New legacy lens, first b&w portrait
Started Feb 24, 2013 | Discussions
Axxel
Junior MemberPosts: 45Gear list
Feb 24, 2013
Got the OM zuiko 28mm f2 for 100 usd used. By far my favorite lens so far!
100% crop from original image, removed background(pp)
C&C always welcome!
Kind regards
Axel
Mojn
Contributing MemberPosts: 884
Re: New legacy lens, first b&w portrait
In reply to Axxel, Feb 24, 2013
You must have done something wrong in post or upload
Axxel
Axxel OP
In reply to Mojn, Feb 24, 2013
what is the problem?
Mojn
I don't know exactly, but this is certainly not the detail and sharpness to be expected from this body-lens combo.
Axxel
Axxel OP
300% crop of origninal image
Still not the sharpnes you expected?
Mojn
Absolutely far from. I'm not saying this to be rude. You might have killed this image in post or maybe a bad exposure. Or in the JPG export.
Rickj23
Regular MemberPosts: 456
Of course it is. The picture was cropped and the background removed, then all converted to B&W.  The image was probably grainy to start with .....
Axxel
Axxel OP
wow! then my nex must be defect because this is the sharpest images iv ever gotten for it,  usually i'm lucky if able to get a good 100%, crop on my display these are sharp at 300%...
Mojn
I don't think so, and I don't wan't to be the klugscheisser. But I do have a reference image with more detail and sharpness to show. Tell me if you get anything out of that, I'll be happy to share ...
Full res at
http://fragment.smugmug.com/gallery/11025276_FhkXpC#!i=2380349480&k=sQmf5T3&lb=1&s=O
davect01
Veteran MemberPosts: 6,559
Sharpness is actually ok, just way to bright and washed out.
Novice photobug, proud NEX-3 owner
http://davesnex-3photos.blogspot.com/
Lightshow
Senior MemberPosts: 4,021Gear list
In reply to davect01, Feb 25, 2013
It's called High-Key, and it looks fine to me, shot wide open I presume.
Can you post the original size?
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony Alpha 7R +1 more
dpdog
Forum MemberPosts: 73
I think that's what they call "artistic license." I think it looks good.
Axxel
Axxel OP
In reply to Lightshow, Feb 25, 2013
yep its at 2.0, im not willing to post the whole image, its R rated in my opinion.. but i thought if its my PP the above poster was complaining about i thought i might post a OCC jepg, in similar  crop.
Kind regards
No PP at all.
Jokica
Senior MemberPosts: 1,047Gear list
In reply to Axxel, Feb 25, 2013
Hi, Axxel!
Nice portrait.
If you like, you can compare sharpness of your picture against this mine .
Taken with NEX-5n and Helios 44M-4, somewhere between 2.8 and 4.0, no PP
Regards
 Jokica's gear list:Jokica's gear list
Sony a6000 Sony a77 II Samyang 85mm F1.4 Aspherical IF Sony DT 16-50mm F2.8 SSM Sony E 50mm F1.8 OSS
Jokica
In reply to Mojn, Feb 25, 2013
Full res at
This is really, really sharp! Yes, this can be reference image. What lens did you use? Any PP?
Regards!
Kalabalik
Junior MemberPosts: 35Gear list
In reply to Jokica, Feb 25, 2013
Jokica wrote:
Full res at
Regards!
This was shot with a D800.
(NIKON D800•1/250 sec at f/4,0•85 mm)
 Kalabalik's gear list:Kalabalik's gear list
Sony Alpha NEX-5N Sony E 35mm F1.8 OSS
Jokica
In reply to Kalabalik, Feb 25, 2013
Thanks!
davect01
In reply to dpdog, Feb 25, 2013
Artistic license is fine, but when you can not see any detail, that's not good.
Mojn
Exactly, handheld (shame on me), lens was old AF Nikkor 85 f1.8. I'm using this lens with moderate succes on my 5N too
