Camera Calibration in Lightroom 4
Started Feb 24, 2013 | Discussions
powerbook Regular Member • Posts: 166
Hi,
I have just got the Lightroom 4, and have a question.
In Develop there is: Camera Calibration -> Camera Standard. I want to set Camera Standard on every import. How can I do this?
Thanks in advance.
/Ib
 powerbook's gear list:powerbook's gear list
Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +10 more
goanna Contributing Member • Posts: 638
Re: Camera Calibration in Lightroom 4
Open up a raw file
Set your development settings including "Camera Standard" that you would like to have as defaults on import.
Go to "Develop" menu and select
"Set Default Settings...."
In preferences you can have the default settings dependant on the serial number of your camera and/or ISO setting.
Hope this helps
 goanna's gear list:goanna's gear list
Canon EOS 5D Canon EOS 40D Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
Denis de Gannes
Denis de Gannes Senior Member • Posts: 1,580
Camera Standard is the automatic default., when you are viewing a raw file.
Denis de Gannes
 Denis de Gannes's gear list:Denis de Gannes's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus 14-150 F4-5.6 II Canon Pixma Pro9000 Mark II
Jim Hess Veteran Member • Posts: 5,138
Denis de Gannes
I thought Adobe Standard was the default profile. But maybe I'm wrong.
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,060
Denis de Gannes
No, you are right - out of the box Lightroom is set to Adobe Standard.
You can set the default to Camera Standard, any other available camera calibration, or any camera calibration you have created.  Select the desired camera calibration then hold down the Alt (Option) key to change the button that normally reads Reset into one that reads Set Default...  Click on Set Default... and that becomes the default Camera Calibration.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
powerbook OP Regular Member • Posts: 166
Thanks for the answers :-)
