Rebel T2i vs. EOS 6D - optical viewfinder comparison
Started Feb 23, 2013 | Discussions
djourisman
Regular MemberPosts: 130
Feb 23, 2013
I currently have a Rebel T2i with which I am very happy. I am intrigued, however, by the new EOS 6D with full frame sensor. However, I am concerned by one aspect of the 6D - the optical viewfinder.
The T2i viewfinder has an 0.87x magnification, while the 6D has an 0.71x magnification.
Does anyone have any experience with the 6D viewfinder? Is the view noticeably smaller than the T2i? Any comments or explanations would be greatly appreciated.
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4) Canon EOS 6D
DVT80111
Senior MemberPosts: 1,934Gear list
Pentaprism VF is awesome
In reply to djourisman, Feb 23, 2013
Try it once and you never want to come back.
 DVT80111's gear list:DVT80111's gear list
Sony RX100 Fujifilm X-E1 Canon EOS 6D Canon EOS 70D
mburns
Regular MemberPosts: 249Gear list
Re: Pentaprism VF is awesome
In reply to DVT80111, Feb 23, 2013
Yes, full frame viewfinders are great. The magnification of the viewfinder for a crop frame camera must be handicapped by dividing by the crop factor.
 mburns's gear list:mburns's gear list
Canon EOS 5D Canon EOS 30D Canon EF-S 17-85mm f/4-5.6 IS USM Canon EF 35-80mm f/4.0-5.6 III Canon EF 80-200mm f/4.5-5.6 II +58 more
007peter
Forum ProPosts: 10,132Gear list
the math
Canon 6D = 0.71x divides by FF (1.0) = 0.71 viewfinder size
Canon T2i = 0.87x divides by APSC (1.6) = 0.54 viewfinder size
Nikon D3200 = 0.80x divides by APSC (1.5) = 0.53 viewfinder size
Remember your crop factor is very important.  That is why a lower Nikon D3200 viewfinder seem so big even when the spec only indicates its  0.80x
 007peter's gear list:007peter's gear list
Canon EOS M Panasonic Lumix DMC-GF6 Canon EF-M 22mm f/2 STM Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic Lumix G 25mm F1.7 ASPH
Dave Throgmartin
Contributing MemberPosts: 856
Re: Rebel T2i vs. EOS 6D - optical viewfinder comparison
In reply to djourisman, Feb 24, 2013
Full frame viewfinders are fantastic.  The 6D's is also pentaprism versus the pentamirror on the T2i and will be brighter.
If you tried one immediately after the other you'd notice a major difference.
Dave
Y0GI
Veteran MemberPosts: 5,228Gear list
Re: the math
In reply to 007peter, Feb 24, 2013
Very close Peter.  Here is a convenient table with all of the relative size comparisons:  http://www.neocamera.com/article/viewfinder_sizes
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
Dale Buhanan
Veteran MemberPosts: 3,974Gear list
Re: the math
In reply to Y0GI, Feb 24, 2013
Thanks Yogi.  Bookmarked.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 7D Canon EOS 70D +34 more
RedFox88
Forum ProPosts: 24,052Gear list
correct
Correct.  It is camera maker's fault for using a 50mm lens no matter which SLR instead of using a 50mm FOV since aps-c and 35mm are different imaging formats.
AvyMan
Senior MemberPosts: 2,657
Re: the math
Yogi, you have quite the arsenal of camera info at your disposal. Thanks for sharing this one.
Nick
Photography -- a compatible blend of tech and art --
(Please contact if you want to use any posted photos.)
