Best light modifier for wind?
Started Feb 27, 2013 | Discussions
ishuffle
New MemberPosts: 2
Feb 27, 2013
Hi Everyone,
Using a mobile device and couldn't find the search options. Sorry if this has been asked before.
I'm looking for a soft light modifier than can withstand windy conditions. Have tried using an 60" umbrella outdoors and I can just see it flying away one day.
Any recommendations?
Is the 28" westcott soft box any good?
Phil
zanderlane
Junior MemberPosts: 46Gear list
Re: Best light modifier for wind?
In reply to ishuffle, Feb 27, 2013
...I like a beauty dish with a diffuser sock on a C-stand with a pillowcase filled with whatever and clipped to the stand:
...with howling wind in the mojave
...with strong wind at the beach.
...same as above.
 zanderlane's gear list:zanderlane's gear list
Sony Cyber-shot DSC-RX100 IV
zanderlane
ishuffle wrote:
Hi Everyone,
Phil
...also - if you must use a huge soft modifier - use tent pegs and parachute cord to stake your "sail" into the wind just like a tent in windy conditions, tying off to the leading corners of the softbox/brella to share the force of the wind best you can...
z
Sailor Blue
Veteran MemberPosts: 8,676Gear list
In reply to ishuffle, Feb 28, 2013
ishuffle wrote:
Hi Everyone,
Someone to hold the light diffuser is your best modifier for windy conditions.
It is a good quality 28" softbox, but there are lots of other good quality softboxes in that size range.  Which you use is up to you.
Closed softboxes and closed umbrella softboxes are less likely to sail away than an open umbrella.  Traditional non-umbrella softboxes are more sturdy and less likely to bend a rib in the wind than a umbrella softbox or regular softbox.
Smaller light modifiers present less surface to the wind than larger ones so they are less likely to sail away or be distorted/twisted/destroyed.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
VividExposures
Contributing MemberPosts: 987
In reply to zanderlane, Mar 1, 2013
Amazed you were able to have the setup in the 3rd photo on a windy beach!
Nikonparrothead
Veteran MemberPosts: 4,565Gear list
In reply to VividExposures, Mar 1, 2013
If you take a close look, in addition to the pillowcase of sand, the legs of the C-Stand are also buried in the sand. (I always forget that last part).
'Nice pen, bet you write good stories with it.'
 Nikonparrothead's gear list:Nikonparrothead's gear list
Panasonic Lumix DMC-TZ1 Canon PowerShot S95 Fujifilm FinePix X100 Nikon Coolpix A Panasonic Lumix DMC-LX100 +13 more
ishuffle
New MemberPosts: 2
In reply to Nikonparrothead, Mar 10, 2013
Thanks for sharing everyone!
Sorry for the delayed response. Trying to balance work, family and passion!
I will look into the options mentioned above and experiment what works for me.
Phil
Zee Char
Veteran MemberPosts: 9,793Gear list
In reply to ishuffle, Mar 10, 2013
People make a lot of money off gimmicks. Here is a crazy idea. How about inventing the "Windmill Modifier"? Instead of fighting wind make it work for you. It can even have a generator and charge batteries. OK enough foolishness. Sorry. It is a boring day.
 Zee Char's gear list:Zee Char's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon Extender EF 1.4x III Sigma 2x EX DG Tele Converter +3 more
Dougs_Photo
Regular MemberPosts: 127Gear list
In reply to zanderlane, Mar 10, 2013
The raised hand in the last photo seems to be casting a shadow on the sky background. How is this possable?
 Dougs_Photo's gear list:Dougs_Photo's gear list
Canon EOS 5D Mark III Canon EOS 70D Canon EOS 7D Mark II Canon EOS D30 Canon EOS 50D +28 more
dad_of_four
Veteran MemberPosts: 7,697Gear list
In reply to ishuffle, Mar 14, 2013
I have used these when it is too windy for umbrellas or SB. They don't offer the same level of diffusion, but it is better than scrubbing the shoot.
7" / 18cm Soft White Diffuser Sock for Flash Reflector
 dad_of_four's gear list:dad_of_four's gear list
Nikon D70 Nikon D2Xs Nikon D700 Nikon D5000 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +10 more
DuaneV
Senior MemberPosts: 1,350
In reply to Dougs_Photo, Mar 14, 2013
Its just motion blur from a super slow shutter speed. Look at the outline of everything in that photo, its all blurred.
