Rechargeable AA Batteries and Charger for SB700
Started Feb 26, 2013 | Discussions
sthlm Regular Member • Posts: 136
I've read through most of the older threads about this but thought I'd get the most up to date answer.  I need to buy both the charger and batteries for my flash and would love some recommendations. Is the discharge rate really that important?
 sthlm's gear list:sthlm's gear list
Nikon D600 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tokina AT-X 16-28mm f/2.8 Pro FX Nikon AF-S Nikkor 50mm f/1.8G +1 more
Kuppenbender
Kuppenbender Senior Member • Posts: 1,985
Sanyo Eneloops
Only you can answer that. Is it really that important for you, or do you prefer to recharge your batteries the night before you need them anyway?
I tend to use my flashguns occasionally, and even then a couple of dozen times at a time. Being able to pick up my flashgun without worrying so much about whether the batteries are charged means a great deal to me.
 Kuppenbender's gear list:Kuppenbender's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +3 more
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,141
Re: Rechargeable AA Batteries and Charger for SB700
Rechargeable batteries are expensive and the fastest way to ruin them is by using a cheap charger.  Slow controlled charging of each battery will give you the longest life and the highest charges.
I strongly recommend the Maha Powerex MH-C9000 WizardOne Charger-Analyzer.
B&H - Powerex MH-C9000 WizardOne Charger-Analyzer
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
newtoy Regular Member • Posts: 391
Sanyo Eneloop 2000mAh is the best AA rechargable for the money. Powerrex MH-C801D changer is what I am using. Charge 8 AA or AAA at once and each cell is charge and monitor indepently.
 newtoy's gear list:newtoy's gear list
Nikon D70 Nikon 1 V2 Fujifilm X-T1 Nikon D810 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +23 more
sthlm OP Regular Member • Posts: 136
I live in Sweden and nobody carries that charger for some reason.  Nothing from that brand at all.
bravozulu Contributing Member • Posts: 897
Sanyo Eneloop batteries are the highest quality made. This is because the purity of the chemical components.
If you want to read about them, and see some tests, go to the website for Thomas Distributing.
http://www.thomasdistributing.com/AA-AAA-C-D-9V-Batteries_c_634.html
I believe they are in Pennsylvania. But you can buy the batteries anywhere. I got them at both Amazon.com and from BH Photo in New York.
The Maha charger is rated the highest, according to the tests on the Thomas Industry website. But I'm not a pro, and wanted to save money. So I bought the Pearstone charger sold at BHPhoto. Amazon also sells them. They are about half the price of the Maha. They hold 8 AA cells at one time and have full digital controls. Just like the Maha.
The Eneloops and other good batteries require a charger that will fully discharge the batteries before re-charging them. This conditions the batteries and so you can expect them to last for 1,000 charging cycles. The Thomas website has good technical and background info on rechargeable batteries. Very useful to photographers.
 bravozulu's gear list:bravozulu's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
hirejn Regular Member • Posts: 341
Maha Powerex. They make the batteries and charger. You can buy directly from them. Make sure you get a charger that works with your outlets. I used Powerex 2700mAh batteries intensely for two years before they required replacement. Four batteries cost $14.50 on Amazon; $14.50 for two years worth of batteries is a good deal. I shot a lot of sports and indoor activities. The higher power means the flash recycles quicker and you can get more flashes out of a set of batteries. It's worth it if you use flash more than a couple times a year.
Joel Nisleit Photography
The best piece of camera gear is the one used by someone who understands photography.
 hirejn's gear list:hirejn's gear list
Nikon D300 Nikon D100 Nikon D200 Nikon D700 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +8 more
juliemeikle Regular Member • Posts: 265
The charger costs a lot....is there a cheaper alternative, please?
 juliemeikle's gear list:juliemeikle's gear list
Olympus PEN E-PL1 Canon EOS 5D Mark III Canon EF 50mm f/1.8 II Canon EF 300mm f/2.8L IS USM Canon EF 17-40mm f/4.0L USM +15 more
