85 f/1.8 vs 100 f/2.0
Started Feb 28, 2013 | Discussions
Rene71
Junior MemberPosts: 40Gear list
Feb 28, 2013
Hi,
I have a 7D with:
10-22 mm f/3.5-4.5 USM
17-55 mm f/2.8 USM
50 mm 1.8
70-200 mm f/4.0 L
Now I want to buy either a 100mm f/2.0 or a 85 mm f/1.8. The former is more expensive and gives a 160mm to my 7d which can be nice for indoor sports but might be too long for portrait?? The latter is 100 euro's less expensive and imho is more suitable for portrait and could be used for indoor gymnastics of my daughter?
Which one to choose?
Thanks for helping me out
cheers
Rene
 Rene71's gear list:Rene71's gear list
Canon EOS 20D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +3 more
Canon EOS 7D
Sovern
Contributing MemberPosts: 907
Re: 85 f/1.8 vs 100 f/2.0
In reply to Rene71, Feb 28, 2013
Rene71 wrote:
Hi,
I have a 7D with:
17-55 mm f/2.8 USM
50 mm 1.8
70-200 mm f/4.0 L
cheers
Rene
85mm makes more sense to me (135mm 35mm or rather FF equivalent). 160mm can be cutting it too tight even outdoors I'd imagine. From what I've read both lenses are identical in optical performance with the 85 1.8 gaining the edge in AF speed.
Gearóid Ó Laoi, Garry Lee
Veteran MemberPosts: 6,034Gear list
In reply to Sovern, Feb 28, 2013
I've both. Optically more or less similar. Go for 85.
NĂ­or bhris focal maith fiacail riamh (Irish Gaelic)
A good word never broke a tooth.
 Gearóid Ó Laoi, Garry Lee's gear list:Gearóid Ó Laoi, Garry Lee's gear list
Canon PowerShot S90 Fujifilm X10 Canon EOS-1Ds Mark III Panasonic Lumix DMC-G1 Canon EOS-1D Mark IV +25 more
Scott Larson
Veteran MemberPosts: 5,579Gear list
In reply to Gearóid Ó Laoi, Garry Lee, Feb 28, 2013
With the copies I've owned and used...
The 100mm f2 is soft wide open. It was soft even on my old D30 and 1D so it must be worse with more modern cameras. Stop it down to f2.8 and it's great.
The 85mm f1.8 is somewhat sharper wide open and is great at f2.0. You will have to watch out for purple fringing in high contrast situations between f1.8 and f2.8.
 Scott Larson's gear list:Scott Larson's gear list
Canon EOS-1D Mark III Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +12 more
ulto
Forum MemberPosts: 62
I have owned both lenses.
They are the same, just go for the focal length you want.
barba
Regular MemberPosts: 108Gear list
Sovern wrote:
Rene71 wrote:
Hi,
I have a 7D with:
17-55 mm f/2.8 USM
50 mm 1.8
70-200 mm f/4.0 L
cheers
Rene
+ 1! Go for 85mm f/1.8.
 barba's gear list:barba's gear list
Canon EOS 400D Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS
Scott Larson
In reply to ulto, Mar 1, 2013
If you want to shoot at f2, you'll be happier with the sharper 85mm than the soft 100mm.
ulto
In reply to Scott Larson, Mar 1, 2013
As we know some samples of the same lens model are more or less sharp.
If you want to base your decision on which of the two lenses is sharper, I would rather refer to reviewers like DxOmark or Photozone that are shooting charts.
MisterPootieCat
Veteran MemberPosts: 3,085Gear list
Photozone testing shows the 100/2 is almost as sharp in the center and a wee bit sharper in the corners at f2.8, and the 85/1.8 is softer at the center and corners at f1.8.
I own and use the 85/1.8 but at anything less than f/2.8 it's a turd unless you like that look. Check the lens test data at slrgear for more info. It's kind of like the 50/1.4, dreamlike softness  wide open that turns into almost razor like sharpness at f2.8 and higher.
In real world shooting it's doubtful the small differences between the two would ever be noticed.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon PowerShot S2 IS Canon PowerShot S5 IS Canon PowerShot G10 Minolta DiMAGE Z1 Konica Minolta DiMAGE Z2 +19 more
BAK
BAK
Forum ProPosts: 20,350
Buy the 100 f2
In reply to Rene71, Mar 1, 2013
You aready have several smallish lenses around 50mm and the 70mm end of the 70-200 is sort of close to the 85mm.
So buy the 100mm lens, just because it is "more" and a bigger step up from what you already have than is the 85mm lens.
BAK
MAC
MAC
Forum ProPosts: 13,209Gear list
you got great glass so far
get 100L instead
Rene71 wrote:
Hi,
I have a 7D with:
17-55 mm f/2.8 USM
50 mm 1.8
70-200 mm f/4.0 L
cheers
Rene
 MAC's gear list:MAC's gear list
Canon EOS Rebel SL1 Canon EOS 7D Mark II Canon EF 70-200mm f/2.8L USM Canon EF 100mm f/2.8L Macro IS USM Canon Extender EF 1.4x II +6 more
jedinstvo
Senior MemberPosts: 1,914
No answer to that question
There is for practical purposes no difference between the two lenses. Used to be the 85 was better for basketball because it's 1/3 stop faster....but with improvement of image quality with high ISO that no longer matters. I have both. You can buy either and it won't matter.
biza43
Veteran MemberPosts: 3,524Gear list
The obvious thing to do: try your 70-200 zoom at 85mm and at 100mm, in the situations you describe, and decide from your conclusions.
As for sharpness or lens IQ the 85 and the 100 are from similar vintage, meaning nobody would be able to tell the difference.
www.paulobizarro.com
 biza43's gear list:biza43's gear list
Sony Alpha 7 Sony Alpha 7 II Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 +2 more
Scott Larson
Re: No answer to that question
In reply to jedinstvo, Mar 1, 2013
Only if you feel that improved sharpness at f2 is not a practical difference.
Only with cameras that aren't noisier at higher ISO.
