D 7100 6 shot Raw Buffer IMO D400 still coming
Started Feb 21, 2013 | Discussions
ThomasH_always
ThomasH_always Regular Member • Posts: 296
Re: D 7100 6 shot Raw Buffer IMO D400 still coming
Stusteelhead wrote:
After a bunch of searching found the D7100 buffer specs. to me 14 bit 6 shot buffer means a D400 has to be coming, http://imaging.nikon.com/lineup/dslr/d7100/spec.htm either that or canon will have a banner second half of the year.
Nikonrumors showed recently a facsimile of a Japanese magazine predicting a D9x00 series, what would be probably "the replacement" for our ancient D300, and a continuation of the D100/D200 lineage. However, they predicted a "D7200" in the same article, and at least in the matter of the product name, they got it wrong.
Thomas
 ThomasH_always's gear list:ThomasH_always's gear list
Canon EOS 6D Leica V-Lux 3 Nikon D7200
teodorian2
teodorian2 Senior Member • Posts: 1,870
Re: So the original poster is wrong?
jfriend00 wrote:
Franglais91 wrote:
You're saying that the original poster is wrong in his assertion that the D7100 will do only 6 uncompressed 14-bit RAW shots before stalling because:
- 6 frames is just the size of the of the buffer, not an actual measurement of the performance
- the D7100 supports a faster card write format so it should be able to flush shots faster (shooting compressed 12-bit will take you further anyway)
OK I can see that. I have never noticed Nikon deliberately limiting the performance of a camera to leave an opportunity to produce a better one
Don't forget that the D7100 images are 50% larger than the D7000 images (24MP vs. 16MP) too so some of the card write speed increase is taken up by the larger images. We'll have to see how this actually works out with a real camera. Actual measured write speed always seems to be different in the real world than what manufacturers proclaim so we will have to see what the actual camera does with a fast card.
I'm guessing a burst of 7-8 before it slows to a stutter speed which averages something around 2-3fps, but this is just a guess based on the specs and how other cameras seem to work.
The D7100 is actually worse than the D7000:
The D7100 manage only 5 fps in 14 bit raw in DX mode (6 fps i 1.3 x crop mode) vs 6 fps for the D7000.
You need to use 12-bit raw to reach 6 fps in the DX mode and 7 fps i the 1.3x crop mode.
From the D7100 pdf:
Approximate frame advance rate • JPEG and 12-bit NEF (RAW) images recorded with DX (24×16) selected for image area: C L 1 to 6 fps, CH 6 fps • JPEG and 12-bit NEF (RAW) images recorded with 1.3× (18×12) selected for image area: CL 1 to 6 fps, CH 7 fps • 14-bit NEF (RAW) images recorded with DX (24×16) selected for image area: CL 1 to 5 fps, CH 5 fps • 14-bit NEF (RAW) images recorded with 1.3× (18×12) selected for image area: CL 1 to 6 fps, CH 6 fps
In real life testing using the same Sandisk Extreme Pro 95 MB/s 16 GB card I found the D7000 to manage 20 12 bit compressed files before stalling vs 57 for the D800E using the DX mode. I was however shooting at 5 fps since I don´t have a grip for the D800E. The D7100 should be comparable to the D7000.
Manuela
Manuela Forum Member • Posts: 99
I believe that there is a Canon agent in the Nikon company whose idea was to cripple the buffer
 Manuela's gear list:Manuela's gear list
Canon PowerShot SX50 HS Nikon D7000 Sony Alpha NEX-5N Nikon D800E Nikon AF-S DX Nikkor 35mm f/1.8G +23 more
lvidal
lvidal New Member • Posts: 1
Re: Most likely not
It's all about marketing, guys. If they say it's not a professional camera most people believe that when certainly it is.
The D7100 have enough features to be considered a complete professional camera. Some people need some features and some people don't, that's why they play with people's minds.
Just remember one thing: Most of the time the most talented and memorable professionals didn't use the top notch technology or equipment but they created masterpieces. And almost any of the DLSR that is offered today have a lot more capabilities than the cameras the best photographers used many years ago.
Focus yourself in what you can create and not what the equipment can do.
n057
n057 Veteran Member • Posts: 4,584
Re: Most likely not
Well, if one says a camera is not the one for him, why do others insist that he should have a second look?
JC
Some cameras, some lenses, some computers
 n057's gear list:n057's gear list
Nikon Coolpix 995 Nikon D200 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +7 more
Mr Gadget
Mr Gadget Senior Member • Posts: 1,966
Re: Most likely not
This is somewhat of a trite comment. The equipment, while not being the whole story does have an important role to play in what you create. Using your logic, I should be able to match the work of Ansel Adams used large format sheet film with a 110 Kodak if only I applied myself.
Certain types and styles of photography require equipment with specific capabilities as defined by the photographer who uses it. If Nikon chooses not to support their customer base that feels that it needs an upgraded D300s, then those customers will look at other options, which opens the door for many to look at other manufacturers. If their hope is that the D7100/D600 will fulfill what their D300s customer base wants they may find that some of us may leave the fold.
Frankly speaking, it would cost Nikon next to nothing to put the D7100 chip and 51 point focus system into a D300 body and make everyone happy.
It is all about choice.
Conrad
Show Low, Arizona
golf1982
golf1982 Contributing Member • Posts: 744
Re: Most likely not
Conrad
Show Low, Arizona
why do you think nikon numbered the d600 that and not the 400 or 500?? Leaving model numbering room, actually they probably intents to number d400, 600 and 800 going to 410 610 and 810...
DezM
DezM Forum Pro • Posts: 34,238
Impressive review
Impressive review of the D7100 but agree that the D400 is still coming.
Mr Gadget
Re: Most likely not
Conrad
Show Low, Arizona
Let us hope that, that is the case! I have the money in my account and I am ready to hit the buy button as soon as the damn thing is announced. The thing that gnaws at the back of my skull is that why hasn't Nikon produced it yet. It may be that they are working on a game changer? A pro level mirrorless based upon the D7100 APS-C sensor et al, but with a lightweight, no mirror, high quality EVF with proper controls? That could explain the delay getting the D400 to market. Not much in the rumor mill though ....
Conrad
Show Low, Arizona
