I want to "delete" all but the center point from the viewfinder on 6D - can I?
Started Mar 1, 2013 | Discussions
billorg Senior Member • Posts: 1,194
I can turn off all but the center point (from seeing them and from using them) on the 5DMIII, but I cannot find a way to do it on the 6D. Please tell me how to do it if it can be done. Thanks, Bill
 billorg's gear list:billorg's gear list
Canon EOS 5D Mark III Sony SLT-A99 Canon EOS 6D Canon EOS 70D Nikon D5500 +13 more
Canon EOS 5D Canon EOS 6D
ASR45
ASR45 Forum Pro • Posts: 34,982
Re: I want to "delete" all but the center point from the viewfinder on 6D - can I?
Page 91 on the manual.
http://gdlp01.c-wss.com/gds/8/0300009238/01/eos6d-im-en.pdf
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
biza43 Veteran Member • Posts: 4,274
Have people stopped reding instruction manuals?
www.paulobizarro.com
 biza43's gear list:biza43's gear list
Sony Alpha 7 Sony Alpha 7 II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 +2 more
dave_bass5
dave_bass5 Veteran Member • Posts: 6,211
Yep, too busy starting multiple threads about the same subject by the looks of it.
The amount of "how do i" threads on here these days leads me to believe people want others to teach them how to use their equipment rather than make any effort to learn themselves.
 dave_bass5's gear list:dave_bass5's gear list
Canon EOS 5D Mark III Sony a6000 Canon EF 135mm f/2.0L USM Canon EF 24-70mm f/2.8L II USM Canon EF 35mm f/2 IS USM +10 more
George Spencer Senior Member • Posts: 1,079
The manual doesn't tell you how to "delete" all but the center point from the viewfinder does it? It tells you - in effect - how to make the center point dominent.  But that isn't exactly what the OP is asking.
 George Spencer's gear list:George Spencer's gear list
Canon EOS 50D Canon EOS 6D Canon EOS 7D Mark II Panasonic Lumix DMC-GX8 Canon EF 50mm f/1.2L USM +12 more
myphotographic
myphotographic Forum Member • Posts: 93
The 5DIII uses a type of transmissive LCD to overlay the focus points and other on-demand information,. The 6D doesn't feature this technology so I'm guessing the AF points can't be hidden.
Paul
I am sorry, the manual is very clear on selecting AF points: "the selected AF point will be displayed in the viewfinder and on the LCD panel". So, if you are in single point selection, only the AF point you select will be visible, or light up, when you AF.
billorg OP Senior Member • Posts: 1,194
Please read and understand my post before bashing!
Do you really think after all these years I would come here without first reading the manual, searching Google and other sources?  YOU ARE THE ONES who need to READ MY POST before you tell me it's all in the manual, because most of you have no idea what I am talking about here!
My 5DMIII shows ONE SQUARE in the center of the VF - not just a center one that lights up when I shoot, but ONE PERIOD.  My 6D is set to use only the center point (lights red when in use) but it STILL SHOWS ALL THE OTHER POINTS/BLACK SQUARES in the VF that are not being used.  I want to set it so the unused points are not all showing in the VF.
If anyone took the time to read my posts on this, they wouldn't complain that I had 2 posts on here trying to explain it so people would understand me!  I also started out by saying I assumed it couldn't be done, and so far from your answers, it looks like I was right to begin with.
Bill
Thank you George Spencer and myphotographic!
for understanding what I needed to do.
Bill
Gary P Regular Member • Posts: 325
Re: Thank you George Spencer and myphotographic!
END OF LINE...
Andre Affleck Senior Member • Posts: 2,219
Yes, I believe the 6D uses the more traditional technology similar to the 5DII. The AF squares are etched into the view screen material. So you are out of luck.
If you really want to get rid of them you could probably order a custom view screen that only has one AF square. Brightscreen used to be a great source, but I think they went out of business. Do they really bother you?
Re: Please read and understand my post before bashing!
Well, you only made it clear what you wanted now, at least for me. And I was not bashing, I was actually very polite.
Well, most likely, if it is not in manual, chances are that it is not possible... stiil, with such obscure question, why don't you contact Canon service centre directly? They should know...
Bill
Well, that should tell you that you were not being very clear...
Good liuck.
