Lens hood - do you use one?
Started Feb 18, 2013 | Discussions
pannayar Regular Member • Posts: 213
One of my (bought used) camera came with a lens hood.  Some reading suggests it can prevent glare/flare.  I am curious to know how (much) people use these...  If you have one, is it just collecting dust in the drawer or is it a 'must have' for you on outdoor photo trips...?
Pitbullo Regular Member • Posts: 476
Re: Lens hood - do you use one?
I use lens hoods, both to prevent glare, but also for protection of the front element. The only negative thing about a lens hood is that the camera gets longer when it is in use. Other than that, all positive!
Some use UV filters for protection, much better to use a lens hood.
Barrie Davis
Barrie Davis Forum Pro • Posts: 21,460
Yes, I use one.
So should you, and you should use it all the time...
Only under rare circumstances do I take off a lens hood while shooting, for instance, if it throws a shadow from the built in flash.
Baz
"Ahh... But the thing is, these guys were no ORDINARY time travellers!"
MPrince Senior Member • Posts: 1,421
Yes, of course, and not just when shooting outdoors.
HEA-45 Regular Member • Posts: 330
I rarely use a lens hood for my landscape shots. The main reason is the incompatibility with my graduated filter set (which I use constantly.) The second reason is simply a lack of necessity; experimentation has shown that hoods make little difference (with a careful shot setup.)
As a side note, I designed and prototyped several inexpensive lens hoods (for personal use) that were compatible with my filter holder. But the lack of necessity prevented further spending for a production model.
 HEA-45's gear list:HEA-45's gear list
Nikon D810 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-120mm f/4G ED VR +10 more
Barrie Davis
The hood exists to remove non-image-forming light from the periphery of the image.
Non-image-forming light is that part of the light passed by the lens which is inside its circle of coverage, but outside the rectangle of the format frame.
This light is always deleterious of image quality.. (reduces shadow contrast).. even if not noticed a lot of the time.
This superfluous light reduces shadow detail, and does so by two independent mechanisms..
1) ... by bouncing between lens elements and creating flare which transfers highlight illumination to shadow zones.. (ameliorated but not removed by efficient lens coatings)
2) ... by spilling unhindered onto the wall of the sensor chamber, and from there reflecting to the sensor itself. All sensor zones receive this light, but it affects the shadows most, as in (1) above. Again, it is ameliorated by painting the surfaces with matte black paint, but the absorption process is not 100% effective.
Preventing this non-image-forming light from entering the lens in the first place, by means of a good hood IS 100% effective.. The closer the edges of the hood crop to the image zone itself, without actually appearing in frame, the better. That is why the ideal opening of a lenshood is a rectangle of same aspect ratio as the sensor, that is, NOT a circle.
(Petal hoods are the compromise they have to be to provide some hooding on zoom lenses, which is most critical at the wide end. The ideal hood for a zoom lens would vary its acceptance angle in synchrony with that of the optics... but the best we have so far are the adjustable professional hoods made in bellows form..)
Final point:- It is particularly important to fit an efficient close cropping hood when using filters, despite any inconvenience.
Baz
Mark B. Forum Pro • Posts: 19,533
Absolutely always...
I never leave home w/o them   I don't use the fill flash as a main source of light, so blocking the flash with the hood is not a concern for me.  It's always on - indoors or out.
Mark
hotdog321
hotdog321 Forum Pro • Posts: 15,713
I shoot professionally and use rigid lens hoods 100% of the time on all my lenses. Most people don't realize that a lens hood is an essential part of the lens itself. It reduce lens flare, increases contrast and provides terrific protection.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,242
As little as possible, but yes
I always have the hood in tow in case the front element cannot be placed in shadow (it's own shadow, or a shadow from something blocking the light (like a tree during the day).
Note the position of the sun in the following - with the sun just behind the left shoulder, not necessary.   But with sun in front of right shoulder, necessary.   There's a lot to consider sizing up a shot, and if the potential for side light on the front element isn't one of the things that automatically come to mind in the process, you're better off using a hood routinely than selectively.   As well, if your shooting style means mounting a hood has you missing opportunities. . .
A hood has a specific purpose (lens protection being a side effect), and it should be used when it has purpose (but there are NO negatives regarding exposures in using one  when there is no purpose).
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
PhD4
PhD4 Senior Member • Posts: 3,616
It's not just "some reading" suggestions.... It is the reason they were created, are available & supplied with most lenses.
Mine are always with me (when I have my backpack), and stored mounted backwards on their respective lenses.
