensor. Moving the camera slightly to change the position at which the bright light is entering the lens, or shielding the lens with your hand, should minimize or eliminate the effect."
Well, so far so good, but we all kind of knew that already. The key question is why the flare now goes purple whereas it previously stayed neutrally colored (white/gray) and, as far as I can tell, not much of a convincing answer has been provided yet, by Apple or anyone else. As you can see here, DPR, in their "quick review", suggest a lot of potential explanations but reject most of them and in the end have little more to offer than speculations about the new saphire glass in front of the lens and the lens coatings.
So what's really going on here? In the second and third image posted below, the flare and/or its purpleness has been vastly reduced. So what did I do to achieve that?
No, I didn't change the light, the camera position, the framing, the lens, the focus or the aperture. The light remained unchanged and the camera was firmly fixed on a tripod. All images were shot with the E-M5 and the 45/1.8 at f/1.8 and 1/5 s. And no, I didn't do anything to reduce the flare or its purpleness in PP. What I did to reduce it was done at the time of shooting. So what did I do? Two different solutions were tried, one for image two and another for image three.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
ryan2007
Forum ProPosts: 12,001Gear list
Re: Purple flare: Causes and remedies
In reply to Anders W, Mar 1, 2013
Simple,
Don't shoot directly into any light source, move camera position so you do not see direct light, tilt camera toward the ground and zoom in if you have to, crop purple issues in post editing, change to a different lens. Just skip the shot, or don't buy the lens.
I use this lens all the time and never get any purple flare.
noirdesir
Forum ProPosts: 12,183
IR or UV cut-off filter?
Anders W
In reply to noirdesir, Mar 1, 2013
I see your idea. But, nope.
richarddd
Senior MemberPosts: 2,982Gear list
I'd note that there are two issues, flare and purple. Purple is relatively easy to deal with in post processing (if you have the right tools). Flare is a much more difficult task in post.
The usual remedy for flare is to avoid bright lights, especially point sources.
I look forward to seeing your technique.
I notice you didn't include EXIF data. Does that provide a clue to your technique?
 richarddd's gear list:richarddd's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +3 more
kenw
Veteran MemberPosts: 4,859Gear list
Well, just to potentially eliminate the obvious since you didn't mention it explicitly...
Did you shade the lens front element from the ceiling lights?  They are notably outside the image so you could have done that...
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GM1 Olympus E-M5 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +29 more
Macx
Senior MemberPosts: 1,430Gear list
Well, I suppose it isn't a lens hood. Pol-filter perhaps?
Dr_Jon
Senior MemberPosts: 2,502Gear list
Aperture? Narrower beam of light so less possible reflections.
 Dr_Jon's gear list:Dr_Jon's gear list
Fujifilm FinePix Real 3D W3 Sony RX100 Panasonic Lumix DMC-GH4 Canon EOS 5DS R Canon EF 14mm f/2.8L II USM +23 more
Prokyon
Forum MemberPosts: 85Gear list
Anders W wrote:
...but I have been waiting for some key equipment that would allow me to test my ideas to a somewhat greater extent before spelling them out.
Minus Violett-Filter ?
 Prokyon's gear list:Prokyon's gear list
Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Sigma 105mm F2.8 EX DG Macro Sigma 150mm F2.8 EX DG Macro HSM Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +5 more
Anders W
In reply to richarddd, Mar 1, 2013
Yes, but the purpleness is not always that easy to get rid off, depending on how much of it and where it is. I can't remember seeing any complaints about flare with the 7-14 before that flare started to become purple. The reason, of course, is that before that it was hardly visible since it merely implied a slight loss of contrast, although it was certainly present.
Yes, but there are quite a few scenes where this is more or less impossible.
I hope I won't make you too disappointed. But I should mention in advance that I think my main contribution (if any) will be toward a better understanding of the causes. Not that the solutions are bogus but they do have their downsides.
They might, yes, at least in one case and perhaps indirectly in the other. So I removed them in order to make the quiz a bit more challenging.
Anders W
In reply to kenw, Mar 1, 2013
Hi Ken,
No I didn't shield. That would have been cheating in my book.
Anders W
In reply to Dr_Jon, Mar 1, 2013
Nope. I said I didn't change the aperture.
Anders W
In reply to Prokyon, Mar 1, 2013
You mean a green filter (to eliminate purple)? If so, no.
Anders W
In reply to Macx, Mar 1, 2013
No.
Pol-filter perhaps?
Yes, in one case. Which? And for what reason can a polarizer remove lens flare and/or its purpleness?
Prokyon
they are used in astronomy to reduce purple halo
http://cs.astronomy.com/asy/equipment/f/12/t/36802.aspx
richarddd
Perhaps because people are generally used to flare, especially with an UWA lens, while purple flare is much more unusual.
Yes, alas.
If it's in the EXIF data and it's not aperture, that leaves shutter speed and ISO, neither of which I'd have thought would have any effect on flare, purple or otherwise.
MAubrey
Senior MemberPosts: 1,598Gear list
Anders W wrote:
Pol-filter perhaps?
Hmmm. So at least one answer is DIY filters for the 7-14mm...
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha 7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Voigtlander 58mm F1.4 Nokton SL II Voigtlander 35mm F1.2 Nokton +6 more
Anders W
OK. I have yet to try my old green filter. But, given my ideas of what the cause of the purpleness is, I have little reason to think it would work in this case.
Macx
Anders W wrote:
No.
Pol-filter perhaps?
2nd one? Well, the flare is a reflection and as such polarised light? *guessing*
Erick L
Contributing MemberPosts: 848
So, what did you do?
Erick - www.borealphoto.com
