Which filter adapter size, 67 or 58 mm is better for the Canon SX50 HS and why?
Started Feb 26, 2013 | Discussions
coody
coody Senior Member • Posts: 1,674
Users have reported that both of the 67 and 58 mm filter adapter can fit the Canon SX50 HS though the Canon lists the adapter size is 67 mm. Can experts tell which size is better and why?
(unknown member) Veteran Member • Posts: 3,073
Re: Which filter adapter size, 67 or 58 mm is better for the Canon SX50 HS and why?
I don't know about better but 58mm filters are much less expensive than 67mm filters.  Lensmate has a nice 58mm adapter for about $20
Murry
PK62
PK62 Contributing Member • Posts: 950
Murry
I also have the 58mm adapter from Lensmate.  I chose 58mm because I have filters that size already.
Patti
 PK62's gear list:PK62's gear list
Canon EOS 6D Canon EOS 7D Mark II Canon EF 17-40mm f/4.0L USM Canon EF 24-105mm f/4L IS USM Tamron SP 150-600mm F/5-6.3 Di VC USD +6 more
Jay7h Regular Member • Posts: 178
The 67mm is large, very large and looks weird, at least to me, on the front of the camera. If you use a sunshade, it is huge! It is a matter of aesthetes because both will work without interference with your camera lens. Check Amazon.  The adapter is not expensive.
shade1989 Junior Member • Posts: 33
These are just some pictures of how the 67mm filter adapter and lens looks on the camera. I don't have a 58mm one and I've never seen how it looks on the camera.
 shade1989's gear list:shade1989's gear list
Canon PowerShot SX50 HS
Michael Kaplan
Michael Kaplan Veteran Member • Posts: 4,185
Buy whatever is best for you.
For me since my DSLR lenses are 77mm and 67mm I bought the 67 adapter and have a kit of variable filter adapters so my 77mm filters will work on all my cameras/lenses. Easiest for me, a no brainer. The one other reason to go for 67mm is you can go a little thicker before you would have any vignetting.
Michael Kaplan
http://www.pbase.com/mkaplan
See my profile for equipment list
 Michael Kaplan's gear list:Michael Kaplan's gear list
Sony Cyber-shot DSC-RX100 III Nikon D810 Nikon D500 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Teleconverter TC-20E III +18 more