Lens flare can be an issue in may situations, so having the hood on allows me to concentrate more on composition and less on where the sun is.
I have no built-in flash, and I don't shoot much indoors without controlled lighting situations.
So for me... mostly just outdoors.
Many will cheer the whole "lens protection" thing, but I find even better lens protection is to keep my camera from bumping things.
Which isn't very hard to do.
sensible Junior Member • Posts: 36
i personally do not use lens hoods. while i understand the benefits ,they are generally too bulky. only one on a beercan
but when i think on it, i wonder why to use these petal shaped
types. look impressive but  why the open spaces between petals?
seems like you are limiting the shading benefit
mgd43 Veteran Member • Posts: 4,275
I always use a lens hood to prevent flare and to protect the lens. You may have to remove the hood when using the pop-up flash as it could cause a shadow. That looks like an aftermarket hood so check that it doesn't cut off the edges at wideangle settings.
 mgd43's gear list:mgd43's gear list
Nikon Coolpix P7800 Nikon D5500 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Sigma 10-20mm F4-5.6 EX DC HSM Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR +3 more
joejack951 Senior Member • Posts: 2,682
Nikon's 28-70/2.8, 17-55/2.8, and 24-70/2.8 lenses all make efficient use of their deep, fixed (relative to the moving front element) lens hoods by way of their optical and mechanical designs. The lens is most extended at the wide angle, preventing the lens hood from causing vignetting at that angle of view. The lens then retracts as the focal length moves towards 50mm equivalent (35mm on the 17-55) effectively making the lens hood deeper and then only extends slightly at the switch-over to telephoto. While not perfect due to the slight extension at telephoto, this design allows for much more shading by the lens hood than a typical zoom hood which moves with with the extending front element or is fixed with a non-moving front element. Because all the extension happens with the hood, there's no surprise when the lens is longer than you thought (as has happened to me with the 24-120/4VR at full telephoto).
 joejack951's gear list:joejack951's gear list
Nikon Coolpix AW100 Nikon Coolpix P7700 Nikon D300S Nikon D3S Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Bob Tullis
Such cutouts are there so the hood doesn't show up on the corners of the exposure.  If you take note, telephoto and telezoom hoods are deeper (and usually don't have cut outs) than hoods on the wider angle lenses.   It's easier to thoroughly sheild a front element that utilizes a narrower FOV than a wider one.
...Bob, NYC
PhD4
Well the petal shape is because the camera sensor is rectangular, not square. The field of view is wider at each side, so a shorter "petal" would be less intrusive on your image. This is mostly a problem for wider angle lenses.
If the camera sensors were square, then a round hood would be more popular.
How often this would even become an issue for you depends on what you are shooting and with which lens.
hotdog321
Petal shape answer.
The petal shape is an optimized shape that allows superior shading for the lens. The corners of the rectangular camera format fit in the "cut" sections of the petal, while the long sections shade the sides. The petal shape is most often used with wide angle lenses, but it also appears on telephotos like the Canon 70-200 f/2.8.
Art Jacks Senior Member • Posts: 2,191
Re: As little as possible, but yes
I would miss many of my shots of something similar to your first shot if I was deciding to to put the lens hood on or not, my lens hoods are on permanently, whilst not adding anything to a shot where they are not needed by the same mark they are not having any detrimental effect, then should I turn around and the shot of a lifetime appears I have my camera ready for the type of image where the lens hood is essential.
Bob Tullis
Did you note the direction of the sun/shadows in the shot you referenced?
Did what I said contradict what you find necessary for your practices?
...Bob, NYC
DonA2
DonA2 Senior Member • Posts: 2,658
Re: Petal shape answer.
I went from a skylight filter add on, primarily to protect the lens, to no filter and a petal type, bayonet mount, hood.  Actually provides better protection from knocks and of course lens flare.  The hood reverses on the lens for storage but even without reversing it the lens cap can still be snapped on.  I now leave the hood deployed.
Don V. Armitage
 DonA2's gear list:DonA2's gear list
Canon PowerShot S2 IS Canon PowerShot SX10 IS Canon PowerShot S100 Canon PowerShot SX40 HS Canon PowerShot SX50 HS +1 more
Hank3152
Hank3152 Forum Pro • Posts: 13,460
Re: Absolutely always...
Same here.....hood always on, especially in a crowded environment........since I don't have a built-in flash the external flash is never a problem.......
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm f/2.8L Macro IS USM +5 more
