X100S vs X20 Studio Comparison Test : Advice From Experts Would Be Appreciated
Started Mar 1, 2013 | Discussions
ryder78 Contributing Member • Posts: 616
As some forummers here have mentioned earlier, this studio test may not accurately represent the actual performance of the cameras due to some discrepancies/anomalies/whatever in the test conditions, though I would think judgment through this method may be more accurate than looking at a set of similar images from both cameras.
Some of the images taken from the studio test are as below. Image of the X20 at the top, X100S at the bottom.
Questions as follows:-
1) Why does the X20's textured black board at the background show more detail than the X100?
2) Why does the red flower in the X20's image initially showed a more saturated color and better detail than the X100S at ISO100 and ISO200, but at ISO400 onwards it is the X100S that showed better detail than the X20?
I would truly appreciate some feedback on this matter. Thanks.
ISO100
X20
X100S
Impressions:-
Black textured background - The X20 shows more detail in this area. The fine horizontal lines can be easily seen on the X20's image. These lines are blurred and look soft on the X100S.
Green apples - The green apples on the X100S show more detail and saturated colour than the X20.
Red flower - Look at the petal and the thing in the middle. The X20 shows a more saturated colour and slightly more detail than the X100S
____________________________________________________________________________
ISO200
X20
X100S
Impressions:-
Black textured background - Similar results to ISO100. The X20 shows more detail in this area.
Green apples - Similar results to ISO100. The green apples on the X100S show more detail and saturated color than the X20.
Red flower - Similar results to ISO100. The X20 shows a more saturated color and slightly more detail than the X100S.
ISO400
X20
X100S
Impressions:-
Green apples - The clarity of the X20 clearly takes a dip here. The green apples on the X100S show substantially more detail and saturated color than the X20.
Red flower - Tables are turned here. Instead of the X20 exhibiting more detail and saturated colors than the X100S at ISO100 and ISO200, the image on the X100S here shows significantly more detail than the X20.
ISO800
X20
X100S
Impressions:-
Similar results to ISO400 except that the X20 now shows more noise here.
ISO1600
X20
X100S
Impressions:-
The X20 shows considerably more noise here.
ISO3200
X20
X100S
Impressions:-
The X20 appears to be losing it here as the X100S remains clean.
Fujifilm FinePix X100 Fujifilm X100S Fujifilm X20
jakeman Junior Member • Posts: 41
Re: X100S vs X20 Studio Comparison Test : Advice From Experts Would Be Appreciated
The better detail on the black background on the X20 is just due to the fact that it's in focus on the X20 shot and out of focus in the X100S shot - with the larger sensor size comes a smaller depth of field at the same aperture. This is also why the flower is more detailed on the X20 pic than the one from the X100S, the front part of the flower is out of focus on the X100S. Compare the detail on something that's in focus in both pictures, like for example the celery thing in the left glass, and the X100S is miles ahead even in the ISO 100 shot. In the ISO 400 shot the detail in the X20 is just a muddled mess in comparison.
Shooting small objects from a pretty close distance you're gonna need a very small aperture to get them all in focus with the X100S. The smaller depth of field is preferable in a lot of cases and can make for pleasing images, for example when you shoot portraits and want the background to look a bit blurry. If you're a couple of meters away from your subject it's also easier to get everything important in focus with a decently large aperture on a camera with a bigger sensor like the X100S.
mbb101 Junior Member • Posts: 41
Apart from the depth of field issue the X20 is overexposed by 2/3's of a stop and the X100s by 1/3 stop. Quite frankly the X20 looks like it could do with 2/3 to 1 stop of exposure less. The greens look awful and with the greater saturation then the noise would not be as accentuated.
Notwithstanding that the X20 looks like a iso 800 camera as was the X10.
