New Nex 3N
Started Feb 20, 2013 | Discussions
Astrophotographer 10 Senior Member • Posts: 6,682
New Nex 3N
I read the release info on DPreview. I did not see them mention a price.
Does anyone know the price of this camera?
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
D Cox Forum Pro • Posts: 13,845
Re: New Nex 3N
Greg.
There is no single price, it will vary in different countries and from different dealers. But it will be close to the previous NEX 3s.
This is the entry model and it must be priced accordingly. I envy anyone who starts out in photography with one of these.
Kashmir442 Regular Member • Posts: 200
Re: New Nex 3N
Greg.
With the old sensor (same as F3 / 5N), old LCD screen, no accessory port, no wireless, etc. I'll bet they are trying to keep this the costs way down on this one. This will give more separation from the 5 series, and I'd guess Sony is hoping to scoop up lots of low-end point-and-shoot upgraders. They'd hope that some portion of people that buy in cheap will pick up an extra lens or two and then hey - it makes sense to step up to a 5 or 6 series next because you've already got some lenses.
If I didn't already have the RX100, I'd maybe think about this one with the 16-50 pancake as my carry-in-the-work-bag-everyday camera.
Sonyshine
Sonyshine Senior Member • Posts: 7,832
Re: New Nex 3N
It will have to be about £300 - £350 UK price with a kit lens I would think.
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +7 more
Kalabalik Junior Member • Posts: 35
Re: New Nex 3N
That sounds a little too good to be true. The 16-50 PZ alone costs £300.
 Kalabalik's gear list:Kalabalik's gear list
Sony Alpha NEX-5N Sony E 35mm F1.8 OSS
Sonyshine
Re: New Nex 3N
Well I bought my NEXF3 with the kit lens for £299 PLUS £50 cashback which netts down to £249....and this is its replacement?
Helen
Helen Veteran Member • Posts: 4,378
Re: New Nex 3N
One UK site says £400, which is pretty impressive as it's supposed to include the 16-50.  The camera looks attractively styled and compact, but I note the loss of the accessory port (so the F3 turns out to be is unique among the 3's in being able to use the accessory EVF), whilst the limited downward tilt of the F3's LCD has been replaced by no downward tilt at all.
Sonyshine
Re: New Nex 3N
The downward screen tilt does not matter, if its like the NEXF3 you just turn the camera upside down and the screen picture rotates so that overhead shooting works perfectly - something a lot of reviewers did not pick up on! You kinda have to hold it and use it to fully understand!
If its being launched at £400 then it will soon be at £350 - about right!
isvana Regular Member • Posts: 287
Re: New Nex 3N = downspecced
This is more of a NEX-2 with its poorer resolution display (and aforementioned loss of the accessory port). I see the continuous shutter speed is reduced too. Probably the poorer screen is the most significant part, although not being able to add system components (EVF, better flash) almost delegates this to NEX-1 status!
 isvana's gear list:isvana's gear list
Panasonic Lumix DMC-TS3 Sony RX100 II Sony Alpha NEX-6 A3000 +1 more
It's the entry model. It isn't aimed at DPReview readers.
My first (film) camera had interchangeable lenses, an extension tube, and a flash sync socket, but no focussing aid at all (you had to measure or guess the distance), a plain optical viewfinder, no light meter (but the film came with a useful leaflet suggesting exposures for Cloudy Bright etc).
Even so, I managed to shoot correctly exposed and in-focus colour slides, after some practice with B&W negs.
Many people started on plastic Russian cameras with similar specs.
Anyone who starts on a Sony 3N has a vastly better camera and is almost guaranteed technically excellent photos from the first day.
BubbaHotepUK Regular Member • Posts: 458
Re: New Nex 3N
If it does hit the £350 mark, it's almost a no-brainer to buy if you want the PZ 16-50 for an existing NEX. You get the spare battery & body for next to no extra cost
 BubbaHotepUK's gear list:BubbaHotepUK's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Sony Cyber-shot DSC-RX100 IV Sony Alpha NEX-5N Canon EOS 70D +2 more
zygh
zygh Senior Member • Posts: 1,798
Re: New Nex 3N
probably around 500 euros in merkel-reich (formely known as the eu)...
 zygh's gear list:zygh's gear list
Nikon D40 NEX5R Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +2 more
Sonyshine
Re: New Nex 3N
£399 at WEX with the 16-50 lens.....so that will be £350 soon !
zygh
Re: New Nex 3N
yup, seems a bit cheaper in englistan...
Helen
Re: New Nex 3N
Good point! Though I find using a camera upside down a bit awkward, personally - but maybe my coordination is poor. Also, when I was using my briefly-owned NEX-6 (nice camera) upside down for a completely separate reason (actually, to work out whether some one-sided softness to the results was a problem with its particular 16-50 lens or just an artefact due to the subject/shooting conditions) it caused the shutter to malfunction, to my surprise, giving partially cropped images. The issue only occurred whilst it was upside down, but it's made me cautious about inverting modern cameras with focal plane shutters, just in case, as it was clearly stressing the shutter function!
I do think it's a shame that the resolution of the 3N's LCD has been downgraded as well - something I hadn't spotted initially when I scanned the specs. The price, size and styling are impressive (at least from my point of view), but some of the downgrades seem a shame - though Sony is apparently trying to more clearly differentiate its models in the NEX family, which is probably sensible.
True. The F3 was massively overpriced in the UK on its launch (over £500, more than the then-current 5N) though it did of course fall a lot, and very rapidly (as did the 5R, though the fall on the 6 has been a lot slower and not so far).
spacemn Senior Member • Posts: 1,590
Re: New Nex 3N
It's a tempting little piece:
http://www.youtube.com/watch?v=Ut7RnW2KUvs
Build and materials seem nicer than the NEX-6. Quite impressive.
The only niggle I have is that the screen res is downgraded. Big let down!
If the rumor holds, $500 including the 1650PZ, then it is very tempting. The NEX-7 and the 3N could make for a nice set ;P
Ian Cockram New Member • Posts: 6
Re: New Nex 3N
My RX100 was recently stolen and much as you suggested above, my dilemma is to either replace with the same or wait for the 3N. I have no experience with NEX cameras. Which do you think is likely to produce the best picture quality? Cheers
joun Junior Member • Posts: 37
Re: New Nex 3N
I was tempted to buy the 5R body only but am tempted by this if it hits the shops before March 16th (going on holiday and need a travel camera)
WIFI? RAW? Video capabilities vs 5R? Possible to use off camera flash?
WillMc Regular Member • Posts: 132
Re: New Nex 3N
I think you might still want to look at the F3. It's pretty cheap now, and it's got a lot to recommend it.
 WillMc's gear list:WillMc's gear list
Sony Cyber-shot DSC-RX100 III Sony E 18-55mm F3.5-5.6 OSS Sony E 55-210mm F4.5-6.3 OSS +1 more
sergerez Regular Member • Posts: 217
Just curious: which 'plastic Russian cameras' in particular you're referring to: all Zenit, FED, Zorkiy series were metal, quite heavy bodies. Unless you're talking about some toy cameras, which I don't even recall. No offence here.
Serge
