Xrite ColorChecker Passport & Merrill images
Started Feb 18, 2013 | Discussions
PicOne
PicOne Veteran Member • Posts: 6,923
I didn't have any luck trying to use my ColorChecker passport to set color for DP2M files.  THought I'd trying with X3F->TIF->DNG, but couldn't get this to work.
Does anyone know of a tool like XRite software product that can be made to work with Jpegs or Tifs?  If not, is there a reason nobody has invented one yet?
'Everything in photography boils down to what's sharp and what's fuzzy.'
-Gaylord Herron
Sigma DP2
guzzibreva1 Contributing Member • Posts: 949
Re: Xrite ColorChecker Passport & Merrill images
The only way I found to make the Passport work with my SD14 was to convert the X3F to DNG directly using ACR.
DMillier Forum Pro • Posts: 19,092
My SD9, SD14, DP1 all work with DNG profiles in LR just fine. The original image used to generate the profile has to be converted to DNG but once done, the profile can be applied to the X3f files direct.
PicOne
PicOne OP Veteran Member • Posts: 6,923
Yes but I assume you converted the raw x3f to Dng not a tif.  Of course since PS doesn't support the Merrill raw files I had to export to tiff, then "convert" the tiff to dng.
martin
-CG-
-Gaylord Herron
I haven't used a Merrill. LR supports my older Sigmas. The procedure was simply to make a DNG of the colour checker image (I did several under different lighting) then generate the recipe file.
After that, I convert regular x3f files in LR and apply whatever profile looks best.
vfan Forum Member • Posts: 53
For Merrill of cameras, Maybe you can try the ACR Calibrator.
It is a script for Adobe Photoshop. Take Tiff of Colorchecker chart into ACR, and it will give you the best setting. But it's not good than Camera profiles editor.
 vfan's gear list:vfan's gear list
Sigma 50mm F1.4 DG HSM | A
D Cox Forum Pro • Posts: 13,854
That would not work because the TIFF is not a raw format. You would have to go directly from X3F to DNG.
In principle, one should be able to make a set of custom curves for use in Photoshop, based on the Color-Checker image.
The ACR calibrator script seems the nearest to this.
PicOne
Yes, but I thought that by making the DNG from a TIF, maybe I could "fool" the software.
I can tend to laziness; so nobody has created a software that does this automatically for non-Raw files?
Maybe I'll try this. Is this built into PS or a download from elsewhere?   But if this is called "ACR", it sounds like it's meant for Raw files, if PS doesn't recognize my X3Fs, will this still work; and/or work with Tifs?
-Gaylord Herron
You can find the AcrCalibrator in the link or others.
http://www.fors.net/chromoholics/
First, Check the box in ACR setting "Always open TIFF files with settings using Camera Raw"
Used SPP to output TIFF that has a ColorChecker Chart.
Load Tiff by Photoshop, then it will open in ACR. Open this into the Photoshop and run AcrCalibrator.
At last you get one picture that has some parameter in ACR.
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,724
if all you want is to get colors from SPP output to .tiff right (according to some proper rendering of a target, might be a synthetic image of the target) in Photoshop - study this script and modify it accordingly (for your target).
http://sail2ithaki.livejournal.com/142328.html
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
johnyj Junior Member • Posts: 31
For DP2M, you might consider using X3change, if you could provide me with a colorchecker shot X3F file under sunlight, I will calculate the matrix for you
